* PWM輸出(可調(diào))程序
* Don.2017.7
#include <STC12C5A60S2.h>
#include <intrins.h>
typedef unsigned char uchar8;
sbit PWM0_ADD = P2 ^ 0;
sbit PWM0_CUT = P2 ^ 1;
sbit PWM1_ADD = P2 ^ 2;
sbit PWM1_CUT = P2 ^ 3;
void PWM0_OUT( )
CCON = 0x00;
//PCA控制器清零
CL = 0;
CH = 0;
//16位PAC計數(shù)器清零
TMOD = 0x42;
//定時器0工作在模式2(8位自動重裝)
TL0 = ;
TH0 = ;
//寫入初值
//計算: 初值 = (256 - 外部晶振頻率 / PCA時鐘源頻率)H
//PCA時鐘源頻率 = 256 * PWM頻率
AUXR = 0X80;
//T0工作在1T模式
TR0 = 1;
//T0開始工作
CMOD = 0x08;
//設(shè)置計數(shù)器時鐘源
//0x00:系統(tǒng)時鐘/12, 0x02:系統(tǒng)時鐘/2
//0x04: 定時器T0溢出脈沖, 0x06: P1.2引腳輸入的外部時鐘
//0x08:系統(tǒng)時鐘, 0x0a: 系統(tǒng)時鐘/4
//0x0c: 系統(tǒng)時鐘/6, 0x0e: 系統(tǒng)時鐘/8
//PWM波的頻率 = CMOD數(shù)值(10位)/256
CCAPM0 = 0x42;
//8位PWM P1.3輸出
//0x42:無中斷;0x53:下降沿產(chǎn)生中斷;
//0x63:上升沿產(chǎn)生中斷;0x73:跳變沿產(chǎn)生中斷
CCAP0L = 0xc0;
CCAP0H = 0xc0;
//占空比設(shè)置:數(shù)值 / 256 * 100%
//0xc0:占空比為25%,0x80:占空比為50%,0x40:占空比為75%
CR = 1;
void PWM1_OUT( )
CCON = 0x00;
//PCA控制器清零
CL = 0;
CH = 0;
//16位PAC計數(shù)器清零
CMOD = 0x08;
CCAPM1 = 0x42;
//8位PWM P1.3輸出
CCAP1L = 0xc0;
CCAP1H = 0xc0;
CR = 1;
void PWM0_Alter(uchar8 type0, uchar8 change0)
//type = 0減占空比,1增加占空比 change: 0x0c約5%,0x05約2%
if(type0 == 0)
if(CCAP0L < 0xe6) //<90%
CCAP0L += change0;
CCAP0H += change0;
if(CCAP0L > 0x19) //>10%
CCAP0L -= change0;
CCAP0H -= change0;
void PWM1_Alter(uchar8 type1, uchar8 change1)
//type1 = 0減占空比,1增加占空比 change1: 0x0c約5%,0x05約2%
if(type1 == 0)
if(CCAP1L < 0xe6) //<90%
CCAP1L += change1;
CCAP1H += change1;
if(CCAP1L > 0x19) //>10%
CCAP1L -= change1;
CCAP1H -= change1;
void PWM_Alter_Drive( )
if(PWM0_ADD == 0)
_nop_( );_nop_( );_nop_( );_nop_( );
//按鍵消抖
while(PWM0_ADD == 0);
//按鍵釋放才跳出執(zhí)行下一步
PWM0_Alter(1, 0x05);
if(PWM0_CUT == 0)
while(PWM0_CUT == 0);
PWM0_Alter(0, 0x05);
if(PWM1_ADD == 0)
//按鍵消抖
while(PWM1_ADD == 0);
//按鍵釋放才跳出執(zhí)行下一步
PWM1_Alter(1, 0x05);
if(PWM1_CUT == 0)
while(PWM1_CUT == 0);
PWM1_Alter(0, 0x05);
void main( )
P1M0 = 0x00;
P1M1 = 0x00;
P2M0 = 0x00;
P2M1 = 0x00;
//配置標(biāo)準(zhǔn)I/O口
PWM0_OUT( );
PWM1_OUT( );
PWM_Alter_Drive( );
