查看: 3712|回復: 0
stm32矩陣按鍵掃描代碼
ID:225232 發(fā)表于 2017-8-7 08:08 | 顯示全部樓層 |閱讀模式
  1. //直接將代碼貼出來了,就不發(fā)附件了,僅供參考
  2. u16 Get_KeyValue(void)//使用PF0~PF7
  3. {
  4.         GPIO_InitTypeDef GPIO_InitStructure;
  5.   u8 i=5,j=5;
  6.   u16 temp1,temp2;
  7.    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOF, ENABLE);
  8.   GPIO_DeInit(GPIOF);
  9.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;
  10.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  11.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  12.   GPIO_Init(GPIOF, &GPIO_InitStructure);
  13.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
  14.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  15.   GPIO_Init(GPIOF, &GPIO_InitStructure);
  16.   GPIO_ResetBits(GPIOF,GPIO_Pin_L);//掃描列值
  17.   if((GPIO_ReadInputData(GPIOF)&0x00f0)==0x00f0)
  18.     return 0;
  19.   else
  20.   {
  21.     Delay_nms(70);//按鍵消抖
  22.     if((GPIO_ReadInputData(GPIOF)&0x00f0)==0x00f0)
  23.       return 0;
  24.     else
  25.       temp1=GPIO_ReadInputData(GPIOF)&0x00f0;
  26.   }
  27.   switch(temp1)
  28.   {
  29.   case 0x00e0:j=0;break;
  30.   case 0x00d0:j=1;break;
  31.   case 0x00b0:j=2;break;
  32.   case 0x0070:j=3;break;
  33.   default:break;
  34.   }
  35.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
  36.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  37.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  38.   GPIO_Init(GPIOF, &GPIO_InitStructure);
  39.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;
  40.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  41.   GPIO_Init(GPIOF, &GPIO_InitStructure);
  42.   GPIO_ResetBits(GPIOF,GPIO_Pin_R);//掃描行值
  43.   if((GPIO_ReadInputData(GPIOF)&0x000f)==0x000f)
  44.     return 0;
  45.   else
  46.   {//這里不再延時再掃描,因為已經(jīng)確定了不是抖動才會進入本步操作
  47.     temp2=GPIO_ReadInputData(GPIOF)&0x000f;
  48.   }
  49.   switch(temp2)
  50.   {
  51.   case 0x000e:i=0;break;
  52.   case 0x000d:i=1;break;
  53.   case 0x000b:i=2;break;
  54.   case 0x0007:i=3;break;
  55.   default:break;
  56.   }
  57.   if((i==5)||(j==5))
  58.     return 0;
  59.   else
  60.     return (Key_Tab[i][j]);
  61. }
參與人數(shù) 1黑幣 +50 收起 理由
