#include <reg52.h> //調(diào)用單片機(jī)頭文件
#define uchar unsigned char //無(wú)符號(hào)字符型 宏定義 變量范圍0~255
#define uint unsigned int //無(wú)符號(hào)整型 宏定義 變量范圍0~65535
//數(shù)碼管段選定義 0 1 2 3 4 5 6 7 8 9
uchar code smg_du[]={0x28,0xee,0x32,0xa7,0xe4,0xa1,0x51,0xea,0x80,0xa0,
0x60,0x25,0x39,0x26,0x31,0x71,0xff}; //斷碼
//數(shù)碼管位選定義
uchar code smg_we[]={0xef,0xdf,0xbf,0x7f};
uchar dis_smg[8] = {0x28,0xee,0x32,0xa2,0xe4,0x92,0x82,0xf8};
uchar smg_i = 3; //顯示數(shù)碼管的個(gè)位數(shù)
sbit dq = P2^4; //18b20 IO口的定義
sbit beep = P3^3;
bit flag_lj_en; //按鍵連加使能
bit flag_lj_3_en; //按鍵連3次連加后使能 加的數(shù)就越大了
uchar key_time,key_value; //用做連加的中間變量
bit key_500ms ;
sbit pwm = P2^3;
uchar f_pwm_l ; //越小越暗
uint temperature ; //
bit flag_300ms ;
uchar menu_1; //菜單設(shè)計(jì)的變量
uint t_high = 300,t_low = 100; //溫度上下限報(bào)警值
//數(shù)碼管位選定義
sbit smg_we1 = P3^7; //數(shù)碼管位選定義
sbit smg_we2 = P3^6;
sbit smg_we3 = P3^5;
sbit smg_we4 = P3^4;
uchar danwei;
/***********************1ms延時(shí)函數(shù)*****************************/
void delay_1ms(uint q)
uint i,j;
for(i=0;i<q;i++)
for(j=0;j<120;j++);
/***********************小延時(shí)函數(shù)*****************************/
void delay_uint(uint q)
while(q--);
/***********************數(shù)碼位選函數(shù)*****************************/
void smg_we_switch(uchar i)
switch(i)
case 0: smg_we1 = 0; smg_we2 = 1; smg_we3 = 1; smg_we4 = 1; break;
case 1: smg_we1 = 1; smg_we2 = 0; smg_we3 = 1; smg_we4 = 0; break;
case 2: smg_we1 = 1; smg_we2 = 1; smg_we3 = 0; smg_we4 = 1; break;
case 3: smg_we1 = 1; smg_we2 = 1; smg_we3 = 1; smg_we4 = 0; break;
/***********100us的延時(shí)函數(shù)***12M晶振**************/
void delay_100us(uchar z)
{ //12M
uchar x,y;
for(x=0;x<z;x++)
for(y=0;y<20;y++);
uchar flag_moshi;
sbit hw_P32=P3^2; //紅外遙控IO口的定義
bit flag_jiema_en = 0; //紅外解碼成功標(biāo)志位
uchar hw_table[4]; //紅外解碼數(shù)據(jù)緩沖區(qū)
/***********************數(shù)碼顯示函數(shù)*****************************/
void display()
static uchar i;
i++;
if(i >= smg_i)
i = 0;
P1 = 0xff; //消隱
smg_we_switch(i); //位選
P1 = dis_smg; //段選
/***********************18b20初始化函數(shù)*****************************/
void init_18b20()
bit q;
dq = 1; //把總線拿高
delay_uint(1); //15us
dq = 0; //給復(fù)位脈沖
delay_uint(80); //750us
dq = 1; //把總線拿高 等待
delay_uint(10); //110us
q = dq; //讀取18b20初始化信號(hào)
delay_uint(20); //200us
dq = 1; //把總線拿高 釋放總線
/*************寫18b20內(nèi)的數(shù)據(jù)***************/
void write_18b20(uchar dat)
uchar i;
for(i=0;i<8;i++)
{ //寫數(shù)據(jù)是低位開始
dq = 0; //把總線拿低寫時(shí)間隙開始
dq = dat & 0x01; //向18b20總線寫數(shù)據(jù)了
delay_uint(5); // 60us
dq = 1; //釋放總線
dat >>= 1;
/*************讀取18b20內(nèi)的數(shù)據(jù)***************/
uchar read_18b20()
uchar i,value;
for(i=0;i<8;i++)
dq = 0; //把總線拿低讀時(shí)間隙開始
value >>= 1; //讀數(shù)據(jù)是低位開始
dq = 1; //釋放總線
if(dq == 1) //開始讀寫數(shù)據(jù)
value |= 0x80;
delay_uint(5); //60us 讀一個(gè)時(shí)間隙最少要保持60us的時(shí)間
return value; //返回?cái)?shù)據(jù)
/*************讀取溫度的值 讀出來(lái)的是小數(shù)***************/
uint read_temp()
uint value;
uchar low; //在讀取溫度的時(shí)候如果中斷的太頻繁了,就應(yīng)該把中斷給關(guān)了,否則會(huì)影響到18b20的時(shí)序
init_18b20(); //初始化18b20
write_18b20(0xcc); //跳過(guò)64位ROM
write_18b20(0x44); //啟動(dòng)一次溫度轉(zhuǎn)換命令
delay_uint(50); //500us
write_18b20(0xbe); //發(fā)出讀取暫存器命令
low = read_18b20(); //讀溫度低字節(jié)
value = read_18b20(); //讀溫度高字節(jié)
value <<= 8; //把溫度的高位左移8位
value |= low; //把讀出的溫度低位放到value的低八位中
value *= 0.625; //轉(zhuǎn)換到溫度值 小數(shù)
return value; //返回讀出的溫度 帶小數(shù)
/*************定時(shí)器0初始化程序***************/
void time_init()
EA = 1; //開總中斷
TMOD = 0X11; //定時(shí)器0、定時(shí)器1工作方式1
ET0 = 1; //開定時(shí)器0中斷
TR0 = 1; //允許定時(shí)器0定時(shí)
ET1 = 1; //開定時(shí)器0中斷
/********************獨(dú)立按鍵程序*****************/
uchar key_can; //按鍵值
void key() //獨(dú)立按鍵程序
static uchar key_new;
key_can = 20; //按鍵值還原
P2 |= 0x07;
if((P2 & 0x07) != 0x07) //按鍵按下
if(key_500ms == 1) //連加
key_500ms = 0;
key_new = 1;
delay_1ms(1); //按鍵消抖動(dòng)
if(((P2 & 0x07) != 0x07) && (key_new == 1))
{ //確認(rèn)是按鍵按下
key_new = 0;
switch(P2 & 0x07)
case 0x06: key_can = 1; break; //得到k2鍵值
case 0x05: key_can = 2; break; //得到k3鍵值
case 0x01: key_can = 3; break; //得到k4鍵值
flag_lj_en = 1; //連加使能
if(key_new == 0)
key_new = 1;
flag_lj_en = 0; //關(guān)閉連加使能
flag_lj_3_en = 0; //關(guān)閉3秒后使能
key_value = 0; //清零
key_500ms = 0;
/****************按鍵處理數(shù)碼管顯示函數(shù)***************/
void key_with()
if(key_can == 1) //設(shè)置鍵
f_pwm_l = 30;
menu_1 ++;
flag_moshi = 0; //自動(dòng)模式
if(menu_1 >= 4)
menu_1 = 0;
smg_i = 3; //數(shù)碼管顯示3位
if(menu_1 == 1) //設(shè)置高溫報(bào)警
smg_i = 4; //數(shù)碼管顯示4位
if(key_can == 2)
if(flag_lj_3_en == 0)
t_high ++ ; //按鍵按下未松開自動(dòng)加三次
t_high += 10; //按鍵按下未松開自動(dòng)加三次之后每次自動(dòng)加10
if(t_high > 990)
t_high = 990;
if(key_can == 3)
t_high -- ; //按鍵按下未松開自動(dòng)減三次
t_high -= 10; //按鍵按下未松開自動(dòng)減三次之后每次自動(dòng)減10
if(t_high <= t_low)
t_high = t_low + 1;
dis_smg[0] = smg_du[t_high % 10]; //取小數(shù)顯示
dis_smg[1] = smg_du[t_high / 10 % 10] & 0xdf; //取個(gè)位顯示
dis_smg[2] = smg_du[t_high / 100 % 10] ; //取十位顯示
dis_smg[3] = 0x64; //H
if(menu_1 == 2) //設(shè)置低溫報(bào)警
if(key_can == 2)
t_low ++ ; //按鍵按下未松開自動(dòng)加三次
t_low += 10; //按鍵按下未松開自動(dòng)加三次之后每次自動(dòng)加10
if(t_low >= t_high)
t_low = t_high - 1;
if(key_can == 3)
t_low -- ; //按鍵按下未松開自動(dòng)減三次
t_low -= 10; //按鍵按下未松開自動(dòng)加三次之后每次自動(dòng)加10
if(t_low <= 10)
t_low = 10;
dis_smg[0] = smg_du[t_low % 10]; //取小數(shù)顯示
dis_smg[1] = smg_du[t_low / 10 % 10] & 0xdf; //取個(gè)位顯示
dis_smg[2] = smg_du[t_low / 100 % 10] ; //取十位顯示
dis_smg[3] = 0x3D; //L
if(menu_1 == 3)
flag_moshi = 1; //手動(dòng)模式
if(key_can == 2) //加檔
danwei ++;
if(danwei >= 4)
danwei = 0;
if(key_can == 3) //減檔
if(danwei == 0)
danwei = 4;
danwei --;
if(danwei == 0) //風(fēng)扇停止
TR1 = 0;
pwm = 1;
if(danwei == 1) //1檔
TR1 = 1;
f_pwm_l = 69;
if(danwei == 2) //2檔
TR1 = 1;
f_pwm_l = 30;
if(danwei == 3) //3檔
TR1 = 0;
pwm = 0;
dis_smg[0] = smg_du[temperature / 10 % 10]; //取小數(shù)顯示
dis_smg[1] = smg_du[temperature / 100 % 10]; //取個(gè)位顯示
dis_smg[2] = 0xf7;
dis_smg[3] = smg_du[danwei];
/****************風(fēng)扇控制函數(shù)***************/
void fengshan_kz()
if(temperature >= t_high) //風(fēng)扇全開
TR1 = 0;
pwm = 0;
else if((temperature < t_high) && (temperature >= t_low)) //風(fēng)扇緩慢
f_pwm_l = 60;
TR1 = 1;
else if(temperature < t_low) //關(guān)閉風(fēng)扇
TR1 = 0;
pwm = 1;
/***********外部中斷0初始化程序****************/
void init_int0() //外部中斷0初始化程序
EX0=1; //允許外部中斷0中斷
EA=1; //開總中斷
IT0 = 1; //外部中斷0負(fù)跳變中斷
/***********紅外遙控程序**************/
void hongwai_dis()
if(flag_jiema_en == 1)
flag_jiema_en = 0;
beep = 0 ;
delay_1ms(100);
beep = 1;
if(hw_table[2] == 0x47) //設(shè)置鍵
key_can = 1;
if(hw_table[2] == 0x40) //加鍵
key_can = 2;
if(hw_table[2] == 0x19) //減鍵
key_can = 3;
if(hw_table[2] == 0x16) //0檔
TR1 = 0;
pwm = 1;
danwei = 0;
if(hw_table[2] == 0x0c) //1檔
TR1 = 1;
f_pwm_l = 69;
danwei = 1;
if(hw_table[2] == 0x18) //2檔
TR1 = 1;
f_pwm_l = 30;
danwei = 2;
if(hw_table[2] == 0x5e) //3檔
TR1 = 0;
pwm = 0;
danwei = 3;
hw_table[2] = 0; //把數(shù)據(jù)清零
/****************主函數(shù)***************/
uchar value;
time_init(); f_pwm_l = 50;
init_int0(); //外部中斷0初始化程序
key(); //按鍵程序
hongwai_dis(); //紅外遙控程序
if(key_can < 10)
key_with(); //設(shè)置報(bào)警溫度
if(flag_300ms == 1) //300ms 處理一次溫度程序
flag_300ms = 0;
temperature = read_temp(); //先讀出溫度的值
value ++;
if(value >= 2)
beep = ~beep; //報(bào)警
beep = 1;
value = 0;
if(menu_1 == 0)
smg_i = 3;
dis_smg[0] = smg_du[temperature % 10]; //取溫度的小數(shù)顯示
dis_smg[1] = smg_du[temperature / 10 % 10] & 0xdf; //取溫度的個(gè)位顯示
dis_smg[2] = smg_du[temperature / 100 % 10] ; //取溫度的十位顯示
if(menu_1 == 3)
dis_smg[2] = 0xf7;
if(flag_moshi == 0)
fengshan_kz(); //風(fēng)扇控制函數(shù)
/*****************紅外解碼程序********************/
void int0() interrupt 0
unsigned char i,j;
delay_100us(40); //防止干擾
if(hw_P32 == 0)
{ //引導(dǎo)碼9+4.5=13.5ms
while(hw_P32 == 0); //等待9ms的低電平過(guò)完
delay_100us(27); //2.7ms
if(hw_P32 == 1) //引碼結(jié)束
delay_100us(20); //2.7ms+2.0ms=4.7ms 說(shuō)明4.5ms的高電平已經(jīng)過(guò)完 引導(dǎo)碼已經(jīng)結(jié)束
for(i=0;i<4;i++)
for(j=0;j<8;j++)
while(hw_P32 == 0); //等待過(guò)完0.56ms
delay_100us(9);
if(hw_P32 == 0) //數(shù)據(jù)0的時(shí)間=0.56+0.565=1.125ms
{ //數(shù)據(jù)1的時(shí)間=0.56+1.685=2.245ms
hw_table >>= 1; //低位在前
delay_100us(10); //0.9+1.0=1.9ms 延時(shí)讓1.685高電平的時(shí)間過(guò)完
hw_table |= 0x80; //1.9ms過(guò)完后 數(shù)據(jù)線已經(jīng)是低電平了
flag_jiema_en = 1; //紅外解碼成功
/*************定時(shí)器0中斷服務(wù)程序***************/
void time0_int() interrupt 1
static uchar value; //定時(shí)2ms中斷一次
TH0 = 0xf8;
TL0 = 0x30; //2ms
display(); //數(shù)碼管顯示函數(shù)
value++;
if(value >= 150)
value = 0;
flag_300ms = 1;
if(flag_lj_en == 1) //按下按鍵使能
key_time ++;
if(key_time >= 250) //500ms
key_time = 0;
key_500ms = 1; //500ms
key_value ++;
if(key_value > 3)
key_value = 10;
flag_lj_3_en = 1; //3次后1.5秒連加大些
/*******************定時(shí)器1用做單片機(jī)模擬PWM 調(diào)節(jié)***********************/
void Timer1() interrupt 3 //調(diào)用定時(shí)器1
static uchar value_l;
TH1=0xbe; // 定時(shí)10ms中斷一次
TL1=0x0c; //500us
if(pwm==1)
value_l+=1;
if(value_l > f_pwm_l) //高電平
value_l=0;
if(f_pwm_l != 0)
pwm=0;
value_l+=1;
if(value_l > 100 - f_pwm_l)
value_l=0;
pwm=1;
