查看: 4474|回復: 2
單片機AD轉換教程和程序
單片機AD轉換例程,請不要傳閱,壓縮包里面有STC12C5A60S2單片機的教程與程序源碼
全部資料下載地址:
單片機實訓--AD轉換例程.rar (1.4 MB, 下載次數: 82)
STC12C5A60S2單片機AD轉換源程序如下:
  1. /*------------------------------------------------------------------*/
  2. /* --- STC MCU Limited ---------------------------------------------*/
  3. /* --- STC12C5Axx Series MCU A/D Conversion Demo -------------------*/
  4. /* If you want to use the program or the program referenced in the  */
  5. /* article, please specify in which data and procedures from STC    */
  6. /*------------------------------------------------------------------*/
  7. #include "reg51.h"
  8. #include "intrins.h"
  9. #define FOSC    11059200L
  10. #define BAUD    9600
  11. typedef unsigned char BYTE;
  12. typedef unsigned int WORD;
  13. /*Declare SFR associated with the ADC */
  14. sfr ADC_CONTR   =   0xBC;           //ADC control register
  15. sfr ADC_RES     =   0xBD;           //ADC high 8-bit result register
  16. sfr ADC_LOW2    =   0xBE;           //ADC low 2-bit result register
  17. sfr P1ASF       =   0x9D;           //P1 secondary function control register
  18. /*Define ADC operation const for ADC_CONTR*/
  19. #define ADC_POWER   0x80            //ADC power control bit
  20. #define ADC_FLAG    0x10            //ADC complete flag
  21. #define ADC_START   0x08            //ADC start control bit
  22. #define ADC_SPEEDLL 0x00            //420 clocks
  23. #define ADC_SPEEDL  0x20            //280 clocks
  24. #define ADC_SPEEDH  0x40            //140 clocks
  25. #define ADC_SPEEDHH 0x60            //70 clocks
  26. void InitUart();
  27. void InitADC();
  28. void SendData(BYTE dat);
  29. BYTE GetADCResult(BYTE ch);
  30. void Delay(WORD n);
  31. void ShowResult(BYTE ch);
  32. void main()
  33. {
  34.     InitUart();                     //Init UART, use to show ADC result
  35.     InitADC();                      //Init ADC sfr
  36.     while (1)
  37.     {
  38.         ShowResult(0);              //Show Channel0
  39.         ShowResult(1);              //Show Channel1
  40.         ShowResult(2);              //Show Channel2
  41.         ShowResult(3);              //Show Channel3
  42.         ShowResult(4);              //Show Channel4
  43.         ShowResult(5);              //Show Channel5
  44.         ShowResult(6);              //Show Channel6
  45.         ShowResult(7);              //Show Channel7
  46.     }
  47. }
  48. /*----------------------------
  49. Send ADC result to UART
  50. ----------------------------*/
  51. void ShowResult(BYTE ch)
  52. {
  53.     SendData(ch);                   //Show Channel NO.
  54.     SendData(GetADCResult(ch));     //Show ADC high 8-bit result
  55. //if you want show 10-bit result, uncomment next line
  56. //    SendData(ADC_LOW2);             //Show ADC low 2-bit result
  57. }
  58. /*----------------------------
  59. Get ADC result
  60. ----------------------------*/
  61. BYTE GetADCResult(BYTE ch)
  62. {
  63.     ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ch | ADC_START;
  64.     _nop_();                        //Must wait before inquiry
  65.     _nop_();
  66.     _nop_();
  67.     _nop_();
  68.     while (!(ADC_CONTR & ADC_FLAG));//Wait complete flag
  69.     ADC_CONTR &= ~ADC_FLAG;         //Close ADC
  70.     return ADC_RES;                 //Return ADC result
  71. }
  72. /*----------------------------
  73. Initial UART
  74. ----------------------------*/
  75. void InitUart()
  76. {
  77.     SCON = 0x5a;                    //8 bit data ,no parity bit
  78.     TMOD = 0x20;                    //T1 as 8-bit auto reload
  79.     TH1 = TL1 = -(FOSC/12/32/BAUD); //Set Uart baudrate
  80.     TR1 = 1;                        //T1 start running
  81. }
  82. /*----------------------------
  83. Initial ADC sfr
  84. ----------------------------*/
  85. void InitADC()
  86. {
  87.     P1ASF = 0xff;                   //Open 8 channels ADC function
  88.     ADC_RES = 0;                    //Clear previous result
  89.     ADC_CONTR = ADC_POWER | ADC_SPEEDLL;
  90.     Delay(2);                       //ADC power-on and delay
  91. }
  92. /*----------------------------
  93. Send one byte data to PC
  94. Input: dat (UART data)
  95. Output:-
  96. ----------------------------*/
  97. void SendData(BYTE dat)
  98. {
  99.     while (!TI);                    //Wait for the previous data is sent
  100.     TI = 0;                         //Clear TI flag
  101.     SBUF = dat;                     //Send current data
  102. }
  103. /*----------------------------
  104. Software delay function
  105. ----------------------------*/
  106. void Delay(WORD n)
  107. {
  108.     WORD x;
  109.     while (n--)
  110.     {
  111.         x = 5000;
  112.         while (x--);
  113.     }
  114. }
收藏收藏4 分享淘帖 頂 踩
ID:1064915 發表于 2024-1-8 11:48 | 只看該作者
這是第九章,其它章節的有嗎?
ID:884711 發表于 2024-5-5 09:36 | 只看該作者
路過學習,謝謝分享!
