查看: 15608|回復: 21
PMS7003 PM2.5測試儀,帶SHT20溫濕度 STM32源碼
ID:86777 發表于 2017-7-20 14:01 | 顯示全部樓層 |閱讀模式
由于網上的PM2.5測試儀質量不一,多數測試儀傳感器只能定性,而不能精確定量,而且價格還很貴,所以在家沒事做了個PM2.5測試儀,帶溫度顯示
配件:
1、空氣質量傳感器為攀騰第七代PMS7003傳感器
2、溫濕度傳感器為SHT20
3、單片機STM32F103C8T6
屏幕各界面顯示數據:空氣質量指數,PM2.5.PM0.3.PM0.5.PM1.0.PM2.5.PM10顆粒數,含量以及溫濕度
特別提示:代碼我只上傳了攀藤7003傳感器的官方測試代碼,希望各位電子愛好者勇于探索,功到才能自然成。
TB2ArtEiAqvpuFjSZFhXXaOgXXa_!!0-fleamarket.jpg_728x728.jpg TB2FJ_Kg3NlpuFjy0FfXXX3CpXa_!!0-fleamarket.jpg_728x728.jpg TB2MjdXXr_0UKFjy1XaXXbKfXXa_!!0-fleamarket.jpg_728x728.jpg TB2VW9gistnpuFjSZFvXXbcTpXa_!!0-fleamarket.jpg_728x728.jpg TB2z7DYgYJkpuFjy1zcXXa5FFXa_!!0-fleamarket.jpg_728x728.jpg
  1. #include "global_includes.h"
  2. #include <stdio.h>
  3. #include <string.h>
  4. #include "stm32f10x_rcc.h"
  5. typedef struct
  6. {
  7.         uint16_t Buffer_Len;
  8.         uint16_t PM1_0_CF;
  9.         uint16_t PM2_5_CF;
  10.         uint16_t PM10_CF;
  11.         uint16_t PM1_0;
  12.         uint16_t PM2_5;
  13.         uint16_t PM10;
  14.         uint16_t Count0_3nm;
  15.         uint16_t Count0_5nm;
  16.         uint16_t Count1_0nm;
  17.         uint16_t Count2_5nm;
  18.         uint16_t Count5_0nm;
  19.         uint16_t Count10nm;
  20. }PM_Sensor_DataStruct;
  21. typedef enum {RESET = 0, SET = !RESET} FlagStatus;
  22. typedef enum {ERROR = 0, SUCCESS = !ERROR} ErrorStatus;
  23. PM_Sensor_DataStruct        PM_Sensor_Data;
  24. uint8_t         PM_Sensor_RxBuffer[50];
  25. uint16_t    PM_Sensor_RxTimeOut = 0;
  26. uint16_t    PM_Sensor_RxCount = 0;
  27. FlagStatus  PM_Sensor_RxFinish = RESET;
  28. void SysTick_Handler(void)  // SYS timer interrupt function
  29. {
  30.         //OS_TimeMS ++;   //   ++1us for os timer
  31.         //==========================================================================
  32.         if(PM_Sensor_RxTimeOut != 0x00) // timeout for PM data receive
  33.         {
  34.                 PM_Sensor_RxTimeOut--;
  35.         }
  36.         else
  37.         {
  38.                 if((PM_Sensor_RxCount)&&(PM_Sensor_RxBuffer[0] == 'B')&&(PM_Sensor_RxBuffer[1] == 'M'))
  39.                 {
  40.                         PM_Sensor_RxCount = 0;
  41.                         PM_Sensor_RxFinish = SET;
  42.                         USART_ITConfig(USART1,USART_IT_RXNE,DISABLE);
  43.                 }
  44.                 else
  45.                 {
  46.                         PM_Sensor_RxCount = 0;
  47.                 }
  48.         }
  49. }
  50. void USART1_IRQHandler(void)  // USART1 interrupt
  51. {
  52.         static uint8_t                 USART1_ByteData = 0;
  53.         if (USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
  54.         {
  55.                 USART1_ByteData = USART_ReceiveData(USART1);
  56.                 if(PM_Sensor_RxFinish == RESET)
  57.                 {
  58.                         PM_Sensor_RxBuffer[PM_Sensor_RxCount++] = USART1_ByteData;
  59.                         PM_Sensor_RxTimeOut = 20;
  60.                 }
  61.         }
  62.         //============================================================================
  63.         if(USART_GetFlagStatus(USART1, USART_FLAG_ORE) != RESET)
  64.         {
  65.                 USART1_ByteData = USART_ReceiveData(USART1);
  66.                 USART_ClearFlag(USART1, USART_FLAG_ORE);
  67.         }
  68.         if(USART_GetFlagStatus(USART1, USART_FLAG_NE) != RESET)
  69.         {
  70.                 USART_ClearFlag(USART1, USART_FLAG_NE);
  71.         }
  72.         if(USART_GetFlagStatus(USART1, USART_FLAG_FE) != RESET)
  73.         {
  74.                 USART_ClearFlag(USART1, USART_FLAG_FE);
  75.         }
  76.         if(USART_GetFlagStatus(USART1, USART_FLAG_PE) != RESET)
  77.         {
  78.                 USART_ClearFlag(USART1, USART_FLAG_PE);
  79.         }
  80. }
  81. //=============================================================================
  82. //PM_USART1_Configuartion  USART1 configuration
  83. //=============================================================================
  84. void PM_USART1_Configuartion(void)
  85. {
  86.           USART_InitTypeDef USART_InitStructure;
  87.           GPIO_InitTypeDef  GPIO_InitStructure;
  88.
  89.         RCC_APB2PeriphClockCmd(        RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOA |
  90.                                                         RCC_APB2Periph_GPIOC, ENABLE);
  91.
  92.           RCC_APB2PeriphClockCmd( RCC_APB2Periph_USART1, ENABLE);
  93.
  94.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  95.
  96.
  97.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  98.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                //
  99.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  100.
  101.
  102.         /* PA9 USART1_Tx */
  103.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  104.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                        //推挽輸出-TX
  105.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  106.         /* PA10 USART1_Rx */
  107.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  108.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;        //浮空輸入-RX
  109.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  110.           USART_InitStructure.USART_BaudRate             = 9600;                                                //波特率
  111.           USART_InitStructure.USART_WordLength           = USART_WordLength_8b;                   //設置數據長度為8bit
  112.           USART_InitStructure.USART_StopBits             = USART_StopBits_1;                      //停止位為1
  113.           USART_InitStructure.USART_Parity               = USART_Parity_No;                       //無校驗位
  114.           USART_InitStructure.USART_HardwareFlowControl  = USART_HardwareFlowControl_None;//數據流控制為none
  115.           USART_InitStructure.USART_Mode                 = USART_Mode_Rx | USART_Mode_Tx; //接收和發送模式都打開
  116.           USART_Init(USART1, &USART_InitStructure);                                                 //初始化串口1
  117.           USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);                                         // 接收接收中斷
  118.         USART_ITConfig(USART1, USART_IT_ERR | USART_IT_PE, ENABLE);
  119.           /* Enable the USART1 */
  120.           USART_Cmd(USART1, ENABLE);        //使能USART1
  121. }
  122. //=============================================================================
  123. //Check_PMSensor_DataValid    //
  124. //=============================================================================
  125. ErrorStatus        Check_PMSensor_DataValid(void)
  126. {
  127.         uint16_t         Cal_CheckSum;
  128.         uint16_t         Buffer_CheckSum;
  129.         uint16_t         Buffer_Len;
  130.         uint8_t         i;
  131.         ErrorStatus Result = ERROR;
  132.         if((PM_Sensor_RxBuffer[0] == 'B')&&(PM_Sensor_RxBuffer[1] == 'M'))
  133.         {
  134.                 Buffer_Len = (uint16_t)((PM_Sensor_RxBuffer[2] << 8) | PM_Sensor_RxBuffer[3]);
  135.                 Buffer_CheckSum = (uint16_t)((PM_Sensor_RxBuffer[Buffer_Len + 2] << 8) | PM_Sensor_RxBuffer[Buffer_Len + 3]);
  136.                 Cal_CheckSum = 0;
  137.                 for(i=0;i<(Buffer_Len + 2);i++)
  138.                 {
  139.                         Cal_CheckSum += PM_Sensor_RxBuffer[i];
  140.                 }
  141.                 if(Cal_CheckSum == Buffer_CheckSum)
  142.                         Result = SUCCESS;
  143.         }
  144.         return Result;
  145. }
  146. //=============================================================================
  147. //PMSensor_DataReflash    //
  148. //=============================================================================
  149. void PMSensor_DataReflash(void)
  150. {
  151.         uint16_t Buffer_Len;
  152.         memset(&PM_Sensor_Data,0,(sizeof(PM_Sensor_Data) - 2)); //PM_Sensor_Data.PM2_5_Old should not set to zero
  153.
  154.         Buffer_Len = (uint16_t)((PM_Sensor_RxBuffer[2] << 8) | PM_Sensor_RxBuffer[3]);
  155.         if(Buffer_Len == 28)   //PMS1003/5003
  156.         {
  157.                 PM_Sensor_Data.Buffer_Len = 28;
  158.                 PM_Sensor_Data.PM1_0_CF = (uint16_t)((PM_Sensor_RxBuffer[4]<<8) | PM_Sensor_RxBuffer[5]);
  159.                 PM_Sensor_Data.PM2_5_CF = (uint16_t)((PM_Sensor_RxBuffer[6]<<8) | PM_Sensor_RxBuffer[7]);
  160.                 PM_Sensor_Data.PM10_CF         = (uint16_t)((PM_Sensor_RxBuffer[8]<<8) | PM_Sensor_RxBuffer[9]);
  161.                 PM_Sensor_Data.PM1_0         = (uint16_t)((PM_Sensor_RxBuffer[10]<<8) | PM_Sensor_RxBuffer[11]);
  162.                 PM_Sensor_Data.PM2_5         = (uint16_t)((PM_Sensor_RxBuffer[12]<<8) | PM_Sensor_RxBuffer[13]);
  163.                 PM_Sensor_Data.PM10         = (uint16_t)((PM_Sensor_RxBuffer[14]<<8) | PM_Sensor_RxBuffer[15]);
  164.                 PM_Sensor_Data.Count0_3nm = (uint16_t)((PM_Sensor_RxBuffer[16]<<8) | PM_Sensor_RxBuffer[17]);
  165.                 PM_Sensor_Data.Count0_5nm = (uint16_t)((PM_Sensor_RxBuffer[18]<<8) | PM_Sensor_RxBuffer[19]);
  166.                 PM_Sensor_Data.Count1_0nm = (uint16_t)((PM_Sensor_RxBuffer[20]<<8) | PM_Sensor_RxBuffer[21]);
  167.                 PM_Sensor_Data.Count2_5nm = (uint16_t)((PM_Sensor_RxBuffer[22]<<8) | PM_Sensor_RxBuffer[23]);
  168.                 PM_Sensor_Data.Count5_0nm = (uint16_t)((PM_Sensor_RxBuffer[24]<<8) | PM_Sensor_RxBuffer[25]);
  169.                 PM_Sensor_Data.Count10nm = (uint16_t)((PM_Sensor_RxBuffer[26]<<8) | PM_Sensor_RxBuffer[27]);
  170.
  171.         }
  172.         else if(Buffer_Len == 20)// PMS3003
  173.         {
  174.                 PM_Sensor_Data.Buffer_Len = 20;
  175.                 PM_Sensor_Data.PM1_0_CF = (uint16_t)((PM_Sensor_RxBuffer[4]<<8) | PM_Sensor_RxBuffer[5]);
  176.                 PM_Sensor_Data.PM2_5_CF = (uint16_t)((PM_Sensor_RxBuffer[6]<<8) | PM_Sensor_RxBuffer[7]);
  177.                 PM_Sensor_Data.PM10_CF         = (uint16_t)((PM_Sensor_RxBuffer[8]<<8) | PM_Sensor_RxBuffer[9]);
  178.                 PM_Sensor_Data.PM1_0         = (uint16_t)((PM_Sensor_RxBuffer[10]<<8) | PM_Sensor_RxBuffer[11]);
  179.                 PM_Sensor_Data.PM2_5         = (uint16_t)((PM_Sensor_RxBuffer[12]<<8) | PM_Sensor_RxBuffer[13]);
  180.                 PM_Sensor_Data.PM10         = (uint16_t)((PM_Sensor_RxBuffer[14]<<8) | PM_Sensor_RxBuffer[15]);
  181.                 PM_Sensor_Data.Count0_3nm = 0;
  182.                 PM_Sensor_Data.Count0_5nm = 0;
  183.                 PM_Sensor_Data.Count1_0nm = 0;
  184.                 PM_Sensor_Data.Count2_5nm = 0;
  185.                 PM_Sensor_Data.Count5_0nm = 0;
  186.                 PM_Sensor_Data.Count10nm = 0;
  187.         }
  188. }
  189. int main(void)
  190. {
  191.         /*!< At this stage the microcontroller clock setting is already configured,
  192.                 this is done through SystemInit() function which is called from startup
  193.                 file (startup_stm32f10x_xx.s) before to branch to application main.
  194.                 To reconfigure the default setting of SystemInit() function, refer to
  195.                 system_stm32f10x.c file
  196.         */
  197.         SetSysClockInternal();  // sysclock for internal  RC
  198.     /**/
  199.         SysTick_Init();
  200.         /**/
  201.         NVIC_Configuration();
  202.         /**/
  203.         PM_USART1_Configuartion();
  204.
  205.         /**/
  206. ……………………
  207. …………限于本文篇幅 余下代碼請從51黑下載附件…………
PMS7003測試代碼.rar (2.24 KB, 下載次數: 316)
參與人數 2黑幣 +8 收起 理由
七號123 + 4 很給力!
zhangli019 + 4 贊一個!
ID:228577 發表于 2017-8-21 10:33 | 顯示全部樓層
想看看
ID:238505 發表于 2017-10-11 16:43 | 顯示全部樓層
很好的參考
ID:198608 發表于 2017-10-11 23:52 來自觸屏版 | 顯示全部樓層
樓主,能向你學習嗎
ID:242109 發表于 2017-10-23 15:03 | 顯示全部樓層
學習了
ID:70546 發表于 2017-11-21 21:59 | 顯示全部樓層
謝謝樓主分享
ID:15207 發表于 2017-12-26 16:47 | 顯示全部樓層
這個傳感器是上電后每隔一段時間定時主動發送一條串口數據給單片機嗎?
ID:267330 發表于 2017-12-26 20:00 | 顯示全部樓層
我正要找SHT20程序啊
ID:270197 發表于 2018-1-2 14:59 | 顯示全部樓層
看看,謝謝
ID:273651 發表于 2018-1-9 11:02 | 顯示全部樓層
謝謝樓主的分享
ID:288544 發表于 2018-3-7 09:55 | 顯示全部樓層
感謝分享
ID:289262 發表于 2018-3-29 09:46 | 顯示全部樓層
好東西,下載學習下。謝謝
ID:334781 發表于 2018-5-21 16:35 | 顯示全部樓層
SHT20 這款傳感器不錯,有51的程序更好了
ID:366196 發表于 2018-7-6 14:29 | 顯示全部樓層
資料能發一份到我郵箱嗎??gavin1111@126.com
謝謝
ID:366196 發表于 2018-7-6 14:37 | 顯示全部樓層
memset(&PM_Sensor_Data,0,(sizeof(PM_Sensor_Data) - 2));請問這句是什么意思?memset是什么
ID:560737 發表于 2019-6-12 11:25 | 顯示全部樓層
看看大佬的
ID:526058 發表于 2019-11-9 23:52 | 顯示全部樓層
這代碼質量還可以,就是沒貼完整。
ID:646328 發表于 2019-11-21 10:23 | 顯示全部樓層
學習一下,觀摩
ID:818839 發表于 2020-9-14 14:01 | 顯示全部樓層
您的這個PMS7003的機器能給我一些嗎?我不要7003模塊,只要外殼和板子
ID:825701 發表于 2020-12-24 21:13 | 顯示全部樓層
沒想到,這里居然有我想要的
ID:1120670 發表于 2024-5-16 16:08 | 顯示全部樓層
問一下大佬,global_includes.h是什么文件,里面都聲明了哪些啊?
ID:1144566 發表于 2025-2-28 10:00 | 顯示全部樓層
請問有實物和單片機的連接圖嗎,我用的轉接板,轉成四根插針,用杜邦線連接到單片機的,連上電后傳感器沒有反應
