查看: 1727|回復(fù): 0
關(guān)于12864lcd顯示屏
ID:226333 發(fā)表于 2017-8-9 23:11 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
#include "12864.h"
void Delay(__IO uint32_t nCount)
   for(; nCount != 0; nCount--);
void send_dat(unsigned char dat)
    unsigned char i;
        //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    for(i=0;i<8;i++)
                if((dat&0x80)==0x80) SID_1;
                if((dat&0x80)==0x00) SID_0;
        CLK_0;
                Delay(35);
        CLK_1;
                dat<<=1;
unsigned char get_byte()
     unsigned char i,temp1=0,temp2=0;
         //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
     for(i=0;i<8;i++)
           temp1=temp1<<1;
           CLK_0;
                   Delay(25);
           CLK_1;
                   Delay(20);
           CLK_0;
           if(GPIO_ReadOutputDataBit(GPIOE,GPIO_Pin_3)) temp1++;
     for(i=0;i<8;i++)
           temp2=temp2<<1;
           CLK_0;
                   Delay(25);
           CLK_1;
                   Delay(25);
           CLK_0;
           if(GPIO_ReadOutputDataBit(GPIOE,GPIO_Pin_3))  temp2++;
     return ((0xf0&temp1)+(0x0f&temp2));
void check_busy()
    do
        send_dat(0xfc);
    while((get_byte()&0x8000)==0x8000);
void send_cmd(unsigned char cmd)
    check_busy();
    send_dat(0xf8);    //
    send_dat(cmd&0xf0); //
    send_dat((cmd&0x0f)<<4); //
void write_char(unsigned char dat)
    check_busy();
    send_dat(0xfa);//rw=0;rs=1
    send_dat(dat&0xf0);
    send_dat((dat&0x0f)<<4);
void lcd_clear()        //清除顯示
    send_cmd(0x01);
void lcd_pos(unsigned char y_add , unsigned char x_add)
    switch(y_add)
        case 1:
        send_cmd(0X80|x_add);break;
        case 2:
        send_cmd(0X90|x_add);break;
        case 3:
        send_cmd(0X88|x_add);break;
        case 4:
        send_cmd(0X98|x_add);break;
        default:break;
void lcd_wstr(unsigned char y_add , unsigned char x_add , unsigned char *str)    //
    unsigned char i;
    lcd_pos(y_add , x_add);
    for(i=0;str[i]!='\0';i++)
        write_char(str[i]);
void write_figer(unsigned char y_add , unsigned char x_add , unsigned int figer)//在任何位置寫數(shù)字
    unsigned char d[5],i,j;
    d[4]=figer%10;
    d[3]=figer%100/10;
    d[2]=figer%1000/100;
    d[1]=figer%10000/1000;
    d[0]=figer/10000;
    for(i=0;i<5;i++)
        if(d[i]!=0)break;
    if(i==5)i--;
    if(i==4)send_dat(0x30);//數(shù)據(jù)裝完,準(zhǔn)備發(fā)送
    for(j=i;j<5;j++)
       send_dat(d[j]|0x30);//取得的數(shù)字加上0x30也即得到該數(shù)字的ASCII碼,再將該數(shù)字發(fā)送去顯示
void lcd_init()     //
    Delay(0xfff);
    send_cmd(0x30);
    send_cmd(0x0C);//0000,1100 整體顯示,游標(biāo)off,游標(biāo)位置off
    send_cmd(0x01);//0000,0001 清DDRAM
    send_cmd(0x02);//0000,0010 DDRAM地址歸位
    send_cmd(0x80);//1000,0000 設(shè)定DDRAM 7位地址000,0000到地址計數(shù)器A
/******************* (C) COPYRIGHT 2011 奮斗STM32 *****END OF FILE****/
