查看: 3669|回復(fù): 11
溫度傳感器,改了一天了,求大神幫助
ID:227857 發(fā)表于 2017-8-16 09:59 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
sbit datacon=P3^7;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
uchar code smgduan[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar data1[8];
void Delay1ms(uint y)
        uint x;
        for( ; y>0; y--)
                for(x=110; x>0; x--);
uchar Initial1()
    uint a,i;
        datacon=0;
        a=70;
        while(a--);
        datacon=1;
        i=0;
        while(datacon)        //等待DS18B20拉低總線
                Delay1ms(1);
                i++;
                if(i>5)//等待>5MS
                        return 0;//初始化失敗
        return 1;//初始化成功
void Writing1(uchar data_)
        uint i,j;
        for(i=0;i<8;i++)
                datacon=0;
                j++;
                j++;
                datacon=data_&0x01;
                data_>>=1;
                j=6;
                while(j--)                  ;
                datacon=1;
                data_>>=1;
uchar reading1(void)
        uint i,j;
        uchar data_,bit_;
                for(i=7;i>=0;i--)
                datacon=0;
                j++;
                datacon=1;
                j++;
                j++;
        bit_=datacon;
                data_=(data_ >> 1) | (bit_ << 7);
                j=4;
                while(j--);
        return data_;
void DS18B20initial1()
        Initial1() ;
        Delay1ms(1);
        Writing1(0xcc);
        Writing1(0x44);
        Delay1ms(100);
void DS18B20reading1()
        Initial1() ;
        Delay1ms(1);
        Writing1(0xcc);
        Writing1(0xbe);
int Ds18b20ReadTemp1()
        int temp = 0;
        uchar tmh, tml;
        DS18B20initial1();
        DS18B20reading1();
        tml = reading1();
        tmh = reading1();
        temp = tmh;
        temp <<= 8;
        temp |= tml;
        return temp;
void delay(uint i)
        while(i--);
void datadeal(int data2)
        float a;
        if(data2<0)
        data1[0]=0x40;
        data2=data2-1;
        data2=~data2;         //data2*=(-1);
        a=data2;
        data2=a*0.0625*100;
        data1[0]=0x00;
        a=data2;
        data2=a*0.0625*100;
        data1[1]=smgduan[data2/10000];
        data1[2]=smgduan[data2%10000/1000];
        data1[3]=smgduan[data2%1000/100]|0x80;
        data1[4]=smgduan[data2%100/10];
        data1[5]=smgduan[data2%10];
void DigDisplay()
        uchar i;
        for(i=0;i<6;i++)
                switch(i)
                        case(0):
                                LSA=0;LSB=0;LSC=0; break;
                        case(1):
                                LSA=1;LSB=0;LSC=0; break ;
                        case(2):
                                LSA=0;LSB=1;LSC=0; break;
                        case(3):
                                LSA=1;LSB=1;LSC=0; break;
                        case(4):
                                LSA=0;LSB=0;LSC=1; break;
                        case(5):
                                LSA=1;LSB=0;LSC=1; break;
                P0=data1[5-i];
                delay(100);
                P0=0x00;
{        while(1)
                datadeal(Ds18b20ReadTemp1())        ;
                DigDisplay();
ID:227864 發(fā)表于 2017-8-16 10:52 | 只看該作者
延時函數(shù)好像不對吧?
ID:82765 發(fā)表于 2017-8-16 10:54 | 只看該作者
提示: 作者被禁止或刪除 內(nèi)容自動屏蔽
ID:227857 發(fā)表于 2017-8-16 11:48 | 只看該作者
怪怪愛玩 發(fā)表于 2017-8-16 10:52
延時函數(shù)好像不對吧?
應(yīng)該是對的
無效樓層,該帖已經(jīng)被刪除
6#
ID:227857 發(fā)表于 2017-8-16 12:14 | 只看該作者
cjjcjj1 發(fā)表于 2017-8-16 10:54
你好!具體是什么現(xiàn)象?你要實現(xiàn)的總體功能是什么?可以加我
就是讓數(shù)碼管顯示溫度,但是數(shù)碼管就是不顯示
ID:190832 發(fā)表于 2017-8-16 12:50 | 只看該作者
在DigDisplay()函數(shù)中,P0=data[5-i];這句是錯的。應(yīng)該是P0=smgduan[data[i]];
ID:190832 發(fā)表于 2017-8-16 12:56 | 只看該作者
你的datadeal(int data2)和DigDisplay()函數(shù)根本不對,在好好看看怎么寫顯示函數(shù);應(yīng)該是把數(shù)據(jù)放到數(shù)組data,之后通過數(shù)碼管smgduan顯示數(shù)字。好好縷一縷吧。
ID:227857 發(fā)表于 2017-8-16 16:06 | 只看該作者
hange_v 發(fā)表于 2017-8-16 12:56
你的datadeal(int data2)和DigDisplay()函數(shù)根本不對,在好好看看怎么寫顯示函數(shù);應(yīng)該是把數(shù)據(jù)放到數(shù)組dat ...
這個是對的,例程就是這么寫的,
ID:190832 發(fā)表于 2017-8-16 16:45 | 只看該作者
糾結(jié)123 發(fā)表于 2017-8-16 16:06
這個是對的,例程就是這么寫的,
這是我以前的代碼,你看看,另外看看你的跳線帽插上了沒有。。。
#include<reg51.h>
#include<intrins.h>
#define nop() _nop_()
bit flag;
sbit SDA=P3^7;
sbit DA=P2^2;sbit DB=P2^3;sbit DC=P2^4;
void delay(ms)
        uchar i,j;
        for(i=0;i<ms;i++)
          for(j=0;j<110;j++);
uchar code table[]={
        0x7f,0x6f,0x77,0x7c,
        0x39,0x5e,0x79,0x71,0x80,0x40};
uchar initDS13B20()
        uchar i;
        SDA=0;i=70;
        while(i--);
        SDA=1;i=0;
        while(SDA)
                i++;
                delay(1);
                if(i>50)
                        return 0;
        return 1;
void DS13B20write(uchar com)
        uchar i,j;
        for(i=0;i<8;i++)
                SDA=0;j++;
                SDA=(com&0x01);
                j=6;while(j--);
                SDA=1;
                com=(com>>1);
uchar DS13B20read()
        uchar i,j,di=0,dat=0;
        for(i=0;i<8;i++)
                SDA=0;j++;
                SDA=1;j++;j++;
                di=SDA;
                dat=((dat>>1)|(di<<7));
                j=4;
                while(j--);
        return dat;
void change()
        initDS13B20();
        delay(1);
        DS13B20write(0xcc);
        DS13B20write(0x44);
void getvalue()
        initDS13B20();
        delay(1);
        DS13B20write(0xcc);
        DS13B20write(0xbe);
int read()
        uchar dal=0,dah=0;
        int dat=0;
        change();
        getvalue();
        dal=DS13B20read();
        dah=DS13B20read();
        dat=((dah<<8)|dal);
        return dat;
float changeC()
        int a;
        float value;
        a=read();
        if(a>=0)
            flag=1;
                value=a*0.0625;
                flag=0;
                value=(~(a-1))*0.625;
        return value;
void disp1(float num)
        uchar a,i,j;
        for(i=0;i<6;i++)
                switch(i)
            case 0:DA=0;DB=0;DC=0;a=(int)num/10;    break;
            case 1:DA=1;DB=0;DC=0;a=(int)num%10;    break;
            case 2:DA=0;DB=1;DC=0;a=16;             break;
                        case 3:DA=1;DB=1;DC=0;a=(int)(num*10)%10; break;
                        case 4:DA=0;DB=0;DC=1;a=(int)(num*100)%10;  break;
                        case 5:DA=1;DB=0;DC=1;a=(int)(num*1000)%10;   break;
                        case 6:DA=0;DB=1;DC=1;a=(int)(num*10000)%10;      break;
                P0=table[a];
                j=50;
                while(j--);
                P0=0x00;
void disp0(float num1)
        uchar a,i,j;
        float num;
        num=0-num1;
        for(i=0;i<7;i++)
                switch(i)
            case 0:DA=0;DB=0;DC=0;a=17;      break;
                        case 1:DA=1;DB=0;DC=0;a=(int)num/10;  break;
            case 2:DA=0;DB=1;DC=0;a=(int)num%10;break;
            case 3:DA=1;DB=1;DC=0;a=16;          break;
                        case 4:DA=0;DB=0;DC=1;a=(int)(num*10)%10; break;
                        case 5:DA=1;DB=0;DC=1;a=(int)(num*100)%10;  break;
                        case 6:DA=0;DB=1;DC=1;a=(int)(num*1000)%10;   break;
                        case 7:DA=1;DB=1;DC=1;a=(int)(num*10000)%10;      break;
                P0=table[a];
                j=50;
                while(j--);
                P0=0x00;
        float value;
                value=changeC();
                if(flag==1)
                  disp1(value);
                else disp0(value);
ID:123289 發(fā)表于 2017-8-16 20:53 | 只看該作者
多看傳感器手冊,理解了就好寫了。
ID:227857 發(fā)表于 2017-8-16 21:45 | 只看該作者
還是不對呀,我拔掉DS18B20后,數(shù)碼管沒有變化
ID:95277 發(fā)表于 2017-8-17 08:35 | 只看該作者
網(wǎng)上有實例,下個實例試試。
