- 名稱:矩陣鍵盤(pán)行列逐級(jí)掃描
- 編寫(xiě):szjcdz
- 日期:10.9
- 內(nèi)容:如計(jì)算器輸入數(shù)據(jù)形式相同 從右至左 使用行列掃描方法
- #include<reg52.h> //包含頭文件,一般情況不需要改動(dòng),頭文件包含特殊功能寄存器的定義
- #define DataPort P0 //定義數(shù)據(jù)端口 程序中遇到DataPort 則用P0 替換
- #define KeyPort P3
- sbit LATCH1=P2^6;//定義鎖存使能端口 段鎖存
- sbit LATCH2=P2^7;// 位鎖存
- unsigned char code DuanMa[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,
- 0x77,0x7c,0x39,0x5e,0x79,0x71};// 顯示段碼值0~F
- unsigned char code WeiMa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//分別對(duì)應(yīng)相應(yīng)的數(shù)碼管點(diǎn)亮,即位碼
- unsigned char TempData[8]; //存儲(chǔ)顯示值的全局變量
- void DelayUs2x(unsigned char t);//us級(jí)延時(shí)函數(shù)聲明
- void DelayMs(unsigned char t); //ms級(jí)延時(shí)
- void Display(unsigned char FirstBit,unsigned char Num);//數(shù)碼管顯示函數(shù)
- unsigned char KeyScan(void);//鍵盤(pán)掃描
- unsigned char KeyPro(void);
- void Init_Timer0(void);//定時(shí)器初始化
- 主函數(shù)
- void main (void)
- unsigned int num,i,j;
- //unsigned char temp[8];
- unsigned int temp1[]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15} ;
- unsigned int temp2[8];
- unsigned int k;
- unsigned long num1;
- Init_Timer0();
- while (1) //主循環(huán)
- num=KeyPro();
- if(num!=0xff)
- if(i<8)
- TempData[i]=DuanMa[num];
- temp2[i]=temp1[num];
- //for(j=0;j<=i;j++)
- //TempData[7-i+j]=temp[j];
- i++;
- if(i==9)//多出一個(gè)按鍵輸入為了清屏 原本應(yīng)該為8
- num1= temp2[0]*10000000+ temp2[1]*1000000+ temp2[2]*100000+ temp2[3]*10000+ temp2[4]*1000+ temp2[5]*100+ temp2[6]*10+ temp2[7];
- //unsigned int k;
- while(1)
- k++;
- if(k==10) //檢測(cè)當(dāng)前數(shù)值顯示了一小段時(shí)間后,需要顯示的數(shù)值 -1,實(shí)現(xiàn)數(shù)據(jù)顯示的變化
- k=0;
- if(num1>000000)//用于顯示0~9999
- num1--;
- //else
- //num1= temp2[0]*10000000+ temp2[1]*1000000+ temp2[2]*100000+ temp2[3]*10000+ temp2[4]*1000+ temp2[5]*100+ temp2[6]*10+ temp2[7];
- //i=0;
- // for(j=0;j<8;j++)//清屏
- //TempData[j]=0x00;
- TempData[0]=DuanMa[num1/10000000];//分解顯示信息,如要顯示68,則68/10=6 68%10=8
- TempData[1]=DuanMa[(num1%10000000)/1000000];
- TempData[2]=DuanMa[((num1%1000)%1000000)/100000];
- TempData[3]=DuanMa[(((num1%10000000)%1000000)%100000)/10000];
- TempData[4]=DuanMa[((((num1%10000000)%1000000)%100000)%10000)/1000];//分解顯示信息,如要顯示68,則68/10=6 68%10=8
- TempData[5]=DuanMa[(((((num1%10000000)%1000000)%100000)%10000)%1000)/100];
- TempData[6]=DuanMa[((((((num1%10000000)%1000000)%100000)%10000)%1000)%100)/10];
- TempData[7]=DuanMa[((((((num1%10000000)%1000000)%100000)%10000)%1000)%100)%10];
- Display(0,8);
- i=0;
- for(j=0;j<8;j++)//清屏
- TempData[j]=0x00;
- Display(0,8);
- //Display(0,8); //顯示全部8位
- //主循環(huán)中添加其他需要一直工作的程序
- uS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無(wú)返回值
- unsigned char 是定義無(wú)符號(hào)字符變量,其值的范圍是
- 0~255 這里使用晶振12M,精確延時(shí)請(qǐng)使用匯編,大致延時(shí)
- 長(zhǎng)度如下 T=tx2+5 uS
- while(--t);
- mS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無(wú)返回值
- while(t--)
- //大致延時(shí)1mS
- DelayUs2x(245);
- DelayUs2x(245);
- 顯示函數(shù),用于動(dòng)態(tài)掃描數(shù)碼管
- 輸入?yún)?shù) FirstBit 表示需要顯示的第一位,如賦值2表示從第三個(gè)數(shù)碼管開(kāi)始顯示
- 如輸入0表示從第一個(gè)顯示。
- Num表示需要顯示的位數(shù),如需要顯示99兩位數(shù)值則該值輸入2
- static unsigned char i=0;
- DataPort=0x00; //清空數(shù)據(jù),防止有交替重影
- LATCH1=1; //段鎖存
- LATCH1=0;
- DataPort=WeiMa[i+FirstBit]; //取位碼
- LATCH2=1; //位鎖存
- LATCH2=0;
- DataPort=TempData[i]; //取顯示數(shù)據(jù),段碼
- LATCH1=1; //段鎖存
- LATCH1=0;
- i++;
- if(i==Num)
- i=0;
- 定時(shí)器初始化子程序
- TMOD |= 0x01; //使用模式1,16位定時(shí)器,使用"|"符號(hào)可以在使用多個(gè)定時(shí)器時(shí)不受影響
- //TH0=0x00; //給定初值
- //TL0=0x00;
- EA=1; //總中斷打開(kāi)
- ET0=1; //定時(shí)器中斷打開(kāi)
- TR0=1; //定時(shí)器開(kāi)關(guān)打開(kāi)
- 定時(shí)器中斷子程序
- void Timer0_isr(void) interrupt 1
- TH0=(65536-2000)/256; //重新賦值 2ms
- TL0=(65536-2000)%256;
- Display(0,8); // 調(diào)用數(shù)碼管掃描
- 按鍵掃描函數(shù),返回掃描鍵值
- unsigned char KeyScan(void) //鍵盤(pán)掃描函數(shù),使用行列逐級(jí)掃描法
- unsigned char Val;
- KeyPort=0xf0;//高四位置高,低四位拉低
- if(KeyPort!=0xf0)//表示有按鍵按下
- DelayMs(10); //去抖
- if(KeyPort!=0xf0)
- { //表示有按鍵按下
- KeyPort=0xfe; //檢測(cè)第一行
- if(KeyPort!=0xfe)
- Val=KeyPort&0xf0;
- Val+=0x0e;
- while(KeyPort!=0xfe);
- DelayMs(10); //去抖
- return Val;
- KeyPort=0xfd; //檢測(cè)第二行
- if(KeyPort!=0xfd)
- Val=KeyPort&0xf0;
- Val+=0x0d;
- while(KeyPort!=0xfd);
- DelayMs(10); //去抖
- return Val;
- KeyPort=0xfb; //檢測(cè)第三行
- if(KeyPort!=0xfb)
- Val=KeyPort&0xf0;
- Val+=0x0b;
- while(KeyPort!=0xfb);
- DelayMs(10); //去抖
- return Val;
- KeyPort=0xf7; //檢測(cè)第四行
- if(KeyPort!=0xf7)
- Val=KeyPort&0xf0;
- Val+=0x07;
- while(KeyPort!=0xf7);
- DelayMs(10); //去抖
- return Val;
- return 0xff;
- 按鍵值處理函數(shù),返回掃鍵值
- switch(KeyScan())
- case 0x7e:return 0;break;//0 按下相應(yīng)的鍵顯示相對(duì)應(yīng)的碼值
- case 0x7d:return 1;break;//1
- case 0x7b:return 2;break;//2
- case 0x77:return 3;break;//3
- case 0xbe:return 4;break;//4
- case 0xbd:return 5;break;//5
- case 0xbb:return 6;break;//6
- case 0xb7:return 7;break;//7
- case 0xde:return 8;break;//8
- case 0xdd:return 9;break;//9
- case 0xdb:return 10;break;//a
- case 0xd7:return 11;break;//b
- case 0xee:return 12;break;//c
- case 0xed:return 13;break;//d
- case 0xeb:return 14;break;//e
- case 0xe7:return 15;break;//f
- default:return 0xff;break;
復(fù)制代碼 |
