查看: 1853|回復: 0
墩泰源代碼
ID:228978 發表于 2017-8-23 16:12 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
* Copyright (C) 2012-2013, FocalTech Systems (R)£¬All Rights Reserved.
* File Name: CfgAutoTune.h
*    Author: linjianjun
*   Created: 2014-01-03
*  Abstract: This file includes all data structures for panel automatic tuning.
*   ×¢òa£¬½á11ìå×÷ÎaáaoÏìåμÄ3éÔ±£¬2»ÄüòÔêy×é¿aí·£¬2»è»3õê¼»ˉ£¬óÅÏè′|àíoffset3éÔ±
*   μ¼ÖÂ1y¶à3õê¼»ˉ±¨′í
* Reference:
#ifndef __CFG_AUTO_TUNE_H__
#define __CFG_AUTO_TUNE_H__
* Conditional Compiler Options
#if (FT_SENSOR_PATTERN_TYPE != FT_2_POINTS_PATTERN)
* 1.Included files
#include "CfgPlatform.h"
#include "CfgGlobal.h"
* 2.Global constant and macro definitions using #define
* 1. projrct information
* Pattern Type:
* 0: 3-3-3 or 4-4-4 triangle pattern
* 1: 2-4-2 or 1-2-1 triangle pattern
#define PATTERN_TYPE               0x01
#define I2C_SLAVE_ADDR             0x70
#define CFG_PANEL_VENDOR_ID        0x11
#define CFG_PROJECT_CODE           "FTS0000P000"
#define CFG_CUSTOMER_CODE          "0000"
* IC Type
* FT6236U      0     //40 Pin 28Ch
* FT6336G      1     //40 Pin 31Ch
* FT6336U      2     //48 Pin 39Ch
* FT6436U      3     //56 Pin 46Ch
#define CHIP_TYPE               0
* 1. Channel Information
/* VA area CH number */
#define TP_CHANNEL_NUM          20
/* virtually key area CH number*/
#define TP_KEY_NUM              0
/* virtually key number */
#define TP_LOGIC_KEY_NUM        3
/* How many chnanels from last is invalid*/
#define KEY_CH_INVALID_NUM      0
#define TP_CHANNEL_ORDER        {9,10,8,11,7,12,6,13,5,14,4,15,3,16,2,17,1,18,0,19}
*2. AFE setting information
* AFE Scan mode
* 0: Single mode
* 1: Double mode(Scan two channels at one time)
* 2: Four mode  (Scan four channels at one time)
* 3: Eight mode (Scan eight channels at one time)
* "Double mode" will improve the anti power noise ability
* Usually use 3(Eight mode) as default
#define AFE_SCAN_MODE           3
* Seleted sensor scan times for every channel, we will get the ACC value of
* all times for the raw data
* scan times = (AFE_SAMPLE_CYCLE + 1) * 8
* Max value 31
* More scan times will get more accuracy, but lower report rate.
* Usually use 7 as default for Single mode and 15 as default for multi scan mode
#define AFE_SAMPLE_CYCLE        15
* AFE water proof level selection
* 0: No Water proof;
* 1: Level 1;
* 2: Level 2;
* 3: Level 3;
* Usually use 3(Level 3) as default
#define AFE_WATERPROOF_LVL      3
* AFE scan frequency is (AFE clock / (AFE_SCAN_K1_DELAY + AFE_SCAN_K2_DELAY)) Khz.
* For example, if AFE_CLK_DIV = 10, AFE_SCAN_K1_DELAY=12, AFE_SCAN_K2_DELAY=18,
* AFE scan frequency is "3000/(12+18) = 100 Khz".
* Set scan sample time (K1_Delay), the range is
* Eight mode from 0x07 to 0xff.
* Four mode from 0x05 to 0xff.
* Double mode from 0x04 to 0xff.
#define AFE_SCAN_K1_AREA1       28//36//23
* Set scan charge time (K2_Delay), the range is
* Four mode from 0x06 to 0xff.
#define AFE_SCAN_K2_AREA1       38//36//23
* ADC sample mode
* 0-> Single sampling 1->Bilateral sampling
* Usually use 1 as default
#define AFE_SAMPLE_MODE         1
* NLC ACTION ENABLE
#define AFE_NLC_EN              0
* THRESHOLD OF NLC faction
#define AFE_NLC_THR             312
* IIR FACTION ENABLE
#define AFE_IIR_EN             0
/* halitus handle afe paramter */
#define AFE_SAMPLE_CYCLE_HALITUS    0
/* = AFE SCAN K1 AREA1 */
#define AFE_SCAN_K1_AREA1_HALITUS   27
/* = AFE SCAN K2 AREA1 */
#define AFE_SCAN_K2_AREA1_HALITUS   27
#define AFE_WATERPROOF_LVL_HALITUS  0
/*  HOPPING HANDLE AFE PARAMTER */
#define AFE_SAMPLE_CYCLE_MAIN       0
#define AFE_SCAN_K1_AREA1_MAIN      27
#define AFE_SCAN_K2_AREA1_MAIN      27
/* = AFE WATERPROOF LVL */
#define AFE_WATERPROOF_LVL_MAIN     3
/* = AFE SCAN K1 AREA1 + 2 */
#define AFE_SCAN_K1_AREA1_ASSIST1   29
/* = AFE SCAN K2 AREA1 + 2 */
#define AFE_SCAN_K2_AREA1_ASSIST1   29
/* = AFE SCAN K1 AREA1 + 4 */
#define AFE_SCAN_K1_AREA1_ASSIST2   31
/* = AFE SCAN K2 AREA1 + 4 */
#define AFE_SCAN_K2_AREA1_ASSIST2   31
/* = AFE SCAN K1 AREA1 + 8 */
#define AFE_SCAN_K1_AREA1_ASSIST3   35
/* = AFE SCAN K2 AREA1 + 8 */
#define AFE_SCAN_K2_AREA1_ASSIST3   35
/* = AFE SCAN K1 AREA1 + 12 */
#define AFE_SCAN_K1_AREA1_ASSIST4   39
/* = AFE SCAN K2 AREA1 + 12 */
#define AFE_SCAN_K2_AREA1_ASSIST4   39
/* ¶t′ÎD£Õy */
#define _SECOND_AUTO_CLB_EN        0
#define CLB_RAWDATA_MAX            18384
#define CLB_RAWDATA_MIN            14384
*4. TP Tuning information
TUNING_STEP_INITIAL                      0
TUNING_STEP_TB_LINE_TOUCH_HANDLE         1
TUNING_STEP_BORDER_SHIFT_MANUAL_HANDLE   2
TUNING_STEP_BORDER_SPECIAL_HANDLE        3
TUNING_STEP_X_SHIFT_COMPENSATE           4
TUNING_STEP_LR_LINE_TOUCH_HANDLE         5
TUNING_STEP_FINISHED                     6
/* default = TUNING_STEP_FINISHED */
#define COORDINATE_TUNING_STEP           6
* (1) Set COORDINATE_TUNING_STEP to "TUNING_STEP_INITIAL"
*     Tuning mapping related parameters to make the center of X
#define X_CENTER_SHIFT                   0
* (2) Set COORDINATE_TUNING_STEP to "TUNING_STEP_TB_LINE_TOUCH_HANDLE"
*     make the Y coordinate in the top and bottom area more accurate.
* Enable this function will make the Y coordinate in the top and bottom area more accurate.
* Some parameters should be specified when enable this function
* 0: Disable line touch funciton
* 1: Enable line touch function for top and bottom border
#define _TB_LINE_TOUCH_HANDLE_EN         0
* Virtual channel panel order index in the top area(First two) and bottom area(Second two)
* These two virtual channel's line layout should be near the top/bottom area
* 0xFF means that do NOT need to be handled
*  {Top1, Top2, Bottom1, Bottom2}
#define TB_LINETOUCH_VIRTUAL_CH_IDX     {4, (TP_CHANNEL_NUM>>1)+4, TP_CHANNEL_NUM,(TP_CHANNEL_NUM + 1)}
