#include "msp430f5529.h"
#define GPIO_MOTOR P1OUT
uchar code[8]={0x04,0x08,0x10,0x20,}; //反轉(zhuǎn)順序
uchar i=0;
void Delay(unsigned int t);
void Motor();
* 函 數(shù) 名 : main
* 函數(shù)功能 : 主函數(shù)
* 輸 入 : 無(wú)
* 輸 出 : 無(wú)
void IO_init()
P1DIR |=BIT2;
P1DIR |=BIT3;
P1DIR |=BIT4;
P1DIR |=BIT5;
P1OUT&=~BIT2;
P1OUT&=~BIT3;
P1OUT&=~BIT4;
P1OUT&=~BIT5;
void main(void)
WDTCTL = WDTPW + WDTHOLD;
TA0CCTL0=CCIE;
TA0CTL |=MC_1+TASSEL_2+TACLR+ID_3;
TA0CCR0=160;
IO_init();
_EINT();//開(kāi)啟總中斷
#pragma vector = TIMER0_A0_VECTOR
__interrupt void TIMER0(void)
GPIO_MOTOR = code[i]; //取數(shù)據(jù)
P1OUT^=BIT0;
if(i==3)
{i=0;}
i++;
評(píng)分
查看全部評(píng)分
