查看: 1832|回復: 0
smart210裸板蜂鳴器程序
ID:221841 發表于 2017-7-23 20:05 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
C語言版
start.s:
.global _start
_start:
        bl main
loop:
        b loop
.end
main.c:
#define GPIOCON_0 *((volatile unsigned int  *)0xE02000A0)
#define GPIODAT_0 *((volatile unsigned char *)0xE02000A4)
void init_buzzer();
void on_buzzer();
void off_buzzer();
void delay();
void init_buzzer(){
        GPIOCON_0 &=~0xf;
        GPIOCON_0 |=0x1;
void on_buzzer(){
        GPIODAT_0 |=0x1;
void off_buzzer(){
        GPIODAT_0 &=~0x1;
void delay(){
        int i=1000000;
        while(i--);
int main(){
        init_buzzer();
        while(1){
        on_buzzer();
        delay();
        off_buzzer();
        delay();
        return 0;
Makefile:
buz.bin:start.o main.o
        arm-linux-ld -Ttext=0xd0020010 $^ -o temp
        arm-linux-objcopy -O binary temp $@
%.o:%.s
        arm-linux-gcc -c $< -o $@
%.o:%.c
clean:
        rm -f temp *.bin *.o
匯編版:
start.s
.global _start
_start:
        bl init_buzzer
loop:
        bl on_buzzer
        bl delay
        bl off_buzzer
        bl delay
        b loop
init_buzzer:
        ldr r0,=0xE02000A0
        ldr r1, [r0]
        bic r1, r1,#0xf
        orr r1,        r1,#0x1
        str r1, [r0]
        mov pc ,lr
on_buzzer:
        ldr r0,=0xE02000A4
        ldr r1, [r0]
        orr r1,        r1,#0x1
        str r1, [r0]
        mov pc ,lr
off_buzzer:
        ldr r0,=0xE02000A4
        ldr r1, [r0]
        bic r1,        r1,#0x1
        str r1, [r0]
        mov pc ,lr
delay:
        ldr r0,=0x100000
lable:
        subs r0,r0,#1
        bne lable
        mov pc ,lr
.end
Makefile:
buzer.bin:start.o
%.o:%.s
%.o:%.c
.PHONY: clean
clean:
        rm *.o *.bin temp
