查看: 3802|回復(fù): 0
76e716 Tiny板子 單片機資料手冊(共24頁)
ID:227695 發(fā)表于 2017-8-15 17:53 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
76e716單片機資料
TABLE OF CONTENTS
1.  SETUP NUVOTON KEILTM OCD DRIVER  ............................................................................................. 3
2.  INSTALL NUVOTON VIRTUAL COM DRIVER  ..................................................................................... 8
3.  CHECK DRIVER IS WORKING ........................................................................................................... 18
4.  DOCUMENT REVISION HISTORY  ...................................................................................................... 23
完整的pdf格式文檔51黑下載地址(共24頁):
N76E616_Nu-Tiny_Board_Quick_User_Guide_v1.00.pdf (1.73 MB, 下載次數(shù): 10)
