查看: 1793|回復: 0
計算器+1602
ID:222532 發表于 2017-7-28 16:14 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#include<stdio.h>
#include<intrins.h>
#define uchar  unsigned char
#define uint  unsigned int
sbit RS = P1^0;
sbit RW = P1^1;
sbit EN = P1^2;
sbit Busy = P0^7;
void delay(uint z)
   while(z--);
void BusyJiance(void)                 //忙檢測
  P0 = 0xFF;
  RS = 0;
  RW = 1;
  EN = 1;
  while(Busy);
  EN = 0;
void WriteLCD1602Command(uchar com)
            BusyJiance();
   P0 = com;
   RS = 0;
   RW = 0;
   EN = 1;
   delay(2);
   EN = 0;
void WriteLCD1602Dat(uchar dat)
      BusyJiance();
   P0 = dat;
   RS = 1;
   RW = 0;
   EN = 1;
   delay(2);
   EN = 0;
void LCD1602_Init(void)
  WriteLCD1602Command(0x38);
  WriteLCD1602Command(0x0c);
  WriteLCD1602Command(0x06);
  WriteLCD1602Command(0x01);
  //WriteLCD1602Command(0x08);
/*******顯示單個字符函數***********/
void LCD_Write_Char(uchar x,uchar y,uchar a)
   if (y == 0)
       WriteLCD1602Command(0x80 + x);
       WriteLCD1602Command(0xC0 + x);
   WriteLCD1602Dat(a);
/*******顯示字符串函數************/
void DisplayLCD1602(uchar x, uchar y, uchar *p)
  if(x == 0)
    WriteLCD1602Command(0x80 + y);
    WriteLCD1602Command(0xc0 + y);
  while(*p)
    WriteLCD1602Dat(*p);
    p++;
/*按鍵掃描函數,返回掃描鍵值*/
uchar KeyScan()  //鍵盤掃描函數,使用行列反轉掃描法
    uchar num1;
static uchar key_on =0;
P2=0x0f;
if(P2!=0x0f)
    if(key_on==0)
       key_on=1;
    num1=P2;
    num1 |= 0xf0;
    P2=num1;
    num1=P2;
    return(num1);
    key_on=0;
    return(0xff);
uchar KeyPro()
switch(KeyScan())
//    case 0x7e:return '+';break;//0 按下相應的鍵顯示相對應的碼值
//   case 0x7d:return '-';break;//1
//   case 0x7b:return '*';break;//2
//   case 0x77:return '/';break;//3
//   case 0xbe:return '3';break;//4
//   case 0xbd:return '6';break;//5
//   case 0xbb:return '9';break;//6
//   case 0xb7:return '=';break;//7
//   case 0xde:return '2';break;//8
//   case 0xdd:return '5';break;//9
//   case 0xdb:return '8';break;//a
//   case 0xd7:return '0';break;//b
//   case 0xee:return '1';break;//c
//   case 0xed:return '4';break;//d
//   case 0xeb:return '7';break;//e
//   case 0xe7:return '.';break;//f
//   default:return 0xff;break;
   case 0xe7:return '.';break;//0 按下相應的鍵顯示相對應的碼值
   case 0xeb:return '0';break;//1
   case 0xed:return '=';break;//2 .0=/
   case 0xee:return '/';break;//3
   case 0xd7:return '7';break;//4
   case 0xdb:return '8';break;//5 789*
   case 0xdd:return '9';break;//6
   case 0xde:return '*';break;//7
   case 0xb7:return '4';break;//8
   case 0xbb:return '5';break;//9 456-
   case 0xbd:return '6';break;//a
   case 0xbe:return '-';break;//b
   case 0x77:return '1';break;//c
   case 0x7b:return '2';break;//d 123+
   case 0x7d:return '3';break;//e
   case 0x7e:return '+';break;//f
  unsigned char num,i,sign;
  unsigned char temp[16];   //最大輸入16個 -
  bit firstflag;       //標志位
  float a=0,b=0;
  unsigned char s;
  LCD1602_Init();    //初始化液晶屏
  WriteLCD1602Command(0x01); //清屏
  while (1)            //主循環
   num=KeyPro();    //掃描鍵盤
   if(num != 0xff)    //如果掃描是按鍵有效值則進行處理
      if(i==0)      //輸入是第一個字符的時候需要清空,方便觀看
      if((num=='+')||(num=='-') || (num=='*')|| (num=='/') || (num=='='))//輸入符號表示輸入結束
            i=0;    //計數器復位
            if(firstflag==0)  //如果是輸入的第一個數據,賦值給a,并把標志位 置1,到下一個數據輸入時可以跳轉賦值給b
                sscanf(temp,"%f",&a);
                firstflag=1;
               else     //把第二個數據賦給 b
                   sscanf(temp,"%f",&b);
               for(s=0;s<16;s++) //賦值完成后把緩沖區清零,防止下次輸入影響結果
               temp[s]=0;
               LCD_Write_Char(0,1,num);
               if(num != '=')      //判斷當前符號位并做相應處理
               sign=num;         //如果不是等號記下標志位
                   firstflag=0;   //檢測到輸入=號,判斷上次讀入的符合
                   switch(sign)
         case '+':a=a+b;break;
         case '-':a=a-b;break;
         case '*':a=a*b;break;
         case '/':a=a/b;break;
         default:break;
                   sprintf(temp,"%g",a);    //輸出浮點型,無用的0不輸出
                   DisplayLCD1602(1,1,temp);//顯示到液晶屏
                   sign=0;a=b=0;            //用完后所有數據清零
                   temp[s]=0;
       else    //輸入的是數字并處理
        if(i<=16)
        if( (1==i) && (temp[0]=='0') )//如果第一個字符是0,判讀第二個字符(i不自加一)
            if(num=='.')  //如果是小數點則正常輸入,光標位置加1
                temp[1]='.';
                LCD_Write_Char(1,0,num);//輸出數據
                i++;
            } //這里沒有判斷連續按小數點,如0.0.0
             temp[0]=num;     //如果是1-9數字,說明0沒有用,則直接替換第一位0
             LCD_Write_Char(0,0,num);//輸出
             temp[i]=num;
             LCD_Write_Char(i,0,num);//輸出數據(顯示)
             i++;        //光標位置加1
       if(i==16)
          i=0;   //防止當按下17下的時候等待
收藏收藏 分享淘帖 頂1 踩
