查看: 6675|回復: 1
基于BMP280芯片的使用程序
ID:233924 發表于 2017-9-18 18:18 | 顯示全部樓層 |閱讀模式
#include "Arduino.h"
#include <Wire.h>
#include <SPI.h>
#include "Adafruit_BMP280.h"
static bmp280_calib_data bmp280_calib;
PRIVATE FUNCTIONS
Adafruit_BMP280::Adafruit_BMP280()
  : _cs(-1), _mosi(-1), _miso(-1), _sck(-1)
Adafruit_BMP280::Adafruit_BMP280(int8_t cspin)
  : _cs(cspin), _mosi(-1), _miso(-1), _sck(-1)
Adafruit_BMP280::Adafruit_BMP280(int8_t cspin, int8_t mosipin, int8_t misopin, int8_t sckpin)
  : _cs(cspin), _mosi(mosipin), _miso(misopin), _sck(sckpin)
bool Adafruit_BMP280::begin(uint8_t a) {
  _i2caddr = a;
  if (_cs == -1) {
    // i2c
    Wire.begin();
  } else {
    digitalWrite(_cs, HIGH);
    pinMode(_cs, OUTPUT);
    if (_sck == -1) {
      // hardware SPI
      SPI.begin();
    } else {
      // software SPI
      pinMode(_sck, OUTPUT);
      pinMode(_mosi, OUTPUT);
      pinMode(_miso, INPUT);
  if (read8(BMP280_REGISTER_CHIPID) != 0x58)
    return false;
  readCoefficients();
  write8(BMP280_REGISTER_CONTROL, 0x3F);
  return true;
uint8_t Adafruit_BMP280::spixfer(uint8_t x) {
  if (_sck == -1)
    return SPI.transfer(x);
  // software spi
  //Serial.println("Software SPI");
  uint8_t reply = 0;
  for (int i=7; i>=0; i--) {
    reply <<= 1;
    digitalWrite(_sck, LOW);
    digitalWrite(_mosi, x & (1<<i));
    digitalWrite(_sck, HIGH);
    if (digitalRead(_miso))
      reply |= 1;
  return reply;
    @brief  Writes an 8 bit value over I2C/SPI
void Adafruit_BMP280::write8(byte reg, byte value)
  if (_cs == -1) {
    Wire.beginTransmission((uint8_t)_i2caddr);
    Wire.write((uint8_t)reg);
    Wire.write((uint8_t)value);
    Wire.endTransmission();
  } else {
    if (_sck == -1)
      SPI.beginTransaction(SPISettings(500000, MSBFIRST, SPI_MODE0));
    digitalWrite(_cs, LOW);
    spixfer(reg & ~0x80); // write, bit 7 low
    spixfer(value);
    if (_sck == -1)
      SPI.endTransaction();              // release the SPI bus
    @brief  Reads an 8 bit value over I2C
uint8_t Adafruit_BMP280::read8(byte reg)
  uint8_t value;
  if (_cs == -1) {
    Wire.requestFrom((uint8_t)_i2caddr, (byte)1);
    value = Wire.read();
  } else {
    if (_sck == -1)
    spixfer(reg | 0x80); // read, bit 7 high
    value = spixfer(0);
    if (_sck == -1)
  return value;
    @brief  Reads a 16 bit value over I2C
uint16_t Adafruit_BMP280::read16(byte reg)
  uint16_t value;
  if (_cs == -1) {
    Wire.requestFrom((uint8_t)_i2caddr, (byte)2);
    value = (Wire.read() << 8) | Wire.read();
  } else {
    if (_sck == -1)
    value = (spixfer(0) << 8) | spixfer(0);
    if (_sck == -1)
  return value;
uint16_t Adafruit_BMP280::read16_LE(byte reg) {
  uint16_t temp = read16(reg);
  return (temp >> 8) | (temp << 8);
    @brief  Reads a signed 16 bit value over I2C
int16_t Adafruit_BMP280::readS16(byte reg)
  return (int16_t)read16(reg);
int16_t Adafruit_BMP280::readS16_LE(byte reg)
  return (int16_t)read16_LE(reg);
    @brief  Reads the factory-set coefficients
void Adafruit_BMP280::readCoefficients(void)
    bmp280_calib.dig_T1 = read16_LE(BMP280_REGISTER_DIG_T1);
    bmp280_calib.dig_T2 = readS16_LE(BMP280_REGISTER_DIG_T2);
    bmp280_calib.dig_T3 = readS16_LE(BMP280_REGISTER_DIG_T3);
    bmp280_calib.dig_P1 = read16_LE(BMP280_REGISTER_DIG_P1);
    bmp280_calib.dig_P2 = readS16_LE(BMP280_REGISTER_DIG_P2);
    bmp280_calib.dig_P3 = readS16_LE(BMP280_REGISTER_DIG_P3);
    bmp280_calib.dig_P4 = readS16_LE(BMP280_REGISTER_DIG_P4);
    bmp280_calib.dig_P5 = readS16_LE(BMP280_REGISTER_DIG_P5);
    bmp280_calib.dig_P6 = readS16_LE(BMP280_REGISTER_DIG_P6);
    bmp280_calib.dig_P7 = readS16_LE(BMP280_REGISTER_DIG_P7);
    bmp280_calib.dig_P8 = readS16_LE(BMP280_REGISTER_DIG_P8);
    bmp280_calib.dig_P9 = readS16_LE(BMP280_REGISTER_DIG_P9);
float Adafruit_BMP280::readTemperature(void)
  int32_t var1, var2;
  int32_t adc_T = read16(BMP280_REGISTER_TEMPDATA);
  adc_T <<= 8;
  adc_T |= read8(BMP280_REGISTER_TEMPDATA+2);
  adc_T >>= 4;
  var1  = ((((adc_T>>3) - ((int32_t)bmp280_calib.dig_T1 <<1))) *
    ((int32_t)bmp280_calib.dig_T2)) >> 11;
  var2  = (((((adc_T>>4) - ((int32_t)bmp280_calib.dig_T1)) *
      ((adc_T>>4) - ((int32_t)bmp280_calib.dig_T1))) >> 12) *
    ((int32_t)bmp280_calib.dig_T3)) >> 14;
  t_fine = var1 + var2;
  float T  = (t_fine * 5 + 128) >> 8;
  return T/100;
float Adafruit_BMP280::readPressure(void) {
  int64_t var1, var2, p;
  int32_t adc_P = read16(BMP280_REGISTER_PRESSUREDATA);
  adc_P <<= 8;
  adc_P |= read8(BMP280_REGISTER_PRESSUREDATA+2);
  adc_P >>= 4;
  var1 = ((int64_t)t_fine) - 128000;
  var2 = var1 * var1 * (int64_t)bmp280_calib.dig_P6;
  var2 = var2 + ((var1*(int64_t)bmp280_calib.dig_P5)<<17);
  var2 = var2 + (((int64_t)bmp280_calib.dig_P4)<<35);
  var1 = ((var1 * var1 * (int64_t)bmp280_calib.dig_P3)>>8) +
    ((var1 * (int64_t)bmp280_calib.dig_P2)<<12);
  var1 = (((((int64_t)1)<<47)+var1))*((int64_t)bmp280_calib.dig_P1)>>33;
  if (var1 == 0) {
    return 0;  // avoid exception caused by division by zero
  p = 1048576 - adc_P;
  p = (((p<<31) - var2)*3125) / var1;
  var1 = (((int64_t)bmp280_calib.dig_P9) * (p>>13) * (p>>13)) >> 25;
  var2 = (((int64_t)bmp280_calib.dig_P8) * p) >> 19;
  p = ((p + var1 + var2) >> 8) + (((int64_t)bmp280_calib.dig_P7)<<4);
  return (float)p/256;
ID:891813 發表于 2021-4-23 13:49 | 顯示全部樓層
這是官方寫的demo吧
