查看: 3812|回復: 0
51單片機矩陣鍵盤按鍵識別
#include<reg51.h>
void delay_5ms()
  unsigned char i,j;
  for(i=0;i<=25;i++)
    for(j=0;j<=200;j++);
unsigned char key_scan()
  unsigned char key_temp0,key_temp1;
  unsigned char key_num=0;
  P1=0x0f;
  key_temp0=P1;
  if(key_temp0!=0x0f)
    delay_5ms();
        key_temp0=P1;
        if(key_temp0!=0x0f)
          P1=0xf0;
          key_temp1=P1;
          if(key_temp0==0x0e)
            switch(key_temp1)
                  case 0xe0: key_num=4;break;
                  case 0xd0: key_num=3;break;
                  case 0xb0: key_num=2;break;
                  case 0x70: key_num=1;break;
                  default: key_num=0;break;
          else if(key_temp0==0x0d)
                   switch(key_temp1)
                  case 0xe0: key_num=8;break;
                  case 0xd0: key_num=7;break;
                  case 0xb0: key_num=6;break;
                  case 0x70: key_num=5;break;
          else if(key_temp0==0x0b)
                  switch(key_temp1)
                  case 0xe0: key_num=12;break;
                  case 0xd0: key_num=11;break;
                  case 0xb0: key_num=10;break;
                  case 0x70: key_num=9;break;
          else if(key_temp0==0x07)
                  switch(key_temp1)
                  case 0xe0: key_num=16;break;
                  case 0xd0: key_num=15;break;
                  case 0xb0: key_num=14;break;
                  case 0x70: key_num=13;break;
  return key_num;
  unsigned char key_num;
  do{
    key_num=key_scan();
        P2=key_num/10;
        P3=key_num%10;
  }while(1);
