- * 文件名 : PCF8591T做DA實驗.c
- * 描述 : 我們單片機去控制PCF8591T去實現DA功能。
- 這個代碼也要在示波器上才能觀測到,DA輸出一個正弦波。
- * 可以用示波器測到正弦波
- #include<reg52.h>
- #include <I2C.H>
- #define PCF8591 0x90 //PCF8591 地址
- // 此表為 LED 的字模 // 0 1 2 3 4 5 6 7 8 9 A b c d E - L P U Hidden _ (20)
- unsigned char Disp_Tab[] = { 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x88,0x83,0xC6,0xA1,0x86,0xbf,0xc7,0x8c,0xc1, 0xff, 0xf7 };
- unsigned char AD_CHANNEL;
- unsigned long xdata LedOut[8];
- unsigned int idata D[32];
- // 128點正弦波樣本表
- unsigned char code auc_SinParam[128] = {
- 64,67,70,73,76,79,82,85,88,91,94,96,99,102,104,106,109,111,113,115,117,118,120,121,
- 123,124,125,126,126,127,127,127,127,127,127,127,126,126,125,124,123,121,120,118,
- 117,115,113,111,109,106,104,102,99,96,94,91,88,85,82,79,76,73,70,67,64,60,57,54,51,48,
- 45,42,39,36,33,31,28,25,23,21,18,16,14,12,10,9,7,6,4,3,2,1,1,0,0,0,0,0,0,0,1,1,2,3,4,6,
- 7,9,10,12,14,16,18,21,23,25,28,31,33,36,39,42,45,48,51,54,57,60};
- DAC 變換, 轉化函數
- bit DACconversion(unsigned char sla,unsigned char c, unsigned char Val)
- Start_I2c(); //啟動總線
- SendByte(sla); //發送器件地址
- if(ack==0)return(0);
- SendByte(c); //發送控制字節
- SendByte(Val); //發送DAC的數值
- Stop_I2c(); //結束總線
- return(1);
- ADC發送字節[命令]數據函數
- bit ISendByte(unsigned char sla,unsigned char c)
- SendByte(c); //發送數據
- return(1);
- ADC讀字節數據函數
- unsigned char IRcvByte(unsigned char sla)
- { unsigned char c;
- SendByte(sla+1); //發送器件地址
- c=RcvByte(); //讀取數據0
- Ack_I2c(1); //發送非就答位
- return(c);
- * 名稱 : Delay_1ms()
- * 功能 : 延時子程序,延時時間為 1ms * x
- * 輸入 : x (延時一毫秒的個數)
- * 輸出 : 無
- void Delay_1ms(unsigned char i)//1ms延時
- unsigned char x,j;
- for(j=0;j<i;j++)
- for(x=0;x<=148;x++);
- main()
- unsigned char i=0;
- while(1)
- {/********以下AD-DA處理*************/
- switch(AD_CHANNEL)
- case 0: ISendByte(PCF8591,0x41);
- D[0]=IRcvByte(PCF8591)*2; //ADC0 模數轉換1
- break;
- case 1: ISendByte(PCF8591,0x42);
- D[1]=IRcvByte(PCF8591)*2; //ADC1 模數轉換2
- break;
- case 2: ISendByte(PCF8591,0x43);
- D[2]=IRcvByte(PCF8591)*2; //ADC2 模數轉換3
- break;
- case 3: ISendByte(PCF8591,0x40);
- D[3]=IRcvByte(PCF8591)*2; //ADC3 模數轉換4
- break;
- case 4: DACconversion(PCF8591,0x40, D[4]/4); //DAC 數模轉換
- break;
- if(++AD_CHANNEL>4) AD_CHANNEL=0;
- /********以下將AD的值送到LED數碼管顯示*************/
- D[4] = auc_SinParam[i++]*2;
- Delay_1ms(5);
- if(i==128) i=0;
view plaincopy to clipboardprint?
- /*************************此部分為I2C總線的驅動程序*************************************/
- #include<reg52.h>
- #include <intrins.h>
- #include <I2C.H>
- #define NOP() _nop_() /* 定義空指令 */
- #define _Nop() _nop_() /*定義空指令*/
- sbit SCL=P1^5; //I2C 時鐘
- sbit SDA=P3^6; //I2C 數據
- bit ack; /*應答標志位*/
- 起動總線函數
- 函數原型: void Start_I2c();
- 功能: 啟動I2C總線,即發送I2C起始條件.
- void Start_I2c()
- SDA=1; /*發送起始條件的數據信號*/
- _Nop();
- SCL=1;
- _Nop(); /*起始條件建立時間大于4.7us,延時*/
- _Nop();
- _Nop();
- _Nop();
- _Nop();
- SDA=0; /*發送起始信號*/
- _Nop(); /* 起始條件鎖定時間大于4μs*/
- _Nop();
- _Nop();
- _Nop();
- _Nop();
- SCL=0; /*鉗住I2C總線,準備發送或接收數據 */
- _Nop();
- _Nop();
- 結束總線函數
- 函數原型: void Stop_I2c();
- 功能: 結束I2C總線,即發送I2C結束條件.
- void Stop_I2c()
- SDA=0; /*發送結束條件的數據信號*/
- _Nop(); /*發送結束條件的時鐘信號*/
- SCL=1; /*結束條件建立時間大于4μs*/
- _Nop();
- _Nop();
- _Nop();
- _Nop();
- _Nop();
- SDA=1; /*發送I2C總線結束信號*/
- _Nop();
- _Nop();
- _Nop();
- _Nop();
- 字節數據發送函數
- 函數原型: void SendByte(UCHAR c);
- 功能: 將數據c發送出去,可以是地址,也可以是數據,發完后等待應答,并對
- 此狀態位進行操作.(不應答或非應答都使ack=0)
- 發送數據正常,ack=1; ack=0表示被控器無應答或損壞。
- void SendByte(unsigned char c)
- unsigned char BitCnt;
- for(BitCnt=0;BitCnt<8;BitCnt++) /*要傳送的數據長度為8位*/
- if((c<<BitCnt)&0x80)SDA=1; /*判斷發送位*/
- else SDA=0;
- _Nop();
- SCL=1; /*置時鐘線為高,通知被控器開始接收數據位*/
- _Nop();
- _Nop(); /*保證時鐘高電平周期大于4μs*/
- _Nop();
- _Nop();
- _Nop();
- SCL=0;
- _Nop();
- _Nop();
- SDA=1; /*8位發送完后釋放數據線,準備接收應答位*/
- _Nop();
- _Nop();
- SCL=1;
- _Nop();
- _Nop();
- _Nop();
- if(SDA==1)ack=0;
- else ack=1; /*判斷是否接收到應答信號*/
- SCL=0;
- _Nop();
- _Nop();
- 字節數據接收函數
- 函數原型: UCHAR RcvByte();
- 功能: 用來接收從器件傳來的數據,并判斷總線錯誤(不發應答信號),
- 發完后請用應答函數應答從機。
- unsigned char RcvByte()
- unsigned char retc;
- retc=0;
- SDA=1; /*置數據線為輸入方式*/
- _Nop();
- SCL=0; /*置時鐘線為低,準備接收數據位*/
- _Nop();
- _Nop(); /*時鐘低電平周期大于4.7μs*/
- _Nop();
- _Nop();
- _Nop();
- SCL=1; /*置時鐘線為高使數據線上數據有效*/
- _Nop();
- _Nop();
- retc=retc<<1;
- if(SDA==1)retc=retc+1; /*讀數據位,接收的數據位放入retc中 */
- _Nop();
- _Nop();
- SCL=0;
- _Nop();
- _Nop();
- return(retc);
- 應答子函數
- 函數原型: void Ack_I2c(bit a);
- 功能: 主控器進行應答信號(可以是應答或非應答信號,由位參數a決定)
- void Ack_I2c(bit a)
- if(a==0)SDA=0; /*在此發出應答或非應答信號 */
- else SDA=1;
- _Nop();
- _Nop();
- _Nop();
- SCL=1;
- _Nop();
- _Nop(); /*時鐘低電平周期大于4μs*/
- _Nop();
- _Nop();
- _Nop();
- SCL=0; /*清時鐘線,鉗住I2C總線以便繼續接收*/
- _Nop();
- _Nop();
- extern bit ack;
- //起動總線函數
- extern void Start_I2c();
- //結束總線函數
- extern void Stop_I2c();
- //應答子函數
- extern void Ack_I2c(bit a);
- //字節數據發送函數
- extern void SendByte(unsigned char c);
- //有子地址發送多字節數據函數
- extern bit ISendStr(unsigned char sla,unsigned char suba,unsigned char *s,unsigned char no) ;
- //無子地址發送多字節數據函數
- extern bit ISendStrExt(unsigned char sla,unsigned char *s,unsigned char no);
- //無子地址讀字節數據函數
- extern unsigned char RcvByte();
- extern void HC595SendData(unsigned int SendVal);
- /*************************此部分為74HC595的驅動程序使用SPI總線連接*************************************/
- #include<reg52.h>
- //SPI IO
- sbit MOSIO =P1^5;
- sbit R_CLK =P1^6;
- sbit S_CLK =P1^7;
- sbit OE =P3^6;
- void HC595SendData(unsigned int SendVal);
- ** 函數名稱: HC595SendData
- ** 功能描述: 向SPI總線發送數據
- ** 管腳描述:請參考相關的芯片資料(學習光盤中以配)
- unsigned char i;
- for(i=0;i<16;i++)
- if((SendVal<<i)&0x8000) MOSIO=1; // set dataline high
- else MOSIO=0;
- S_CLK=0;
- NOP();
- NOP();
- S_CLK=1;
- R_CLK=0; //set dataline low
- NOP();
- NOP();
- R_CLK=1; //片選
- OE=0;
