查看: 9864|回復: 8
詳細LCD1602串行或者并行數據傳輸51單片機程序(自編)
單片機串行源程序如下:
  1. #include "reg52.h"
  2. #include <intrins.h>
  3.
  4. //LCD1602接口定義
  5. #define    LCD_DATA    P1  //P1口(P14~P17)與LCD高四位(D4~D7)對應相接
  6. sbit   LCD1602_RS=P1^2;        //數據指令
  7. sbit   LCD1602_EN=P1^3;        //使能
  8.
  9. //延時函數,12mhz 6t延遲時間10*255us
  10. void LCD_init(void);
  11. void LCD_en_write(void);
  12. void LCD_write_command(unsigned char command) ;
  13. void LCD_write_data(unsigned char Recdata);
  14. void LCD_set_xy (unsigned char x, unsigned char y);
  15. void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s);
  16. void LCD_write_char(unsigned char X,unsigned char Y,unsigned char Recdata);
  17. void delay_nus(unsigned int n);
  18. void delay_nms(unsigned int n);
  19.
  20. //以下函數用于輸出字符串和數字
  21. int LCD_PutNum(unsigned long num,int XS,int pos);
  22. int LCD_PutStr(unsigned char *DData,int pos);
  23.
  24. //-------------------------1us延時函數---------------------------------
  25. void delay_1us(void)
  26. {
  27.     _nop_();
  28. }
  29. //------------------------N us延時函數---------------------------------
  30. void delay_nus(unsigned int n)
  31. {
  32. unsigned int i=0;
  33. for (i=0;i<n;i++)
  34. delay_1us();
  35. }
  36.   //-----------------------1ms延時函數----------------------------------
  37. void delay_1ms(void)
  38. {
  39. unsigned int i;
  40. for (i=0;i<1140;i++);
  41. }
  42.   //-----------------------N ms延時函數---------------------------------
  43. void delay_nms(unsigned int n)
  44. {
  45. unsigned int i=0;
  46. for (i=0;i<n;i++)
  47. delay_1ms();
  48. }
  49.   //------------------------液晶初始化-----------------------------------
  50. void LCD_init(void)
  51. {
  52. LCD_write_command(0x28);
  53. delay_nus(40);
  54. LCD_write_command(0x28);
  55. delay_nus(40);
  56. LCD_write_command(0x28);
  57. delay_nus(40);
  58.
  59. LCD_en_write();
  60. delay_nus(40);
  61. LCD_write_command(0x28); //4位顯示
  62. LCD_write_command(0x0c); //顯示開
  63. LCD_write_command(0x01); //清屏
  64. delay_nms(2);
  65. }
  66.
  67.   //----------------------液晶使能函數-------------------------------------
  68. void LCD_en_write(void)
  69. {                       //EN由高電平跳變到低電平時液晶使能
  70. LCD1602_EN=1;
  71. delay_nus(1);
  72. LCD1602_EN=0;
  73. }
  74. //------------------------寫指令函數--------------------------------------
  75. void LCD_write_command(unsigned char command)
  76. {
  77. delay_nus(16);
  78. LCD1602_RS=0; //RS=0
  79. LCD_DATA &=0X0f; //清高四位
  80. LCD_DATA|=command&0xf0; //寫高四位
  81. LCD_en_write();
  82. command=command<<4; //低四位移到高四位
  83. LCD_DATA&=0x0f; //清高四位
  84. LCD_DATA|=command&0xf0; //寫低四位
  85. LCD_en_write();
  86. }
  87.
  88. //------------------------寫數據函數--------------------------------------
  89. void LCD_write_data(unsigned char Recdata)
  90. {
  91. delay_nus(16);
  92. LCD1602_RS=1; //RS=1
  93. LCD_DATA&=0X0f; //清高四位
  94. LCD_DATA|=Recdata&0xf0; //寫高四位
  95. LCD_en_write();
  96. Recdata=Recdata<<4; //低四位移到高四位
  97. LCD_DATA&=0X0f; //清高四位
  98. LCD_DATA|=Recdata&0xf0; //寫低四位
  99. LCD_en_write();
  100. }
  101.
  102. //-----------------------地址定位函數-------------------------------------
  103. void LCD_set_xy( unsigned char x, unsigned char y )
  104. {
  105.     unsigned char address;
  106.     if (y == 0) address = 0x80 + x;
  107.     else address = 0xc0 + x;
  108.     LCD_write_command(address);
  109. }
  110.
  111.
  112. //----------------------在某個地址處,寫一個字符----------------------------
  113. void LCD_write_char(unsigned char X,unsigned char Y,unsigned char Recdata) //列x=0~15,行y=0,1
  114. {
  115.     LCD_set_xy(X, Y); //寫地址
  116.     LCD_write_data(Recdata);
  117. }
  118. //----------------------------輸出字符串-------------------------------------
  119. int LCD_PutStr(unsigned char *DData,int pos)  //pos表示字符顯示位置,0~31
  120. {
  121.     unsigned char i;
  122.     if(pos==-1)
  123.     {
  124.         LCD_write_command(0x01); //清屏
  125.         delay_nms(2);
  126.         pos=0;
  127.     }
  128.     while((*DData)!='\0')
  129.     {
  130.         switch(*DData)
  131.         {
  132.             case '\n': //如果是\n,則換行
  133.             {
  134.                 if(pos<17)
  135.                 {
  136.                     for(i=pos;i<16;i++) LCD_write_char(i%16, i/16,' ');
  137.                     pos=16;
  138.                 }
  139.                 else
  140.                 {
  141.                     for(i=pos;i<32;i++) LCD_write_char(i%16, i/16,' ');
  142.                     pos=0;
  143.                 }
  144.                 break;
  145.             }
  146.
  147.             case '\b': //如果是\b,則退格
  148.             {
  149.                 if(pos>0) pos--;
  150.                 LCD_write_char(pos%16, pos/16, ' ');
  151.                 break;
  152.             }
  153.
  154.             default:
  155.             {
  156.                 if((*DData)<0x20)  //小于0x20的顯示不了?
  157.                 {
  158.                     *DData=' ';
  159.                 }
  160.
  161.                 LCD_write_char(pos%16, pos/16,*DData);
  162.                 pos++;
  163.                 break;
  164.             }
  165.         }
  166.         DData++;
  167.     }
  168.     return(pos);
  169. }
  170. //----------------------------輸出數字---------------------------------
  171. //這段程序寫法我的理解大致是這樣:num為去掉小數點之后的數字,XS為小數點
  172. //從左數第幾位,pos為顯示的位置
  173. //---------------------------------------------------------------------
  174. int LCD_PutNum(unsigned long num,int XS,int pos)
  175. {
  176.     unsigned long tmp=0;
  177.     unsigned char numbits=0; //總數字位數
  178.     if(pos==-1)
  179.     {
  180.         LCD_write_command(0x01);
  181.         delay_nms(2);
  182.         pos=0;
  183.     }
  184.
  185.     if(num==0)
  186.     {
  187.         LCD_write_char(pos%16, pos/16, '0');
  188.         pos++;
  189.     }
  190.     else
  191.     {
  192.         if(num<0)
  193.         {
  194.             LCD_write_char(pos%16, pos/16, '-');
  195. ……………………
  196. …………限于本文篇幅 余下代碼請從51黑下載附件…………
主函數還沒有寫,大家可以按自己寫需求寫,程序存在問題還很多,請多多指教,一起進步:
LCD1602.zip (61.29 KB, 下載次數: 101)
收藏收藏2 分享淘帖 頂 踩
ID:266711 發表于 2018-3-16 15:32 | 只看該作者
學到了很多,讓我受益很多謝謝
ID:442599 發表于 2019-3-7 18:47 | 只看該作者
沒有主函數啊
ID:398105 發表于 2019-3-9 10:59 | 只看該作者
謝謝分享
ID:770247 發表于 2020-12-9 14:06 | 只看該作者
請問串行的電路圖是什么樣子的啊?
ID:770247 發表于 2020-12-9 14:07 | 只看該作者
請問串行的電路圖是什么樣子的啊,下載了壓縮包只有程序
ID:328014 發表于 2020-12-9 16:18 | 只看該作者
zhenzhenyah 發表于 2020-12-9 14:07
看程序頂部有端口定義,按端口定義接線就可以了,如果以前沒有接過這種電路 最好去51hei先找一個電路圖,搜索"1602 4線"或者"1602 四線"這幾個字即可,有很多人分享http://www.raoushi.com/bbs/dpj-52853-1.html
http://www.raoushi.com/bbs/dpj-167284-1.html
ID:857626 發表于 2020-12-9 18:43 | 只看該作者
謝謝分享,寫的很詳細!!
ID:770247 發表于 2020-12-23 14:24 | 只看該作者
51hei團團 發表于 2020-12-9 16:18
看程序頂部有端口定義,按端口定義接線就可以了,如果以前沒有接過這種電路 最好去51hei先找一個電路圖,搜 ...
好的,謝謝
