查看: 2512|回復: 0
基于stm32f01 控制4x4矩陣按鈕的程序(我試過沒問題,改引腳很方便)
ID:224556 發表于 2017-8-3 23:51 | 顯示全部樓層 |閱讀模式
#include "SysTick.h"  //系統延時
#include "stm32f10x.h"
#include "usart.h"
unsigned char temp;
////*********4x4矩陣引出8個引腳,分別接A_Pin0~A_Pin7**********///
void InitKey(void) //
        GPIO_InitTypeDef  GPIOStru;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
        GPIOStru.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
        GPIOStru.GPIO_Mode = GPIO_Mode_Out_PP;  //
        GPIOStru.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOA,&GPIOStru);
        GPIOStru.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
        GPIOStru.GPIO_Mode = GPIO_Mode_IPD;  //   上拉輸入
        GPIO_ResetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);//拉高
int key(void)  //
        int KeyVal=0;  //
        GPIO_Write(GPIOA,0x0001); //
        temp=GPIOA_IDR;
        temp=temp & 0x00f0;
        if(temp != 0x0000)
                delay_ms(6);
                if(temp != 0x0000)
                                temp=GPIOA_IDR;
                                temp=temp & 0x00f0;
                                switch(temp)                  //
                                        case 0x0010: KeyVal=15; break;
                                        case 0x0020: KeyVal=11; break;
                                        case 0x0040: KeyVal=7; break;
                                        case 0x0080: KeyVal=3; break;
                                while(GPIOA->IDR & 0x00f0 != 0x0000);
        GPIO_Write(GPIOA,(GPIOA->ODR & 0xfff0 | 0x2)); //
        if(GPIOA->IDR & 0x00f0 != 0x0000)
                delay_ms(5);
                        switch(GPIOA->IDR & 0x00f0)                  //
                                case 0x0010: KeyVal=14; break;
                                case 0x0020: KeyVal=10; break;
                                case 0x0040: KeyVal=6; break;
                                case 0x0080: KeyVal=2; break;
        GPIO_Write(GPIOA,(GPIOA->ODR & 0xfff0 | 0x4)); //
                delay_ms(5);
                                case 0x0010: KeyVal=13; break;
                                case 0x0020: KeyVal=9; break;
                                case 0x0040: KeyVal=5; break;
                                case 0x0080: KeyVal=1; break;
        GPIO_Write(GPIOA,(GPIOA->ODR & 0xfff0 | 0x8)); //
                delay_ms(5);
                                case 0x0010: KeyVal=12; break;
                                case 0x0020: KeyVal=8; break;
                                case 0x0040: KeyVal=4; break;
                                case 0x0080: KeyVal=0; break;
        return KeyVal;
int main()
   int a;
   a=key();
   switch(a)
  case 1: break;
  case 1: break;
  case 1: break;
  case 1: break;
  case 1: break;
  case 1: break;
  case 1: break;
  case 1: break;
  case 1: break;
