/*Include---------------------------*/
#include"stm32f10x_lib.h" //包含所有的頭文件
#include <stdio.h>
//----------------函數(shù)聲明--------------------
void Delay_MS(u16 dly);
void delay_us(u16 dly1);
void RCC_Configuration(void);
void GPIO_Configuration(void);
unsigned long Read_HX711(void);
void USART_Configuration(void);
int fputc(int ch,FILE *f);
int GetKey (void);
USART_InitTypeDef USART_InitStructure;
ErrorStatus HSEStartUpStatus;
* Function Name : main
* Description : Main program.
* Input : None
* Output : None
* Return : None
int main(void)
u32 weigh1;
float weigh2;
#ifdef DEBUG
debug();
#endif
//------------初始化------------
RCC_Configuration();
GPIO_Configuration();
USART_Configuration( );
Delay_MS(1000);
weigh2=Read_HX711();
weigh2=weigh2/83886.08;
weigh1=weigh2*2000;
GPIO_SetBits(GPIOA,GPIO_Pin_11);
printf("%d\n",weigh1);
* Function Name : Delay_Ms
* Description : delay 1 ms.
* Input : dly (ms)
* Output : None
* Return : None
u16 i,j;
for(i=0;i<dly;i++)
for(j=1000;j>0;j--);
u16 i;
for(i=dly1;i>0;i--);
* Description : Read weigh
* Input : None
* Output : None
* Return : None
unsigned long Read_HX711(void) //讀HX711芯片輸出的數(shù)據(jù)。
unsigned long val = 0;
unsigned char i = 0;
GPIO_SetBits(GPIOB,GPIO_Pin_11); //DOUT=1
GPIO_ResetBits(GPIOB,GPIO_Pin_12); //SCK=0
while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_11)); //等待DOUT=0
delay_us(1);
for(i=0;i<24;i++)
GPIO_SetBits(GPIOB,GPIO_Pin_12); //SCK=1
val=val<<1;
delay_us(1);
if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_11)) //DOUT=1
val++;
delay_us(1);
delay_us(1);
delay_us(1);
return val;
* Function Name : RCC_Configuration
* Description : Configures the different system clocks.
* Input : None
* Output : None
* Return : None
//----------使用外部RC晶振-----------
RCC_DeInit(); //初始化為缺省值
RCC_HSEConfig(RCC_HSE_ON); //使能外部的高速時鐘
while(RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET); //等待外部高速時鐘使能就緒
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
FLASH_SetLatency(FLASH_Latency_2);
RCC_HCLKConfig(RCC_SYSCLK_Div1); //HCLK = SYSCLK
RCC_PCLK2Config(RCC_HCLK_Div1); //PCLK2 = HCLK
RCC_PCLK1Config(RCC_HCLK_Div2); //PCLK1 = HCLK/2
RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9); //PLLCLK = 8MHZ * 9 =72MHZ
RCC_PLLCmd(ENABLE); //Enable PLLCLK
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); //Wait till PLLCLK is ready
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //Select PLL as system clock
while(RCC_GetSYSCLKSource()!=0x08); //Wait till PLL is used as system
clock source
//---------打開相應(yīng)外設(shè)時鐘--------------------
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE); //使能
APB2外設(shè)的GPIOA的時鐘
//開啟串口時鐘
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
* Function Name : GPIO_Configuration
* Description : 初始化GPIO外設(shè)
* Input : None
* Output : None
* Return : None
//CLK:PB5 CLR:PE11 Data:PE10
GPIO_InitTypeDef GPIO_InitStructure; //聲明一個結(jié)構(gòu)體變量
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15; //選擇PC.10(TXD) 和 PC.11
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //管腳頻率為50MHZ
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD; //輸出模式為推挽輸出
GPIO_Init(GPIOB,&GPIO_InitStructure); //初始化PB5
//配置USART1_Tx為復(fù)合推挽輸出
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
//配置 USART1_Rx 為浮空輸入
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //選擇PC.10(TXD) 和 PC.11
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空輸入
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度為50MHz
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOA,&GPIO_InitStructure); //初始化PB5
* Function Name : USART_Configuration
* Description : 設(shè)置串口USART1
* Input : ch,*f
* Output : None
* Return : None
//串口配置: 波特率 115200 數(shù)據(jù)位 8 停止位 1 奇偶位 NONE
USART_InitStructure.USART_BaudRate = 9600;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No ;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
//初始化串口
USART_Init(USART1, &USART_InitStructure);
//啟動串口
USART_Cmd(USART1, ENABLE);
* Function Name : fputc
* Description : 重定向這個C庫(stdio)printf函數(shù) 文件流——》串口USART1
* Input : ch,*f
* Output : None
* Return : None
int fputc(int ch, FILE *f)
USART_SendData(USART1, (unsigned char) ch);// USART1 可以換成 USART2 等
while (!(USART1->SR & USART_FLAG_TXE));
return (ch);
// 接收數(shù)據(jù)
int GetKey (void) {
while (!(USART1->SR & USART_FLAG_RXNE));
return ((int)(USART1->DR & 0x1FF));
