查看: 4335|回復(fù): 2
溫濕度仿真SHT11和1602顯示
SHT11溫濕度仿真,自己拿去用
流程圖:
單片機(jī)源程序如下:
  1. #include<reg51.h>
  2. #include <intrins.h>
  3. #include <math.h>
  4. #include <stdio.h>
  5. #define LCD_DB        P0
  6. sbit         LCD_RS=P2^0;
  7. sbit         LCD_RW=P2^1;
  8. sbit         LCD_E=P2^2;
  9. sbit         beep = P1^7;
  10. sbit         key1 = P3^0;
  11. sbit         key2 = P3^1;
  12. sbit                     key3 = P3^2;
  13. sbit                     key4 = P3^3;
  14. unsigned char Time;                  //用來存放定時(shí)時(shí)間
  15. unsigned char Second;
  16. unsigned char w;  //標(biāo)志位
  17. unsigned char wendumode = 0;
  18. unsigned char shidumode = 0;
  19. unsigned char  wenduCB = 40;
  20. unsigned char  shiduCB = 100;
  21. unsigned int wendu,shidu;
  22. /******定義函數(shù)****************/
  23. #define uchar unsigned char
  24. #define uint unsigned int
  25. void LCD_init(void);                          //初始化函數(shù)
  26. void LCD_write_command(uchar command);        //寫指令函數(shù)
  27. void LCD_write_data(uchar dat);               //寫數(shù)據(jù)函數(shù)
  28. void LCD_disp_char(uchar x,uchar y,uchar dat);//在某個(gè)屏幕位置上顯示一個(gè)字符,X(0-15),y(1-2)
  29. void LCD_disp_str(uchar x,uchar y,uchar *str); //LCD1602顯示字符串函數(shù)
  30. void delay_n10us(uint n);                     //延時(shí)函數(shù)
  31. void kcankey()
  32. {
  33.                 if(key1==0)
  34.                 {
  35.                   delay_n10us(1000);
  36.                         if(key1==0)
  37.                         {
  38.                           wendumode = 1;
  39.                                 shidumode = 0;
  40.                         }
  41.                 }
  42.                 if(key2==0)
  43.                 {
  44.                   delay_n10us(1000);
  45.                         if(key2==0)
  46.                         {
  47.                           wendumode = 0;
  48.                                 shidumode = 1;
  49.                         }
  50.                 }
  51.                 if(wendumode==1)
  52.                 {
  53.                   if(key3==0)
  54.                         {
  55.                           delay_n10us(1000);
  56.                                 if(key3==0)
  57.                                 {
  58.                                   wenduCB++;
  59.                                 }
  60.                         }
  61.                   if(key4==0)
  62.                         {
  63.                           delay_n10us(1000);
  64.                                 if(key4==0)
  65.                                 {
  66.                                   wenduCB--;
  67.                                 }
  68.                         }
  69.                 }
  70.                 if(shidumode==1)
  71.                 {
  72.                   if(key3==0)
  73.                         {
  74.                           delay_n10us(1000);
  75.                                 if(key3==0)
  76.                                 {
  77.                                   shiduCB++;
  78.                                 }
  79.                         }
  80.                   if(key4==0)
  81.                         {
  82.                           delay_n10us(1000);
  83.                                 if(key4==0)
  84.                                 {
  85.                                   shiduCB--;
  86.                                 }
  87.                         }
  88.                 }
  89.                 if(wendu>=wenduCB*10)
  90.                   {
  91.                                      beep = 1;
  92.                    }
  93.                 if(shidu>=shiduCB*10)
  94.                   {
  95.                                      beep = 1;
  96.                    }
  97.                 if(wendu<wenduCB*10&&shidu<shiduCB*10)
  98.                 {
  99.                  beep = 0;
  100.                 }
  101. }
  102. void LCD_init(void)
  103. {
  104.         delay_n10us(10);
  105.         LCD_write_command(0x38);//設(shè)置8位格式,2行,5x7
  106.         delay_n10us(10);  LCD_write_command(0x0c);//開顯示,關(guān)光標(biāo),不閃爍
  107.         delay_n10us(10);  LCD_write_command(0x06);//設(shè)定輸入方式,增量不移位
  108.         delay_n10us(10);  LCD_write_command(0x01);//清除屏幕顯示
  109.         delay_n10us(100);       //延時(shí)清屏,延時(shí)函數(shù),延時(shí)約n個(gè)10us
  110. }
  111. void LCD_write_command(uchar dat)
  112. {
  113.         delay_n10us(10);
  114.         LCD_RS=0;         //指令
  115.         LCD_RW=0;         //寫入
  116.         LCD_E=1;          //允許
  117.         LCD_DB=dat;  delay_n10us(10);  //實(shí)踐證明,我的LCD1602上,用for循環(huán)1次就能完成普通寫指令。
  118.         LCD_E=0;  delay_n10us(10);  //實(shí)踐證明,我的LCD1602上,用for循環(huán)1次就能完成普通寫指令。
  119. }
  120. void LCD_write_data(uchar dat)
  121. {
  122.         delay_n10us(10);
  123.         LCD_RS=1;          //數(shù)據(jù)
  124.         LCD_RW=0;                   //寫入
  125.         LCD_E=1;           //允許
  126.         LCD_DB=dat; delay_n10us(10);
  127.          LCD_E=0;  delay_n10us(10);
  128. }
  129. void LCD_disp_char(uchar x,uchar y,uchar dat)
  130. {
  131.         uchar address;
  132.         if(y==1)
  133.         address=0x80+x;
  134.         else
  135.         address=0xc0+x;
  136.         LCD_write_command(address);
  137.         LCD_write_data(dat);
  138. }
  139. void LCD_disp_str(uchar x,uchar y,uchar *str)
  140. {
  141.         uchar address;
  142.         if(y==1)
  143.         address=0x80+x;
  144.         else
  145.         address=0xc0+x;
  146.         LCD_write_command(address);
  147.         while(*str!='\0')
  148.                 {
  149.                 LCD_write_data(*str);
  150.                 str++;
  151.                 }
  152. }
  153. void delay_n10us(uint n)  //延時(shí)n個(gè)10us@12M晶振
  154. {
  155.         uint i;
  156.         for(i=n;i>0;i--)
  157.          {
  158.          nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
  159.          }
  160. }
  161. sbit SCK  = P2^6;      //定義通訊時(shí)鐘端口
  162. sbit DATA = P2^7;      //定義通訊數(shù)據(jù)端口
  163. typedef union
  164. { unsigned int i;      //定義了兩個(gè)共用體
  165.   float f;  } value;
  166.   enum {TEMP,HUMI};      //TEMP=0,HUMI=1
  167. #define noACK 0             //用于判斷是否結(jié)束通訊
  168. #define ACK   1             //結(jié)束數(shù)據(jù)傳輸                              //adr  command  r/w
  169. #define STATUS_REG_W 0x06   //000   0011    0
  170. #define STATUS_REG_R 0x07   //000   0011    1
  171. #define MEASURE_TEMP 0x03   //000   0001    1
  172. #define MEASURE_HUMI 0x05   //000   0010    1
  173. #define RESET        0x1e   //000   1111    0
  174. /****************定義函數(shù)****************/
  175. void s_transstart(void);               //啟動傳輸函數(shù)
  176. void s_connectionreset(void);          //連接復(fù)位函數(shù)
  177. char s_write_byte(unsigned char value);//DHT90寫函數(shù)
  178. char s_read_byte(unsigned char ack);   //DHT90讀函數(shù)
  179. char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode);//測量
  180. void calc_dht90(float *p_humidity ,float *p_temperature);//溫濕度補(bǔ)償
  181. void s_transstart(void)   // generates a transmission start
  182. {
  183.         DATA=1; SCK=0;                   //Initial state
  184.         _nop_();
  185.         SCK=1;
  186.         _nop_();
  187.         DATA=0;
  188.         _nop_();
  189.         SCK=0;
  190.         _nop_();_nop_();_nop_();
  191.         SCK=1;
  192.         _nop_();
  193.         DATA=1;
  194.          _nop_();
  195.          SCK=0;
  196. }
  197. void s_connectionreset(void)   // communication reset: DATA-line=1 and at least 9 SCK cycles followed by transstart
  198. {
  199.         unsigned char i;
  200.         DATA=1;
  201.         SCK=0;                    //Initial state
  202.         for(i=0;i<9;i++)                  //9 SCK cycles
  203.         {
  204.         SCK=1;
  205.         SCK=0;
  206.         }
  207.         s_transstart();                   //transmission start
  208. }
  209. char s_write_byte(unsigned char value)
  210. //----------------------------------------------------------------------------------
  211. // writes a byte on the Sensibus and checks the acknowledge
  212. {
  213.         unsigned char i,error=0;
  214.         for (i=0x80;i>0;i/=2)             //shift bit for masking
  215.         {
  216.         if (i & value) DATA=1;          //masking value with i , write to SENSI-BUS
  217.         else DATA=0;
  218.         SCK=1;                          //clk for SENSI-BUS
  219.         _nop_();_nop_();_nop_();        //pulswith approx. 3 us
  220.         SCK=0;
  221.         }
  222.         DATA=1;                           //release DATA-line
  223.         SCK=1;                            //clk #9 for ack
  224.         error=DATA;                       //check ack (DATA will be pulled down by DHT90),DATA在第9個(gè)上升沿將被DHT90自動下拉為低電平。
  225.         _nop_();_nop_();_nop_();
  226.         SCK=0;
  227.         DATA=1;                           //release DATA-line
  228.         return error;                     //error=1 in case of no acknowledge //返回:0成功,1失敗
  229. }
  230. char s_read_byte(unsigned char ack)    // reads a byte form the Sensibus and gives an acknowledge in case of "ack=1"
  231. {
  232.         unsigned char i,val=0;
  233.         DATA=1;                           //release DATA-line
  234.         for (i=0x80;i>0;i/=2)             //shift bit for masking
  235.         {
  236.         SCK=1;                          //clk for SENSI-BUS
  237.         if (DATA) val=(val | i);        //read bit
  238.         _nop_();_nop_();_nop_();        //pulswith approx. 3 us
  239.         SCK=0;
  240.         }
  241.         if(ack==1)
  242.         DATA=0;                 //in case of "ack==1" pull down DATA-Line
  243.         else DATA=1;                      //如果是校驗(yàn)(ack==0),讀取完后結(jié)束通訊
  244.         _nop_();_nop_();_nop_();          //pulswith approx. 3 us
  245.         SCK=1;                            //clk #9 for ack
  246.         _nop_();_nop_();_nop_();          //pulswith approx. 3 us
  247.         SCK=0;
  248.         _nop_();_nop_();_nop_();          //pulswith approx. 3 us
  249.         DATA=1;                           //release DATA-line
  250.         return val;
  251. }
  252. char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode)  // makes a measurement (humidity/temperature) with checksum
  253. {
  254.         unsigned error=0;
  255.         unsigned int i;
  256.         s_transstart();                   //transmission start
  257.         switch(mode){                     //send command to sensor
  258.         case TEMP  : error+=s_write_byte(MEASURE_TEMP); break;
  259.         case HUMI  : error+=s_write_byte(MEASURE_HUMI); break;      default     : break;
  260.         }
  261.         for (i=0;i<65535;i++)
  262.         if(DATA==0) break; //wait until sensor has finished the measurement
  263.         if(DATA) error+=1;                // or timeout (~2 sec.) is reached
  264.         *(p_value)  =s_read_byte(ACK);    //read the first byte (MSB)
  265.         *(p_value+1)=s_read_byte(ACK);    //read the second byte (LSB)
  266.         *p_checksum =s_read_byte(noACK);  //read checksum
  267.         return error;
  268. }
  269. void calc_dht90(float *p_humidity ,float *p_temperature)
  270. // calculates temperature [C] and humidity [%RH]
  271. // input :  humi [Ticks] (12 bit)
  272. //          temp [Ticks] (14 bit)
  273. // output:  humi [%RH]
  274. //          temp [C]
  275. { const float C1=-4.0;              // for 12 Bit
  276. const float C2=+0.0405;           // for 12 Bit
  277. const float C3=-0.0000028;        // for 12 Bit
  278. const float T1=+0.01;             // for 14 Bit @ 5V
  279. const float T2=+0.00008;           // for 14 Bit @ 5V
  280. float rh=*p_humidity;             // rh:      Humidity [Ticks] 12 Bit
  281. float t=*p_temperature;           // t:       Temperature [Ticks] 14 Bit
  282. float rh_lin;                     // rh_lin:  Humidity linear
  283. float rh_true;                    // rh_true: Temperature compensated humidity
  284. float t_C;                        // t_C   :  Temperature [C]
  285. t_C=t*0.01 - 40;                  //calc. temperature from ticks to [C]
  286. rh_lin=C3*rh*rh + C2*rh + C1;     //calc. humidity from ticks to [%RH]
  287. rh_true=(t_C-25)*(T1+T2*rh)+rh_lin;   //calc. temperature compensated humidity [%RH]
  288. if(rh_true>100)rh_true=100;       //cut if the value is outside of
  289. if(rh_true<0.1)rh_true=0.1;       //the physical possible range
  290. *p_temperature=t_C;               //return temperature [C]
  291. *p_humidity=rh_true;              //return humidity[%RH]
  292. }
  293. //*********主函數(shù)*****************
  294. void main(void)
  295. {
  296.         value humi_val,temp_val;
  297.         unsigned char error,checksum;
  298.         LCD_init();
  299.         s_connectionreset();
  300.   beep = 0;
  301.         LCD_disp_str(0,1,"TE       CB:");
  302.         LCD_disp_str(0,2,"RH       CB:");
  303. ……………………
  304. …………限于本文篇幅 余下代碼請從51黑下載附件…………
溫濕度仿真.zip (111.44 KB, 下載次數(shù): 201)
參與人數(shù) 1黑幣 +50 收起 理由
收藏收藏4 分享淘帖 頂 踩
ID:225105 發(fā)表于 2018-3-8 01:20 | 只看該作者
很不錯(cuò)啊,下載學(xué)習(xí)學(xué)習(xí)
ID:329860 發(fā)表于 2018-6-8 22:22 | 只看該作者
很好,寫論文用上了。
無效樓層,該帖已經(jīng)被刪除
