查看: 3273|回復(fù): 3
超聲波測距代碼,調(diào)了一下午都沒能正確顯示距離
ID:206424 發(fā)表于 2017-8-11 20:21 | 顯示全部樓層 |閱讀模式
這個是我剛剛寫的一個超聲波測距的代碼,麻煩大佬幫忙看看是哪出錯了啊,調(diào)了一下午都沒能正確顯示距離,若有大佬幫忙解決,小的定當(dāng)感激不盡
#include <reg52.h>
#define uint  unsigned int
int time;
int succeed_flag;
uchar timeL;
uchar timeH;
sbit Trig =P1^0;
sbit Echo =P3^2;
sbit rs   =P2^0;
sbit lcden=P2^2;
sbit rw   =P2^1;
uchar table[]={
0x30,0x31,0x32,0x33,0x34,0x35,
0x36,0x37,0x38,0x39,0x3a};
uchar code *table1[]={"x zhou:","y zhou:"};
void delay(uint z)
uint x,y;
  for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void delay_20us()
    uchar a ;
    for(a=0;a<100;a++);
void lcdwrdata(uchar dat)
rs=1;
lcden=1;
P0=dat;
delay(6);
lcden=0;
delay(6);
void lcdwrcom(uchar cdat)
    rs=0;
lcden=1;
    P0=cdat;
delay(6);
lcden=0;
delay(6);
void lcd_init()
lcdwrcom(0x38);
lcdwrcom(0x0c);
lcdwrcom(0x06);
lcdwrcom(0x01);
void display(uint temp)
    uchar ge,shi,bai;
    bai=temp/100;
    shi=(temp%100)/10;
    ge=temp%10;
    rw=0;
delay(200);
lcden=0;
lcd_init();
lcdwrcom(0x00|0x80);
    while(*table1[0]!='\0')
lcdwrdata(*table1[0]++);
delay(100);
lcdwrcom(0x00|0xc0);
while(*table1[1]!='\0')
lcdwrdata(*table1[1]++);
delay(100);
    lcdwrcom(0x08|0xc0);
    lcdwrdata(table[ge]);
    delay(1);
    lcdwrcom(0x09|0xc0);
    lcdwrdata(table[shi]);
    delay(1);
    lcdwrcom(0x0a|0xc0);
    lcdwrdata(table[bai]);
    delay(1);
    uint distance;
    Trig=0;
    EA=1;
    TMOD=0x10;
        EA=0;
        Trig=1;
        delay_20us();
        Trig=0;
        while(Echo==0);
        succeed_flag=0;
        EA=1;
        EX0=1;
        TH1=0;
        TL1=0;
        TF1=0;
        TR1=1;
        delay(20);
        TR1=0;
        EX0=0;
       if(succeed_flag==1)
          time=timeH*256+timeL;
          distance=time*0.0172;
      if(succeed_flag==0)
          distance=0;
       display(distance);
void exter()  interrupt 0
     EX0=0;
     timeH =TH1;
     timeL =TL1;
     succeed_flag=1;
void timer1() interrupt 3
         TH1=0;
         TL1=0;
ID:82765 發(fā)表于 2017-8-12 12:23 | 顯示全部樓層
提示: 作者被禁止或刪除 內(nèi)容自動屏蔽
ID:227559 發(fā)表于 2017-8-14 14:05 | 顯示全部樓層
建議使用US-100超聲波模塊,支持串口通信,非常好用
ID:203572 發(fā)表于 2017-8-16 11:26 | 顯示全部樓層
給你一個我們今年電做P題的超聲波測液位的程序,這個可以直接測出液位,我們模塊是用HC-SR04,你也可以用US-100直接把跳線帽抜了用電平觸發(fā)模式,因為能力有限不會用串口模式
#ifndef __CSBRABGE_H__
#define __CSBRABGE_H__
/*連接線圖:
| CSB-----51  | CSB-----51  | CSB-----51     |
| Trig-----P3.6 | Echo-----P3.7  | VCC--5v   GND |
/******************接線引腳定義**************************/
sbit csb_t=P3^6;
sbit csb_r=P3^7;
/******************測量范圍限制 *****************************/
#define MAX_AREA 25000
函 數(shù) 名:void delay_csb(uint t)
功    能:延時
說    明:
入口參數(shù):無
返 回 值:無
while(t--);
函 數(shù) 名:uint  CsbRange(void)
功    能:測距
說    明:占用了定時器0
入口參數(shù):無
返 回 值:返回S 測距結(jié)果
uint  CsbRange(void)
uint time,s;
TMOD=0x01;
TH0=0;
TL0=0;
csb_t=1;
delay_csb(10);
csb_t=0;
while(!csb_r);
TR0=1;
while(csb_r);
TR0=0;
time=TH0*256+TL0;
TH0=0;
TL0=0;
s=time*0.17;//測出的實際值
s=-1.1371*s + 562.62;//算出的液位值
return s;
#endif
