查看: 2858|回復: 4
關于正弦波輸出的一點問題
ID:213326 發表于 2017-7-21 11:44 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
     這里有一個正弦波的產生程序,經編譯,無錯誤無警告,但是我不清楚如何用單片機管腳輸出,程序中定義的輸出管腳3.0并沒有在程序中用到,想麻煩各位幫我看一下,如何將波形輸出。程序如下:
#include<reg51.h>
#include<absacc.h>
#define DA_PORT XBYTE[0xf218]
sbit OUT=P3^0;
sbit ll=P3^1;
uchar code sin[256]={
                     0x80, 0x83, 0x86, 0x89, 0x8c, 0x8f, 0x92, 0x95,
      0x98, 0x9c, 0x9f, 0xa2, 0xa5, 0xa8, 0xab, 0xae,
      0xb0, 0xb3, 0xb6, 0xb9, 0xbc, 0xbf, 0xc1, 0xc4,
      0xc7, 0xc9, 0xcc, 0xce, 0xd1, 0xd3, 0xd5, 0xd8,
      0xda, 0xdc, 0xde, 0xe0, 0xe2, 0xe4, 0xe6, 0xe8,
      0xea, 0xec, 0xed, 0xef, 0xf0, 0xf2, 0xf3, 0xf4,
      0xf6, 0xf7, 0xf8, 0xf9, 0xfa, 0xfb, 0xfc, 0xfc,
      0xfd, 0xfe, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff,
      0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0xfe,
      0xfd, 0xfc, 0xfc, 0xfb, 0xfa, 0xf9, 0xf8, 0xf7,
      0xf6, 0xf5, 0xf3, 0xf2, 0xf0, 0xef, 0xed, 0xec,
      0xea, 0xe8, 0xe6, 0xe4, 0xe3, 0xe1, 0xde, 0xdc,
      0xda, 0xd8, 0xd6, 0xd3, 0xd1, 0xce, 0xcc, 0xc9,
      0xc7, 0xc4, 0xc1, 0xbf, 0xbc, 0xb9, 0xb6, 0xb4,
      0xb1, 0xae, 0xab, 0xa8, 0xa5, 0xa2, 0x9f, 0x9c,
      0x99, 0x96, 0x92, 0x8f, 0x8c, 0x89, 0x86, 0x83,
      0x80, 0x7d, 0x79, 0x76, 0x73, 0x70, 0x6d, 0x6a,
      0x67, 0x64, 0x61, 0x5e, 0x5b, 0x58, 0x55, 0x52,
      0x4f, 0x4c, 0x49, 0x46, 0x43, 0x41, 0x3e, 0x3b,
      0x39, 0x36, 0x33, 0x31, 0x2e, 0x2c, 0x2a, 0x27,
      0x25, 0x23, 0x21, 0x1f, 0x1d, 0x1b, 0x19, 0x17,
      0x15, 0x14, 0x12, 0x10, 0x0f, 0x0d, 0x0c, 0x0b,
      0x09, 0x08, 0x07, 0x06, 0x05, 0x04, 0x03, 0x03,
      0x02, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01,
      0x02, 0x03, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
      0x09, 0x0a, 0x0c, 0x0d, 0x0e, 0x10, 0x12, 0x13,
      0x15, 0x17, 0x18, 0x1a, 0x1c, 0x1e, 0x20, 0x23,
      0x25, 0x27, 0x29, 0x2c, 0x2e, 0x30, 0x33, 0x35,
      0x38, 0x3b, 0x3d, 0x40, 0x43, 0x46, 0x48, 0x4b,
      0x4e, 0x51, 0x54, 0x57, 0x5a, 0x5d, 0x60, 0x63,
      0x66, 0x69, 0x6c, 0x6f, 0x73, 0x76, 0x79, 0x7c,
uint step =1;
float a = 1.0;
void delay(uint m);
void sinwave();
ll=0;
  sinwave();
void delay(uint m)
uint i , j;
for(i = 0; i < m; i++)
  for(j = 0; j < 120; j++);
void sinwave()
uchar t;
uint i;
for(t= 0; t< 256; t= t+ 1)
  for(i = 0 ; i < step ; i++) DA_PORT = (sin[t]*a);
ID:220961 發表于 2017-7-21 20:27 | 只看該作者
你程序沒錯,但是外面要接一個數模轉換芯片
這一句就說明了呀
ID:34643 發表于 2017-7-22 06:30 | 只看該作者
論壇里單片機信號發生器比較多,你找一下參考他們的電路程序進行試驗。
ID:213326 發表于 2017-7-22 11:41 | 只看該作者
大灰狼愛喝湯 發表于 2017-7-21 20:27
您好,關于數模轉換這一塊正在學習,板載的芯片是xpt2046,您能提供一小段程序讓我參考一下嗎
ID:213326 發表于 2017-7-25 09:32 | 只看該作者
您好,板載芯片是xpt2046,您能幫我看一看嗎
