自己做的一個仿真的單片機開發板,有完整的試驗步驟和仿真工程文件提供
板子上帶擴展ROM空間(i^2c 24c02)、adc(數字電壓表)、dac(信號發生器)、矩陣按鍵(計算器),四個任務通過獨立按鍵進行切換
下面是計算器(矩陣鍵盤)部分的的單片機源程序
完整代碼和仿真工程文件請下載http://www.raoushi.com/bbs/dpj-91558-1.html
- #include <reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- sbit leden=P2^7;
- sbit rs=P2^6;
- sbit wr=P2^5;
- sbit key=P3^2;
- //sbit busy=P0^7;
- uchar i,j,num,num_1,temp;
- long a1,b, c;
- float a_c,b_c;
- uchar flag,fuhao;
- uchar code table[]={7,8,9,0,
- 4,5,6,0,
- 1,2,3,0};
- uchar code table1[]={7,8,9,0x2f-0x30,
- 4,5,6,0x2a-0x30,
- 1,2,3,0x2d-0x30,
- 0x01-0x30,0,0x3d-0x30,0x2b-0x30};
- void delay(uchar n)
- uchar i,j;
- for(i=n;i>0;i--)
- for(j=200;j>0;j--) ;
- void write(uint w)
- rs=0;
- wr=0;
- leden=0;
- P0=w;
- leden=1;
- delay(10);//check();
- leden=0;
- void write_data(uint q)
- rs=1;
- wr=0;
- leden=0;
- P0=q;
- leden=1;
- delay(10);
- leden=0;
- void init()
- num=1;
- leden=1;
- write(0x38);
- write(0x08);
- write(0x01);
- write(0x06);
- write(0x0f);
- num_1=0;
- i=0;j=0;a1=0;b=0;c=0;flag=0;fuhao=0;
- void keyscan()
- P1=0Xfe;
- if(P1!=0xfe)
- delay(10);
- if(P1!=0xfe)
- temp=P1&0xf0;
- switch(temp)
- case 0xe0:num=0;break;
- case 0xd0:num=1;break;
- case 0xb0:num=2;break;
- case 0x70:num=3;break;
- while(P1!=0xfe);
- if(num==0||num==2||num==1)
- if(j!=0)
- write(0x01);
- j=0;
- if(flag==0)
- a1=a1*10+table[num];
- else
- b=b*10+table[num];
- else
- flag=1;
- fuhao=4;//除號以按;
- i=table1[num];
- write_data(0x30+i);
- P1=0xfd;
- if(P1!=0xfd)
- delay(10);
- if(P1!=0xfd)
- temp=P1&0xf0;
- switch(temp)
- case 0xe0:num=4;break;
- case 0xd0:num=5;break;
- case 0xb0:num=6;break;
- case 0x70:num=7;break;
- while(P1!=0xfd);
- if(num==4||num==5||num==6)
- if(j!=0)
- write(0x01);
- j=0;
- if(flag==0)
- else
- else
- flag=1;
- fuhao=3;//乘號以按;
- i=table1[num];
- P1=0xfb;
- if(P1!=0xfb)
- delay(10);
- if(P1!=0xfb)
- temp=P1&0xf0;
- switch(temp)
- case 0xe0:num=8;break;
- case 0xd0:num=9;break;
- case 0xb0:num=10;break;
- case 0x70:num=11;break;
- while(P1!=0xfb);
- if(num==8||num==9||num==10)
- if(j!=0)
- write(0x01);
- j=0;
- if(flag==0)
- else
- else if(num==11)
- flag=1;
- fuhao=2;//jian號以按;
- i=table1[num];
- P1=0xf7;
- if(P1!=0xf7)
- delay(10);
- if(P1!=0xf7)
- temp=P1&0xf0;
- switch(temp)
- case 0xe0:num=12;break;
- case 0xd0:num=13;break;
- case 0xb0:num=14;break;
- case 0x70:num=15;break;
- while(P1!=0xf7);
- switch(num)
- case 12:{write(0x01);a1=0;b=0;flag=0;fuhao=0;}break;
- case 13:{
- if(flag==0)
- a1=a1*10;
- write_data(0x30);
- else if(flag==1)
- b=b*10;
- write_data(0x30);
- } break;
- case 14:{
- j=1;
- if(fuhao==1)
- write(0x80+0x4f);
- write(0x04);
- c=a1+b;
- while(c!=0)
- write_data(0x30+c%10);
- c=c/10;
- write_data(0x3d);
- a1=0;b=0;
- flag=0;
- fuhao=0;
- else if(fuhao==2)
- write(0x80+0x4f);
- write(0x04);
- if(a1-b>0)
- c=a1-b;
- else
- c=b-a1;
- while(c!=0)
- c=c/10;
- if(a1-b<0)
- write_data(0x2d);
- write_data(0x3d);
- a1=0;b=0;flag=0;
- fuhao=0;
- else if(fuhao==3)
- write(0x80+0x4f);
- write(0x04);
- c=a1*b;
- while(c!=0)
- c=c/10;
- write_data(0x3d);
- a1=0;
- b=0;
- flag=0;
- fuhao=0;
- else if(fuhao==4)
- write(0x80+0x4f);
- write(0x04);
- i=0;
- c=a1/b;
- while(c!=0)
- c=c/10;
- i++;
- if(i==3)
- write(0x2e);
- if(a1/b<=0)
- write_data(0x30);
- write_data(0x3d);
- a1=0;
- b=0;
- flag=0;
- fuhao=0;
- } break;
- case 15:
- write_data(0x30+table1[num]);
- flag=1;
- fuhao=1;
- } break;
- P1=0xf0;
- void jisuanqi()
- init();
- while(key)
- keyscan();
