查看: 17401|回復: 33
stm32 vl53l0x激光測距程序
ID:227475 發表于 2017-8-14 00:54 | 顯示全部樓層 |閱讀模式
vl53l0x激光測距的stm32單片機源程序如下:
  1. #include "vl53l0.h"
  2. VL53L0X_Dev_t vl53l0x_dev;
  3. VL53L0X_DeviceInfo_t vl53l0x_dev_info;
  4. VL53L0X_RangingMeasurementData_t vl53l0x_data;
  5. VL53L0X_Error vl53l0x_status;
  6. /***************************************************************************************/
  7. void print_pal_error(VL53L0X_Error Status)
  8. {
  9.     char buf[VL53L0X_MAX_STRING_LENGTH];
  10.     VL53L0X_GetPalErrorString(Status, buf);  //得到錯誤碼與字符串
  11.     printf("API Status: %i : %s\n", Status, buf);
  12. }
  13. void print_range_status(VL53L0X_RangingMeasurementData_t* pdata)
  14. {
  15.     char buf[VL53L0X_MAX_STRING_LENGTH];
  16.     uint8_t RangeStatus;
  17.     // New Range Status: data is valid when pdata->RangeStatus = 0
  18.     RangeStatus = pdata->RangeStatus;
  19.     VL53L0X_GetRangeStatusString(RangeStatus, buf);
  20.    // printf("Range Status: %i : %s\n", RangeStatus, buf);
  21. }
  22. VL53L0X_Error vl53l0x_start_single_test(VL53L0X_Dev_t *pdev, \
  23.                             VL53L0X_RangingMeasurementData_t *pdata)
  24. {
  25.     VL53L0X_Error status = VL53L0X_ERROR_NONE;
  26.
  27.     if(vl53l0x_status != VL53L0X_ERROR_NONE)
  28.         return vl53l0x_status;
  29.     status = VL53L0X_PerformSingleRangingMeasurement(pdev, pdata);   //VL53L0X執行單一測量范圍
  30.     if(status != VL53L0X_ERROR_NONE){
  31.        // printf("error:Call of VL53L0X_PerformSingleRangingMeasurement\n");
  32.         return status;
  33.     }
  34.     print_range_status(pdata);
  35.     printf("%icm\n\n", (pdata->RangeMilliMeter)/10);
  36.     return status;
  37. }
  38. VL53L0X_Error vl53l0x_measure_init(VL53L0X_Dev_t *pMyDevice)
  39. {
  40.     VL53L0X_Error Status = VL53L0X_ERROR_NONE;
  41.     //FixPoint1616_t LimitCheckCurrent;
  42.     uint32_t refSpadCount;
  43.     uint8_t isApertureSpads;
  44.     uint8_t VhvSettings;
  45.     uint8_t PhaseCal;
  46.     // Device Initialization
  47.     Status = VL53L0X_StaticInit(pMyDevice);   //基本設備初始化
  48.     if(Status != VL53L0X_ERROR_NONE){         //判斷是否初始化成功 失敗打印錯誤信息
  49.         printf ("Call of VL53L0X_StaticInit\n");
  50.         print_pal_error(Status);
  51.         return Status;
  52.     }
  53.     // Device Initialization
  54.     Status = VL53L0X_PerformRefCalibration(pMyDevice, &VhvSettings, &PhaseCal);    //執行參考校準
  55.     if(Status != VL53L0X_ERROR_NONE){        //判斷是否校準成功
  56.         printf ("Call of VL53L0X_PerformRefCalibration\n");
  57.         print_pal_error(Status);
  58.         return Status;
  59.     }
  60.     // needed if a coverglass is used and no calibration has been performed
  61.     Status = VL53L0X_PerformRefSpadManagement(pMyDevice,&refSpadCount, &isApertureSpads);
  62.     if(Status != VL53L0X_ERROR_NONE){
  63.         printf ("Call of VL53L0X_PerformRefSpadManagement\n");
  64.         printf ("refSpadCount = %d, isApertureSpads = %d\n", refSpadCount, isApertureSpads);
  65.         print_pal_error(Status);
  66.         return Status;
  67.     }
  68.     // no need to do this when we use VL53L0X_PerformSingleRangingMeasurement  當我們使用VL53L0X_PerformSingleRangingMeasurement不需要
  69.     Status = VL53L0X_SetDeviceMode(pMyDevice, VL53L0X_DEVICEMODE_SINGLE_RANGING); // Setup in single ranging mode 設置單一測量模式
  70.     if(Status != VL53L0X_ERROR_NONE){
  71.         printf ("Call of VL53L0X_SetDeviceMode\n");
  72.         print_pal_error(Status);
  73.         return Status;
  74.     }
  75.     // Enable/Disable Sigma and Signal check
  76.     if(Status == VL53L0X_ERROR_NONE){
  77.         Status = VL53L0X_SetLimitCheckEnable(pMyDevice,  //啟用/禁用特定限制檢查
  78.                         VL53L0X_CHECKENABLE_SIGMA_FINAL_RANGE, 1);
  79.     }
  80.     if(Status == VL53L0X_ERROR_NONE){
  81.         Status = VL53L0X_SetLimitCheckEnable(pMyDevice,
  82.                         VL53L0X_CHECKENABLE_SIGNAL_RATE_FINAL_RANGE, 1);
  83.     }
  84.
  85.     if(Status == VL53L0X_ERROR_NONE){
  86.         Status = VL53L0X_SetLimitCheckValue(pMyDevice,
  87.                         VL53L0X_CHECKENABLE_SIGNAL_RATE_FINAL_RANGE,
  88.                         (FixPoint1616_t)(0.25*65536));
  89.         }
  90.     if(Status == VL53L0X_ERROR_NONE){
  91.         Status = VL53L0X_SetLimitCheckValue(pMyDevice,
  92.                         VL53L0X_CHECKENABLE_SIGMA_FINAL_RANGE,
  93.                         (FixPoint1616_t)(18*65536));
  94.     }
  95.     if(Status == VL53L0X_ERROR_NONE){
  96.         Status = VL53L0X_SetMeasurementTimingBudgetMicroSeconds(pMyDevice,   //設置微秒時間
  97.                         200000);
  98.     }
  99.     if(Status != VL53L0X_ERROR_NONE){
  100.         printf ("Sigma and Signal check error\n");
  101.         print_pal_error(Status);
  102.         return Status;
  103.     }
  104.     /*
  105.      *  Step  4 : Test ranging mode
  106.      */
  107.   /*  for(i=0;i<10;i++){
  108.             printf ("Call of VL53L0X_PerformSingleRangingMeasurement\n");
  109.             Status = VL53L0X_PerformSingleRangingMeasurement(pMyDevice,
  110.                             &vl53l0x_data);
  111.             print_pal_error(Status);
  112.             print_range_status(&vl53l0x_data);
  113.             VL53L0X_GetLimitCheckCurrent(pMyDevice,
  114.                             VL53L0X_CHECKENABLE_RANGE_IGNORE_THRESHOLD, &LimitCheckCurrent);
  115.             printf("RANGE IGNORE THRESHOLD: %f\n\n", (float)LimitCheckCurrent/65536.0);
  116.             if (Status != VL53L0X_ERROR_NONE) break;
  117.             printf("Measured distance: %i\n\n", vl53l0x_data.RangeMilliMeter);
  118.     }
  119. */
  120.     return Status;   //返回0
  121. }
  122. VL53L0X_Error vl53l0x_init(void)
  123. {
  124.     VL53L0X_Error Status = VL53L0X_ERROR_NONE;   //初始值賦值為0
  125.     VL53L0X_Dev_t *pMyDevice = &vl53l0x_dev;       //得到設備地址
  126.     pMyDevice->I2cDevAddr      = 0x52;            //iic地址
  127.     pMyDevice->comms_type      =  1;              //選擇IIC還是SPI    iic=1;SPI=0
  128.     pMyDevice->comms_speed_khz =  400;            //iic速率
  129.
  130.     VL53L0X_i2c_init();          //IIC配置
  131.     Status = VL53L0X_DataInit(pMyDevice); // Data initialization  //VL53L0X_DataInit:一次設備的初始化,初始化成功返回0
  132.     if(Status != VL53L0X_ERROR_NONE){     //判斷如果狀態不為0   打印錯誤信息
  133.         print_pal_error(Status);
  134.         return Status;        //  返回錯誤值 可通過此值DEBUG查找錯誤位置
  135.     }
  136.     Status = VL53L0X_GetDeviceInfo(pMyDevice, &vl53l0x_dev_info);   //讀取給定設備的設備信息
  137.     if(Status != VL53L0X_ERROR_NONE){
  138.         print_pal_error(Status);
  139.         return Status;
  140.     }
  141.     printf("VL53L0X_GetDeviceInfo:\n");
  142.     printf("Device Name : %s\n", vl53l0x_dev_info.Name);     //設備名
  143.     printf("Device Type : %s\n", vl53l0x_dev_info.Type);    //產品類型VL53L0X = 1, VL53L1 = 2
  144. ……………………
  145. …………限于本文篇幅 余下代碼請從51黑下載附件…………
vl53l0x_測距.rar (639.98 KB, 下載次數: 486)
參與人數 5黑幣 +69 收起 理由
xuesong7417 + 8 贊一個!
emmmmm + 5 很給力!
默認隱藏 + 1 很給力!我剛剛好需要,就拿來參考了
32818 + 5 贊一個!
ID:223540 發表于 2017-8-16 16:09 | 顯示全部樓層
感謝您的分享
ID:290110 發表于 2018-3-10 17:04 | 顯示全部樓層
感謝分享
ID:297594 發表于 2018-3-26 23:09 | 顯示全部樓層
感謝樓主分享 長見識啊 對得起這價格
ID:72988 發表于 2018-3-27 13:06 | 顯示全部樓層
感謝您的分享
ID:314389 發表于 2018-4-23 12:59 | 顯示全部樓層
感謝您的分享
ID:119803 發表于 2018-4-25 15:50 | 顯示全部樓層
謝謝分享 可惜要黑筆
ID:345678 發表于 2018-6-21 15:00 | 顯示全部樓層
guaishushu 發表于 2018-4-25 15:50
謝謝分享 可惜要黑筆
樓主使用的單片機的具體型號是多少呀,求告知
ID:356817 發表于 2018-7-10 09:13 | 顯示全部樓層
多謝樓主,很厲害
ID:267607 發表于 2018-7-12 13:17 | 顯示全部樓層
謝謝分享,樓主很棒
ID:312675 發表于 2018-8-2 10:28 | 顯示全部樓層
感謝分享
ID:371971 發表于 2018-8-8 18:45 | 顯示全部樓層
看完了有點不明所以
ID:394398 發表于 2018-9-6 15:01 | 顯示全部樓層
謝謝分享
ID:250090 發表于 2018-9-29 12:38 | 顯示全部樓層
        很給力!我剛剛好需要,就拿來參考了
ID:414444 發表于 2018-10-24 09:34 | 顯示全部樓層
正在找呢,謝謝您
ID:434041 發表于 2018-11-28 14:05 | 顯示全部樓層
非常不錯
ID:439402 發表于 2018-12-4 17:07 | 顯示全部樓層
終于找到了,感謝樓主
ID:439402 發表于 2018-12-4 17:09 | 顯示全部樓層
正在找呢,謝謝
ID:282138 發表于 2018-12-11 10:47 | 顯示全部樓層
感謝樓主
ID:455438 發表于 2018-12-28 16:27 | 顯示全部樓層
感謝感謝!!
ID:388992 發表于 2019-1-16 13:22 | 顯示全部樓層
最近也在找這方面的資料,感謝樓主分享!
ID:437392 發表于 2019-2-20 22:00 | 顯示全部樓層
挺好,值得大家學習
ID:45026 發表于 2019-2-24 19:52 | 顯示全部樓層
非常好,很好的學習資料,多謝分享!
ID:411805 發表于 2019-3-4 09:00 | 顯示全部樓層
感謝感謝!
ID:500798 發表于 2019-3-30 10:06 | 顯示全部樓層
想請問一下樓主和各位已經下載的大神,這個只需要接好IO口就可以直接使用嗎
ID:6906 發表于 2019-3-30 10:48 | 顯示全部樓層
這個測距的測量范圍是多少?測量精度又是多少?
ID:393856 發表于 2019-7-11 11:52 | 顯示全部樓層
感謝UP主!得以借鑒一下。
ID:597851 發表于 2019-8-8 16:43 | 顯示全部樓層
啦啦啦,我要代碼
ID:510572 發表于 2019-8-8 23:33 | 顯示全部樓層
想問問xshut和GPIO1怎么接,庫的代碼看不過來
ID:485354 發表于 2019-8-19 09:30 | 顯示全部樓層
感謝樓主的無私奉獻
ID:558527 發表于 2019-9-21 14:49 | 顯示全部樓層
感謝樓主的無私奉獻
ID:630593 發表于 2019-10-28 18:49 | 顯示全部樓層
很給力,正需要
ID:697669 發表于 2020-3-29 20:19 | 顯示全部樓層
感謝分享
ID:741590 發表于 2020-4-30 11:31 | 顯示全部樓層
感謝分享
