查看: 1945|回復(fù): 0
單片機貪吃蛇游戲
ID:230970 發(fā)表于 2017-9-11 13:06 來自觸屏版 | 顯示全部樓層 |閱讀模式
/***********************************************************功能說明:貪吃蛇編譯環(huán)境:keil4MCU     :STC89C52RC時鐘頻率: 22.1184MHz注意:該例程中“過關(guān)”不能在keil4編譯環(huán)境中正常顯示************************************************************//*****************************************************************                    /^\/^\                  _|__|  O|         \/     /~     \_/ \          \____|__________/  \                 \_______      \                         `\     \                 \                           |     |                  \                          /      /                    \                         /     /                       \\                       /      /                         \ \                      /     /                            \  \                    /     /             _----_            \   \                   /     /           _-~      ~-_         |   |                 (      (        _-~    _--_    ~-_     _/   |                   \      ~-____-~    _-~    ~-_    ~-_-~    /                     ~-_           _-~          ~-_       _-~                           ~--______-~                ~-___-~  *****************************************************************/#include "stc.h"#include "Lcd12864.h"#include "Key.h"#define uchar unsigned char#define uint unsigned intstatic unsigned long Seed = 1;#define A 48271L#define M 2147483647L#define Q (M / A)#define R (M % A)/************************************偽隨機數(shù)發(fā)生器*************************************/double Random(void){        long TmpSeed;        TmpSeed=A*(Seed%Q)-R*(Seed/Q);        if(TmpSeed>=0)                Seed=TmpSeed;        else                Seed=TmpSeed+M;        return (double)Seed/M;}/**************************************為偽隨機數(shù)發(fā)生器播種***************************************/void InitRandom(unsigned long InitVal){        Seed=InitVal;}//延時子程序void delay(unsigned int t){          unsigned int i,j;        for(i=0;i<t;i++)                for(j=0;j<10;j++);    }/*********************************初始化MPU**********************************/void InitCpu(void){        TMOD=0x01;        TH0=0;        TL0=0;        TR0=1;        ET0=1;        EA=1;}#define N 25struct Food{        unsigned char x;        unsigned char y;        unsigned char yes;}food;//食物結(jié)構(gòu)體struct Snake{        unsigned char x[N];        unsigned char y[N];        unsigned char node;        unsigned char direction;        unsigned char life;}snake;//蛇結(jié)構(gòu)體unsigned char Flag=0;unsigned char Score=0;unsigned char Speed=5;                   //speed越大,速度越慢unsigned char KeyBuffer=0;#define FUNC 1                                   //(P3^1)表示級別#define UP 2                                   //(P3^3)表示左#define DOWN 3                                   //(P3^5)表示右#define LEFT 4                                   //(P3^4)表示下#define RIGHT 5                                   //(P3^2)表示上#define PASSSCORE 20                   //預(yù)定義過關(guān)成績void Timer0Int(void) interrupt 1{        switch(OSReadKey())        {                case 5:                                KeyBuffer=FUNC;                                                  //表示級別                                /*if(++Speed>=10)                                        Speed=1;                                   Flag|=1<<1;//速度變化標志置1*/                                break;                case 21:                                KeyBuffer=DOWN;                                                 //表示右                                /*if(snake.direction!=2)                                        snake.direction=1;*/                                break;                case 13:                                KeyBuffer=UP;                                                 //表示左                                /*if(snake.direction!=1)                                        snake.direction=2;*/                                break;                case 9:                                KeyBuffer=RIGHT;                                         //表示上                                /*if(snake.direction!=4)                                        snake.direction=3;*/                                break;                   case 17:                                KeyBuffer=LEFT;                                                 //表示下                                /*if(snake.direction!=3)                                        snake.direction=4;*/                                break;                default:                                break;        }}/******************************畫墻壁,初始化界面*******************************/void DrawBoard(void){        unsigned char n;        for(n=0;n<31;n++)        {                Lcd_Rectangle(3*n,0,3*n+2,2,1);                Lcd_Rectangle(3*n,60,3*n+2,62,1);        }        for(n=0;n<21;n++)        {                Lcd_Rectangle(0,3*n,2,3*n+2,1);                Lcd_Rectangle(90,3*n,92,3*n+2,1);                        }        Lcd_HoriLine(93,31,35,1);        Lcd_HoriLine(93,63,35,1);}/***************************打印成績****************************/void PrintScore(void){        unsigned char Str[3];        Lcd_WriteStr(6,0,"成績");        Str[0]=(Score/10)|0x30;//十位        Str[1]=(Score%10)|0x30;//個位        Str[2]=0;        Lcd_WriteStr(7,1,Str);}/********************************打印速度級別*********************************/void PrintSpeed(void){        unsigned char Str[2];        Lcd_WriteStr(6,2,"級別");        Str[0]=Speed|0x30;        Str[1]=0;        Lcd_WriteStr(7,3,Str);}/***********************************游戲結(jié)束處理************************************/void GameOver(void){        unsigned char n;        Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,0);//消隱出食物        for(n=1;n<snake.node;n++)        {                Lcd_Rectangle(snake.x[n],snake.y[n],snake.x[n]+2,snake.y[n]+2,0);//消隱食物,蛇頭已到墻壁內(nèi),故不用消去                        }        if(snake.life==0)//如果蛇還活著                Lcd_WriteStr(2,1,"過關(guān)");        else             //如果蛇死了                Lcd_WriteStr(2,1,"輸了");        Lcd_WriteStr(1,2,"游戲結(jié)束");}/********************************游戲的具體過程,也是貪吃蛇算法的關(guān)鍵部分*********************************/void GamePlay(void){        unsigned char n;        InitRandom(TL0);        food.yes=1;//1表示需要出現(xiàn)新事物,0表示已經(jīng)存在食物尚未吃掉        snake.life=0;//表示蛇還活著        snake.direction=DOWN;        snake.x[0]=6;snake.y[0]=6;        snake.x[1]=3;snake.y[1]=6;        snake.node=2;        PrintScore();        PrintSpeed();        while(1)        {                if(food.yes==1)                {                        while(1)                        {                                food.x=Random()*85+3;                                food.y=Random()*55+3;//獲得隨機數(shù)                                        while(food.x%3!=0)                                        food.x++;                                while(food.y%3!=0)                                        food.y++;                            for(n=0;n<snake.node;n++)//判斷產(chǎn)生的食物坐標是否和蛇身重合                                {                                        if((food.x==snake.x[n])&&(food.y==snake.y[n]))                                                break;                                }                                if(n==snake.node)                                {                                        food.yes=0;                                        break;//產(chǎn)生有效的食物坐標                                }                        }                }                if(food.yes==0)                {                        Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,1);                }                        for(n=snake.node-1;n>0;n--)                {                        snake.x[n]=snake.x[n-1];                        snake.y[n]=snake.y[n-1];                }                switch(snake.direction)                {                        case DOWN:snake.x[0]+=3;break;                        case UP:snake.x[0]-=3;break;                        case RIGHT:snake.y[0]-=3;break;                        case LEFT:snake.y[0]+=3;break;                        default:break;                }                for(n=3;n<snake.node;n++)//從第三節(jié)開始判斷蛇頭是否咬到自己                {                        if(snake.x[n]==snake.x[0]&&snake.y[n]==snake.y[0])                        {                                GameOver();                                snake.life=1;                                break;                        }                }                if(snake.x[0]<3||snake.x[0]>=90||snake.y[0]<3||snake.y[0]>=60)//判蛇頭是否撞到墻壁                {                        GameOver();                        snake.life=1;                }                if(snake.life==1)                        break;//蛇死,則跳出while(1)循環(huán)                if(snake.x[0]==food.x&&snake.y[0]==food.y)//判蛇是否吃到食物                {                        Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,0);//消隱食物                        snake.x[snake.node]=200;                        snake.y[snake.node]=200;//產(chǎn)生蛇新的節(jié)坐標先放在看不見的位置                        snake.node++;//蛇節(jié)數(shù)加1                        food.yes=1;//食物標志置1                        if(++Score>=PASSSCORE)                        {                                PrintScore();                                GameOver();                                break;                        }                        PrintScore();                }                for(n=0;n<snake.node;n++)                {                        Lcd_Rectangle(snake.x[n],snake.y[n],snake.x[n]+2,snake.y[n]+2,1);                }//根據(jù)蛇的節(jié)數(shù)畫出蛇                delay(Speed*1000);          //調(diào)速                delay(Speed*1000);                Lcd_Rectangle(snake.x[snake.node-1],snake.y[snake.node-1],snake.x[snake.node-1]+2,snake.y[snake.node-1]+2,0);                switch(KeyBuffer)                {                        case FUNC:                                        KeyBuffer=0;                                        if(++Speed>=10)                                                Speed=1;                                           PrintSpeed();                                        break;                        case DOWN:                                        KeyBuffer=0;                                        if(snake.direction!=UP)                                                snake.direction=DOWN;                                        break;                        case UP:                                        KeyBuffer=0;                                        if(snake.direction!=DOWN)                                                snake.direction=UP;                                        break;                        case RIGHT:                                        KeyBuffer=0;                                        if(snake.direction!=LEFT)                                                snake.direction=RIGHT;                                        break;                           case LEFT:                                        KeyBuffer=0;                                        if(snake.direction!=RIGHT)                                                snake.direction=LEFT;                                        break;                        default:                                        break;                }                                }//結(jié)束while(1)}void Main(){          InitCpu();//初始化CPU        Lcd_Reset(); //初始化LCD屏        Lcd_WriteStr(2,1,"航峰興業(yè)");        delay(5000);        delay(5000);        Lcd_WriteCmd(0x01);   //清除顯示,并且設(shè)定地址指針為00H        Lcd_Clear(0);//清屏        DrawBoard();//畫界面        GamePlay();//玩游戲        GameOver();//游戲結(jié)束        while(1);//要想重玩,只能重啟,可繼續(xù)完善該游戲
