查看: 2229|回復: 1
LCD1602顯示直流電機速度并帶pwm調速....電機轉速不連貫求大佬們看看
ID:215224 發表于 2017-8-8 15:54 | 顯示全部樓層 |閱讀模式
if(speed>0)
                                                 gotoxy(1,1);
                                                 LCD_Write_String("V= ");
                                                 gotoxy(1,3);
                                                 LcdWriteData((speed/1000)%10+0x30);
                                                 gotoxy(1,4);
                                                 LcdWriteData((speed/100)%10+0x30);
                                                 gotoxy(1,5);
                                                 LcdWriteData((speed/10)%10+0x30);
                                                 gotoxy(1,6);
                                                 LcdWriteData(speed%10+0x30);
                                                 gotoxy(1,7);
                                                 LCD_Write_String("r");
                                                 gotoxy(1,8);
                                                 LCD_Write_String("/");
                                                 gotoxy(1,9);
                                                 LCD_Write_String("m");
                                                 gotoxy(1,10);
                                                 LCD_Write_String("i");
                                                 gotoxy(1,11);
                                                 LCD_Write_String("n");
                                                 interruptcounter=0;
ID:215224 發表于 2017-8-8 15:56 | 顯示全部樓層
if(speed>0)                            {                                                  gotoxy(1,1);                                                  LCD_Write_String("V= ");                                                  gotoxy(1,3);                                                  LcdWriteData((speed/1000)%10+0x30);                                                  gotoxy(1,4);                                                  LcdWriteData((speed/100)%10+0x30);                                                          gotoxy(1,5);                                                  LcdWriteData((speed/10)%10+0x30);                                                  gotoxy(1,6);                                                  LcdWriteData(speed%10+0x30);                                                  gotoxy(1,7);                                                  LCD_Write_String("r");                                                  gotoxy(1,8);                                                  LCD_Write_String("/");                                                  gotoxy(1,9);                                                  LCD_Write_String("m");                                                  gotoxy(1,10);                                                  LCD_Write_String("i");                                                  gotoxy(1,11);                                                  LCD_Write_String("n");                                                  interruptcounter=0;                                         }
