STM32 MPU6050-GY521庫函數(shù)
移植直接引用庫函數(shù)就行
MPU6050.zip
(46.71 KB, 下載次數(shù): 144)
2017-9-1 10:53 上傳
點(diǎn)擊文件名下載附件
單片機(jī)源程序如下:
- #include "mpu6050.h"
- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- //本程序只供學(xué)習(xí)使用,未經(jīng)作者許可,不得用于其它任何用途
- //ALIENTEK精英STM32開發(fā)板V3
- //MPU6050 驅(qū)動(dòng)代碼
- //初始化MPU6050
- //返回值:0,成功
- // 其他,錯(cuò)誤代碼
- u8 MPU_Init(void)
- u8 res;
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);//使能AFIO時(shí)鐘
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);//先使能外設(shè)IO PORTA時(shí)鐘
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15; // 端口配置
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度為50MHz
- GPIO_Init(GPIOA, &GPIO_InitStructure); //根據(jù)設(shè)定參數(shù)初始化GPIOA
- GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//禁止JTAG,從而PA15可以做普通IO使用,否則PA15不能做普通IO!!!
- MPU_AD0_CTRL=0; //控制MPU6050的AD0腳為低電平,從機(jī)地址為:0X68
- MPU_IIC_Init();//初始化IIC總線
- MPU_Write_Byte(MPU_PWR_MGMT1_REG,0X80); //復(fù)位MPU6050
- delay_ms(100);
- MPU_Write_Byte(MPU_PWR_MGMT1_REG,0X00); //喚醒MPU6050
- MPU_Set_Gyro_Fsr(3); //陀螺儀傳感器,±2000dps
- MPU_Set_Accel_Fsr(0); //加速度傳感器,±2g
- MPU_Set_Rate(50); //設(shè)置采樣率50Hz
- MPU_Write_Byte(MPU_INT_EN_REG,0X00); //關(guān)閉所有中斷
- MPU_Write_Byte(MPU_USER_CTRL_REG,0X00); //I2C主模式關(guān)閉
- MPU_Write_Byte(MPU_FIFO_EN_REG,0X00); //關(guān)閉FIFO
- MPU_Write_Byte(MPU_INTBP_CFG_REG,0X80); //INT引腳低電平有效
- res=MPU_Read_Byte(MPU_DEVICE_ID_REG);
- if(res==MPU_ADDR)//器件ID正確
- MPU_Write_Byte(MPU_PWR_MGMT1_REG,0X01); //設(shè)置CLKSEL,PLL X軸為參考
- MPU_Write_Byte(MPU_PWR_MGMT2_REG,0X00); //加速度與陀螺儀都工作
- MPU_Set_Rate(50); //設(shè)置采樣率為50Hz
- }else return 1;
- return 0;
- //設(shè)置MPU6050陀螺儀傳感器滿量程范圍
- //fsr:0,±250dps;1,±500dps;2,±1000dps;3,±2000dps
- //返回值:0,設(shè)置成功
- // 其他,設(shè)置失敗
- u8 MPU_Set_Gyro_Fsr(u8 fsr)
- return MPU_Write_Byte(MPU_GYRO_CFG_REG,fsr<<3);//設(shè)置陀螺儀滿量程范圍
- //設(shè)置MPU6050加速度傳感器滿量程范圍
- //fsr:0,±2g;1,±4g;2,±8g;3,±16g
- //返回值:0,設(shè)置成功
- // 其他,設(shè)置失敗
- u8 MPU_Set_Accel_Fsr(u8 fsr)
- return MPU_Write_Byte(MPU_ACCEL_CFG_REG,fsr<<3);//設(shè)置加速度傳感器滿量程范圍
- //設(shè)置MPU6050的數(shù)字低通濾波器
- //lpf:數(shù)字低通濾波頻率(Hz)
- //返回值:0,設(shè)置成功
- // 其他,設(shè)置失敗
- u8 MPU_Set_LPF(u16 lpf)
- u8 data=0;
- if(lpf>=188)data=1;
- else if(lpf>=98)data=2;
- else if(lpf>=42)data=3;
- else if(lpf>=20)data=4;
- else if(lpf>=10)data=5;
- else data=6;
- return MPU_Write_Byte(MPU_CFG_REG,data);//設(shè)置數(shù)字低通濾波器
- //設(shè)置MPU6050的采樣率(假定Fs=1KHz)
- //rate:4~1000(Hz)
- //返回值:0,設(shè)置成功
- // 其他,設(shè)置失敗
- u8 MPU_Set_Rate(u16 rate)
- u8 data;
- if(rate>1000)rate=1000;
- if(rate<4)rate=4;
- data=1000/rate-1;
- data=MPU_Write_Byte(MPU_SAMPLE_RATE_REG,data); //設(shè)置數(shù)字低通濾波器
- return MPU_Set_LPF(rate/2); //自動(dòng)設(shè)置LPF為采樣率的一半
- //得到溫度值
- //返回值:溫度值(擴(kuò)大了100倍)
- short MPU_Get_Temperature(void)
- u8 buf[2];
- short raw;
- float temp;
- MPU_Read_Len(MPU_ADDR,MPU_TEMP_OUTH_REG,2,buf);
- raw=((u16)buf[0]<<8)|buf[1];
- temp=36.53+((double)raw)/340;
- return temp*100;;
- //得到陀螺儀值(原始值)
- //gx,gy,gz:陀螺儀x,y,z軸的原始讀數(shù)(帶符號(hào))
- //返回值:0,成功
- // 其他,錯(cuò)誤代碼
- u8 MPU_Get_Gyroscope(short *gx,short *gy,short *gz)
- u8 buf[6],res;
- res=MPU_Read_Len(MPU_ADDR,MPU_GYRO_XOUTH_REG,6,buf);
- if(res==0)
- *gx=((u16)buf[0]<<8)|buf[1];
- *gy=((u16)buf[2]<<8)|buf[3];
- *gz=((u16)buf[4]<<8)|buf[5];
- return res;;
- //得到加速度值(原始值)
- //返回值:0,成功
- // 其他,錯(cuò)誤代碼
- u8 MPU_Get_Accelerometer(short *ax,short *ay,short *az)
- u8 buf[6],res;
- res=MPU_Read_Len(MPU_ADDR,MPU_ACCEL_XOUTH_REG,6,buf);
- if(res==0)
- *ax=((u16)buf[0]<<8)|buf[1];
- *ay=((u16)buf[2]<<8)|buf[3];
- *az=((u16)buf[4]<<8)|buf[5];
- return res;;
- //IIC連續(xù)寫
- //addr:器件地址
- //reg:寄存器地址
- //len:寫入長度
- //buf:數(shù)據(jù)區(qū)
- //返回值:0,正常
- // 其他,錯(cuò)誤代碼
- u8 MPU_Write_Len(u8 addr,u8 reg,u8 len,u8 *buf)
- u8 i;
- MPU_IIC_Start();
- MPU_IIC_Send_Byte((addr<<1)|0);//發(fā)送器件地址+寫命令
- if(MPU_IIC_Wait_Ack()) //等待應(yīng)答
- MPU_IIC_Stop();
- return 1;
- MPU_IIC_Send_Byte(reg); //寫寄存器地址
- MPU_IIC_Wait_Ack(); //等待應(yīng)答
- for(i=0;i<len;i++)
- MPU_IIC_Send_Byte(buf[i]); //發(fā)送數(shù)據(jù)
- if(MPU_IIC_Wait_Ack()) //等待ACK
- MPU_IIC_Stop();
- return 1;
- MPU_IIC_Stop();
- return 0;
- //IIC連續(xù)讀
- //addr:器件地址
- //reg:要讀取的寄存器地址
- //len:要讀取的長度
- //buf:讀取到的數(shù)據(jù)存儲(chǔ)區(qū)
- //返回值:0,正常
- // 其他,錯(cuò)誤代碼
- u8 MPU_Read_Len(u8 addr,u8 reg,u8 len,u8 *buf)
- MPU_IIC_Start();
- MPU_IIC_Stop();
- return 1;
- MPU_IIC_Start();
- MPU_IIC_Send_Byte((addr<<1)|1);//發(fā)送器件地址+讀命令
- while(len)
- if(len==1)*buf=MPU_IIC_Read_Byte(0);//讀數(shù)據(jù),發(fā)送nACK
- else *buf=MPU_IIC_Read_Byte(1); //讀數(shù)據(jù),發(fā)送ACK
- len--;
- buf++;
- MPU_IIC_Stop(); //產(chǎn)生一個(gè)停止條件
- return 0;
- //IIC寫一個(gè)字節(jié)
- //reg:寄存器地址
- //data:數(shù)據(jù)
- //返回值:0,正常
- // 其他,錯(cuò)誤代碼
- u8 MPU_Write_Byte(u8 reg,u8 data)
- MPU_IIC_Start();
- MPU_IIC_Send_Byte((MPU_ADDR<<1)|0);//發(fā)送器件地址+寫命令
- MPU_IIC_Stop();
- return 1;
- MPU_IIC_Send_Byte(data);//發(fā)送數(shù)據(jù)
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
