只需一步,快速開(kāi)始
查看: 6976|回復(fù): 7
stm32串行st7920 128*64屏顯示字符源程序
stm32單片機(jī)串行方式控制st7920 128*64屏顯示字符,附件里面有2個(gè)程序,全部都是經(jīng)過(guò)測(cè)試ok的
單片機(jī)源程序如下:
  1. /**********************************************************
  2. * @ File name -> lcd12864.c
  3. * @ Version   -> V1.1.2
  4. * @ Date      -> 11-30-13
  5. * @ Brief     -> LCD12864驅(qū)動(dòng)函數(shù)
  6. *                適用于ST7920驅(qū)動(dòng)芯片
  7. V1.1
  8. * @ Revise    -> A、修正操作命令宏定義。
  9. * @           -> B、增加串口、并口轉(zhuǎn)換宏定義,增加對(duì)高速度MCU控制通訊頻率延時(shí)函數(shù)
  10. * @           -> C、顯示字符串函數(shù)增加顯示長(zhǎng)度選擇,即顯示多少個(gè)ASCII可顯示字符,漢字x2即可
  11. * @           -> D、去掉顯示數(shù)組函數(shù),合并在字符串顯示里
  12. V1.1.1
  13. * @ Revise    -> 增加字符串顯示函數(shù),可以從要顯示的數(shù)組中任意位置顯示一定長(zhǎng)度字符串
  14. V1.1.2
  15. * @ Revise    -> A、增加對(duì)低速晶振系統(tǒng)的MCU通訊頻率是否使用的宏定義
  16. * @           -> B、增加在檢測(cè)液晶忙超時(shí)退出,預(yù)防死循環(huán)
  17. **********************************************************/
  18. #include "lcd12864.h"
  19. /**********************************************************
  20.                     自定義顯示字符
  21. **********************************************************/
  22. #define CGRAM_Value   64        //寫(xiě)入CGRAM數(shù)量
  23.
  24. u8 code CGROM_Code[] = {
  25.                                                 //天線圖形
  26.                                                 0xff,0xff,0x80,0x01,0xbf,0xfd,0xdf,0xfb,0xec,0x37,0xf6,0x6f,0xfb,0xdf,0xfd,0xbf,
  27.                                                 0xfe,0x7f,0xfe,0x7f,0xfe,0x7f,0xfe,0x7f,0xfe,0x7f,0xfe,0x7f,0xfe,0x7f,0xff,0xff,
  28.                                                 //攝氏圖形
  29. //                                                0x00,0x00,0x00,0x00,0x00,0x00,0x1c,0x70,0x14,0xd8,0x1d,0x88,0x01,0x80,0x01,0x80,
  30. //                                                0x01,0x80,0x01,0x80,0x01,0x88,0x00,0xc8,0x00,0x70,0x00,0x00,0x00,0x00,0x00,0x00,
  31.                                                 //藍(lán)牙圖形
  32.                                                 0x07,0xe0,0x0e,0x70,0x1e,0xb8,0x3e,0xdc,0x36,0xec,0x3a,0xdc,0x3c,0xbc,0x3e,0x7c,
  33.                                                 0x3e,0x7c,0x3c,0xbc,0x3a,0xdc,0x36,0xec,0x3e,0xdc,0x1e,0xb8,0x0e,0x70,0x07,0xe0,
  34.                                                 //CD圖形
  35.                                                 0xff,0xff,0xff,0xff,0xff,0xff,0xe3,0x07,0xc9,0xb3,0x9d,0xb9,0x9f,0xb9,0x9f,0xb9,
  36.                                                 0x9f,0xb9,0x9f,0xb9,0x9d,0xb9,0xc9,0xb3,0xe3,0x07,0xff,0xff,0xff,0xff,0xff,0xff,
  37.                                                 //右指向手型
  38.                                                 0x00,0x00,0x1e,0x00,0x12,0x00,0x73,0xfc,0x52,0x02,0x52,0x1c,0x53,0xe0,0x52,0x10,
  39.                                                 0x53,0xe0,0x52,0x10,0x53,0xe0,0x52,0x10,0x73,0xe0,0x12,0x00,0x1e,0x00,0x00,0x00
  40.                                                 };
  41. //=========================================================
  42. #ifdef LCD_Work_Mode        //如果定義了,則使用并口工作模式
  43. //=========================================================
  44. /**********************************************************
  45. * 函數(shù)功能 ---> LCD12864判斷忙
  46. * 入口參數(shù) ---> none
  47. * 返回?cái)?shù)值 ---> none
  48. * 功能說(shuō)明 ---> none
  49. **********************************************************/
  50. void LCD_Check_Busy(void)
  51. {
  52.         static u16 busytimeout;        //忙超時(shí)
  53.     //=====================================================
  54.
  55.     #ifdef LCD_USE_DELAY   /*  定義了則使用延時(shí)調(diào)整通訊頻率    */
  56.     //=====================================================
  57.
  58.         ktdata = 0xf0;        //數(shù)據(jù)口全部置位
  59.         do
  60.         {
  61.                 busytimeout++;
  62.                 if(busytimeout > 300)        break;
  63.                 LCD_RS = 0;
  64.                 LCD_Delay();
  65.                 LCD_RW = 1;
  66.                 LCD_Delay();
  67.                 LCD_EN = 1;
  68.                 LCD_Delay();
  69.         }while(ktdata & LCD_Busy == LCD_Busy);        //等待LCD忙完
  70.         LCD_EN = 0;
  71.     //=====================================================
  72.     #else   /*  沒(méi)定義則不使用  */
  73.     //=====================================================
  74.     ktdata = 0xf0;        //數(shù)據(jù)口全部置位
  75.         do
  76.         {
  77.                 busytimeout++;
  78.                 if(busytimeout > 300)        break;
  79.                 LCD_RS = 0;
  80.                 LCD_RW = 1;
  81.                 LCD_EN = 1;
  82. //                LCD_Delay();
  83.         }while(ktdata & LCD_Busy == LCD_Busy);        //等待LCD忙完
  84.         LCD_EN = 0;
  85.     //=====================================================
  86.
  87.     #endif
  88.     //=====================================================
  89.         if(busytimeout >= 300)        printf("LCD Busy TimeOut...\r\n");
  90.         busytimeout = 0;
  91. }
  92. /**********************************************************
  93. * 函數(shù)功能 ---> LCD寫(xiě)入一個(gè)字節(jié)命令或者數(shù)據(jù),判斷忙標(biāo)志(8位數(shù)據(jù)一次發(fā)送完畢)
  94. * 入口參數(shù) ---> dat:要寫(xiě)入的字節(jié)
  95. *               ord:判斷dat是命令還是數(shù)據(jù)依據(jù),“0”為命令,“1”為數(shù)據(jù)
  96. * 返回?cái)?shù)值 ---> none
  97. * 功能說(shuō)明 ---> none
  98. **********************************************************/
  99. void LCD_Write_Byte(u8 dat,u8 ord)
  100. {
  101.     //=====================================================
  102.
  103.     #ifdef LCD_USE_DELAY   /*  定義了則使用延時(shí)調(diào)整通訊頻率    */
  104.     //=====================================================
  105.
  106.     LCD_Check_Busy();        //判斷是否在忙?
  107.         LCD_EN = 0;
  108.         LCD_Delay();
  109.         LCD_RW = 0;
  110.         LCD_Delay();
  111.         if(ord & 0x01)        LCD_RS = 1;        //放上數(shù)據(jù)或者命令判斷位
  112.         else        LCD_RS = 0;
  113.         LCD_EN = 1;
  114.         LCD_Delay();
  115.         ktdata = dat;        //放入數(shù)據(jù)
  116.         LCD_Delay();
  117.         LCD_EN = 0;
  118.     //=====================================================
  119.     #else   /*  沒(méi)定義則不使用  */
  120.     //=====================================================
  121.     LCD_Check_Busy();        //判斷是否在忙?
  122.         LCD_EN = 0;
  123.         LCD_RW = 0;
  124.         if(ord & 0x01)        LCD_RS = 1;        //放上數(shù)據(jù)或者命令判斷位
  125.         else        LCD_RS = 0;
  126.         LCD_EN = 1;
  127.         ktdata = dat;        //放入數(shù)據(jù)
  128.         LCD_EN = 0;
  129.     //=====================================================
  130.
  131.     #endif
  132.     //=====================================================
  133. }
  134. //=========================================================
  135. #else        //沒(méi)定義則使用串口通訊模式
  136. //=========================================================
  137. /**********************************************************
  138. * 函數(shù)功能 ---> LCD啟動(dòng)字節(jié)
  139. * 入口參數(shù) ---> dt:傳輸?shù)淖止?jié),高5位在函數(shù)內(nèi)部設(shè)定為1
  140. *               只是確定RW和RS為,最后那位也是內(nèi)部確定
  141. * 返回?cái)?shù)值 ---> none
  142. * 功能說(shuō)明 ---> 首先傳送一個(gè)啟動(dòng)字節(jié),送入連續(xù)5個(gè)“1”用來(lái)啟
  143. *               動(dòng)一個(gè)周期,此時(shí)傳輸計(jì)數(shù)被重置,并且串行傳輸
  144. *               被同步,緊接著的兩個(gè)位指定傳輸方向(R/W,確
  145. *               定是讀還是寫(xiě))和傳輸性質(zhì)(RS,確定是命令寄存
  146. *               器還是數(shù)據(jù)寄存器),最后的第八位是一個(gè)“0”
  147. **********************************************************/
  148. void LCD12864_Start(u8 dt)
  149. {
  150.         u8 dat,j;
  151.         dat = dt | 0xf8;        //高5位設(shè)定為“1”,第八位設(shè)定為“0”
  152.         LCD_SCL = 0;
  153.         LCD_Delay();LCD_Delay();
  154.         LCD_CS = 1;        //選中顯示屏,高電平有效
  155.         for(j = 0;j < 8;j++)
  156.         {
  157.                 if(dat & 0x80)        LCD_SDA = 1;        //放數(shù)據(jù)到數(shù)據(jù)線
  158.                 else        LCD_SDA = 0;
  159.
  160.                 LCD_Delay();LCD_Delay();LCD_Delay();
  161.                 LCD_SCL = 1;        //發(fā)送數(shù)據(jù),上升沿有效
  162.                 LCD_Delay();LCD_Delay();LCD_Delay();
  163.                 LCD_SCL = 0;
  164.                 dat <<= 1;        //左移一位,先發(fā)的是高位
  165.         }
  166.         LCD_Delay();LCD_Delay();LCD_Delay();
  167.         LCD_SCL = 0;
  168.         LCD_Delay();LCD_Delay();LCD_Delay();        //等待硬件反應(yīng)(等待數(shù)據(jù)發(fā)送完全)
  169. }
  170. /**********************************************************
  171. * 函數(shù)功能 ---> LCD寫(xiě)入一個(gè)字節(jié)命令或者數(shù)據(jù)
  172. * 入口參數(shù) ---> dat:要寫(xiě)入的命令或者數(shù)據(jù)
  173. *               ord:命令或者數(shù)據(jù)判斷為。0為命令,1為數(shù)據(jù)
  174. * 返回?cái)?shù)值 ---> none
  175. * 功能說(shuō)明 ---> none
  176. **********************************************************/
  177. void LCD_Write_Byte(u8 dat,u8 ord)
  178. {
  179.         u8 tem;
  180.         u8 i,j;
  181.         tem = dat & 0xf0;        //先發(fā)送高4位
  182.         LCD12864_Start((ord << 1) | 0xf0);        //置RW為“0”、RS為“ord”并啟動(dòng)串行傳輸為數(shù)據(jù)格式
  183.         for(j = 0;j < 2;j++)        //一個(gè)字節(jié)數(shù)據(jù)或者命令分兩次發(fā)送
  184.         {
  185.                 LCD_SCL = 0;        //允許數(shù)據(jù)線電平變化
  186.                 LCD_Delay();LCD_Delay();LCD_Delay();
  187.                 for(i = 0;i < 8;i++)
  188.                 {
  189.                         if(tem & 0x80)        LCD_SDA = 1;        //放上數(shù)據(jù),屏蔽低4位
  190.                         else        LCD_SDA = 0;
  191.                         LCD_Delay();LCD_Delay();LCD_Delay();
  192.                         LCD_SCL = 1;        //發(fā)送數(shù)據(jù),上升沿有效
  193.                         LCD_Delay();LCD_Delay();LCD_Delay();
  194.                         LCD_SCL = 0;
  195.                         tem <<= 1;        //左移一位,先發(fā)的是高位
  196.                 }
  197.                 tem = (dat << 4) & 0xf0;        //發(fā)完高4位,再次發(fā)送低4位
  198.         }
  199.         LCD_Delay();LCD_Delay();LCD_Delay();
  200.         LCD_SDA = 0;
  201.         LCD_Delay();LCD_Delay();LCD_Delay();
  202.         LCD_SCL = 0;
  203.         LCD_Delay();LCD_Delay();LCD_Delay();
  204.         LCD_CS = 0;
  205.         LCD_Delay();LCD_Delay();LCD_Delay();        //等待硬件反應(yīng)(等待數(shù)據(jù)發(fā)送完全)
  206. }
  207. //=========================================================
  208. #endif
  209. //=========================================================
  210. /**********************************************************
  211. * 函數(shù)功能 ---> 設(shè)置LCD顯示位置
  212. * 入口參數(shù) ---> x:行,取值范圍:1 ~ 4
  213. *               y:列,取值范圍:0 ~ 7
  214. * 返回?cái)?shù)值 ---> none
  215. * 功能說(shuō)明 ---> none
  216. **********************************************************/
  217. void LCD_Set_xy(u8 x,u8 y)
  218. {
  219.         switch(x)
  220.         {
  221.                 case 1:
  222.                                         LCD_Write_Byte((One_LineAddress + y),0);        //寫(xiě)入操作地址
  223.                                         break;
  224.                 case 2:
  225.                                         LCD_Write_Byte((Two_LineAddress + y),0);        //寫(xiě)入操作地址
  226.                                         break;
  227.                 case 3:
  228.                                         LCD_Write_Byte((Three_LineAddress + y),0);        //寫(xiě)入操作地址
  229.                                         break;
  230.                 case 4:
  231.                                         LCD_Write_Byte((Four_LineAddress + y),0);        //寫(xiě)入操作地址
  232.                                         break;
  233.                 default:
  234.                                         LCD_Write_Byte((One_LineAddress + y),0);        //寫(xiě)入操作地址
  235.                                         break;
  236.         }
  237. }
  238. /**********************************************************
  239. * 函數(shù)功能 ---> 寫(xiě)入自定義字符到LCD的CGRAM
  240. * 入口參數(shù) ---> *data_code:寫(xiě)入的數(shù)組
  241. * 返回?cái)?shù)值 ---> none
  242. * 功能說(shuō)明 ---> none
  243. **********************************************************/
  244. void LCD_Write_CGRAM(u8 *data_code)
  245. {
  246.         u8 i;
  247.         LCD_Write_Byte(0x34,0);        //打開(kāi)字符擴(kuò)展指令
  248.         LCD_Write_Byte(0x02,0);        //SR=0,允許輸入
  249.         LCD_Write_Byte(0x30,0);        //恢復(fù)基本指令
  250.         LCD_Write_Byte(0x40,0);        //CGRAM地址
  251.         for(i = 0;i < CGRAM_Value;i++)
  252.         {
  253.                 LCD_Write_Byte(data_code[i*2],1);
  254.                 LCD_Write_Byte(data_code[i*2+1],1);
  255.         }
  256. }
  257. /**********************************************************
  258. * 函數(shù)功能 ---> 顯示一個(gè)CGRAM內(nèi)容
  259. * 入口參數(shù) ---> x:行
  260. *               y:列
  261. *               *str為要顯示的字符串
  262. *               add_h:CGRAM高位地址
  263. *               add_l:CGRAM低位地址
  264. * 返回?cái)?shù)值 ---> none
  265. * 功能說(shuō)明 ---> none
  266. **********************************************************/
  267. void Display_CGRAM(u8 x,u8 y,u8 add_h,u8 add_l)
  268. {
  269.         LCD_Set_xy(x,y);        //設(shè)置顯示地址
  270.         LCD_Write_Byte(add_h,1);
  271.         LCD_Write_Byte(add_l,1);
  272. }
  273. /**********************************************************
  274. * 函數(shù)功能 ---> LCD顯示字符串
  275. * 入口參數(shù) ---> x:行
  276. *               y:列
  277. *               *str:要顯示的字符串
  278. *               len:顯示的長(zhǎng)度
  279. * 返回?cái)?shù)值 ---> none
  280. * 功能說(shuō)明 ---> 只能從數(shù)組的開(kāi)頭開(kāi)始顯示len長(zhǎng)度字符串
  281. **********************************************************/
  282. void Display_String(u8 x,u8 y,u8 *str,u8 len)
  283. {
  284.         LCD_Set_xy(x,y);        //設(shè)置顯示地址
  285.         while(len--)
  286.         {
  287.                 LCD_Write_Byte(*str,1);
  288.                 str++;
  289.         }
  290. }
  291. /**********************************************************
  292. * 函數(shù)功能 ---> LCD顯示字符串
  293. * 入口參數(shù) ---> x:行
  294. *               y:列
  295. *               *str:要顯示的字符串
  296. *               len:顯示的長(zhǎng)度
  297. * 返回?cái)?shù)值 ---> none
  298. * 功能說(shuō)明 ---> 可以從顯示數(shù)組的任意位置starsum開(kāi)始顯示len長(zhǎng)度的字符串
  299. **********************************************************/
  300. void Display_String1(u8 x,u8 y,u8 *str,u8 starsum,u8 len)
  301. {
  302.         u8 i;
  303.         LCD_Set_xy(x,y);        //設(shè)置顯示地址
  304.         for(i = starsum;i < starsum + len;i++)
  305.         {
  306.                 LCD_Write_Byte(str[i],1);
  307.         }
  308. }
  309. /**********************************************************
  310. * 函數(shù)功能 ---> LCD寫(xiě)入GDRAM繪圖
  311. * 入口參數(shù) ---> x:行
  312. *               y:列
  313. *               width:顯示圖片的寬度
  314. *               hieght:顯示圖片的高度
  315. *               *bmp:要顯示的字符串
  316. *               dis_mode:顯示模式,是半屏顯示還是全屏顯示
  317. *                         0:半屏顯示。1:全屏顯示
  318. * 返回?cái)?shù)值 ---> none
  319. * 功能說(shuō)明 ---> none
  320. **********************************************************/
  321. void Display_GDRAM(u8 x,u8 y,u8 width,u8 height,u8 *bmp,u8 dis_mode)
  322. {
  323.         u8 i,j,k;
  324.         u8 base_x,base_y;        //起始坐標(biāo)
  325.         /******全屏繪圖顯示******/
  326.         if(dis_mode)
  327.         {
  328.                 switch(x)
  329.                 {
  330.                         case 1:
  331.                                         base_y = One_LineAddress + y;
  332.                                         break;
  333.                         case 2:
  334.                                         base_y = Two_LineAddress + y;
  335.                                         break;
  336.                         case 3:
  337.                                         base_y = Three_LineAddress + y;
  338.                                         break;
  339.                         case 4:
  340.                                         base_y = Four_LineAddress + y;
  341.                                         break;
  342.                         default:        break;
  343.                 }
  344.
  345.                  LCD_Write_Byte(MPU_8bit_Expansion_Draw_Close,0);        //擴(kuò)充指令
  346.                 LCD_Write_Byte(MPU_8bit_Expansion_Draw_Open,0);        //打開(kāi)繪圖功能
  347.
  348.                 for(j = 0;j < height;j++)        //32
  349.                 {
  350.                         LCD_Write_Byte(base_y + j,0);        //寫(xiě)入行號(hào),即第幾行開(kāi)始
  351.                         LCD_Write_Byte(One_LineAddress,0);        //橫坐標(biāo)的第幾個(gè)字節(jié)開(kāi)始寫(xiě)
  352.
  353.                         for(i = 0;i < width;i++)        //上半屏
  354.                         {
  355.                                 LCD_Write_Byte(bmp[width * j + i],1);        //開(kāi)始寫(xiě)入數(shù)據(jù)
  356.                         }
  357.                         for(k = 0;k < width;k++)        //下半屏
  358.                         {
  359.                                  LCD_Write_Byte(bmp[width * (j + height) + k],1);        //開(kāi)始寫(xiě)入數(shù)據(jù)
  360.                         }
  361.                 }
  362.         }
  363.         /******分開(kāi)上半屏或者下半屏寫(xiě)******/
  364.         else
  365.         {
  366.                 switch(x)        //判斷顯示的橫坐標(biāo),確定起始行
  367.                 {
  368.                         case 1:        //上半屏
  369.                                         base_x = One_LineAddress;        //起始地址為0x80
  370.                                         break;
  371.
  372.                         case 2:        //下半屏
  373.                                         base_x = One_LineAddress;        //起始地址為0x80
  374.                                         break;
  375.
  376.                         case 3:        //下半屏
  377.                                         base_x = Three_LineAddress;        //起始地址為0x88
  378.                                         break;
  379.                         default:
  380.                                         break;
  381.                 }
  382.
  383.                 base_y = base_x + y;        //x軸方向的偏移,基地址 + 偏移地址
  384.
  385.                 LCD_Write_Byte(MPU_8bit_Expansion_Draw_Close,0);        //擴(kuò)充指令
  386.                 LCD_Write_Byte(MPU_8bit_Expansion_Draw_Open,0);        //打開(kāi)繪圖功能
  387.
  388.                 if(x == 1 || x == 3)        //直接在同一個(gè)半屏的,直接寫(xiě)完32位數(shù)據(jù)
  389.                 {
  390.                         for(i = 0;i < 32;i++)        //寫(xiě)地址有講究,先寫(xiě)垂直再寫(xiě)水平,詳見(jiàn)“設(shè)定繪圖RAM地址”說(shuō)明
  391.                         {
  392.                                 LCD_Write_Byte(One_LineAddress + i,0);        //寫(xiě)入垂直地址,不管上半屏還是下半屏
  393.                                 LCD_Write_Byte(base_y,0);        //寫(xiě)入水平地址
  394.
  395.                                 for(j = 0;j < 2;j++)        //兩組8bit數(shù)據(jù),組成16bit
  396.                                 {
  397.                                         LCD_Write_Byte(*bmp++,1);        //寫(xiě)入數(shù)據(jù)
  398.                                 }
  399.                         }
  400.                 }
  401.
  402.                 if(x == 2)        //數(shù)據(jù)顯示不在同一半屏上的,先寫(xiě)上半屏,在寫(xiě)下半屏
  403.                 {
  404.                         for(i = 0;i < 16;i++)        //上半屏16行點(diǎn)陣數(shù)據(jù)
  405.                         {
  406.                                 LCD_Write_Byte(Two_LineAddress + i,0);        //寫(xiě)入垂直地址
  407.                                 LCD_Write_Byte(base_y,0);        //寫(xiě)入水平地址
  408.
  409.                                 for(j = 0;j < 2;j++)        //兩組8bit數(shù)據(jù),組成16bit
  410.                                 {
  411.                                         LCD_Write_Byte(*bmp++,1);        //寫(xiě)入數(shù)據(jù)
  412.                                 }
  413.                         }
  414.                         for(i = 0;i < 16;i++)        //下半屏16行點(diǎn)陣數(shù)據(jù)
  415.                         {
  416.                                 LCD_Write_Byte(Three_LineAddress + i,0);        //寫(xiě)入垂直地址
  417.                                 LCD_Write_Byte(base_y + 8,0);        //寫(xiě)入水平地址
  418.
  419.                                 for(j = 0;j < 2;j++)        //兩組8bit數(shù)據(jù),組成16bit
  420.                                 {
  421.                                         LCD_Write_Byte(*bmp++,1);        //寫(xiě)入數(shù)據(jù)
  422. ……………………
  423. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
STM32F103VCT612864.rar (263.89 KB, 下載次數(shù): 100)
lcd12864.zip (8.03 KB, 下載次數(shù): 83)
JN12864J使用說(shuō)明書(shū).pdf (776.12 KB, 下載次數(shù): 40)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
ID:44037 發(fā)表于 2017-7-21 19:19 | 只看該作者
謝謝樓主分享  學(xué)習(xí)一下  現(xiàn)在能力只能模仿  無(wú)力獨(dú)立完成
ID:329099 發(fā)表于 2018-5-13 20:16 | 只看該作者
ID:424360 發(fā)表于 2018-11-25 11:53 | 只看該作者
ID:388459 發(fā)表于 2018-11-26 11:25 | 只看該作者
謝謝分享  學(xué)習(xí)一下
ID:100415 發(fā)表于 2019-7-29 14:16 | 只看該作者
謝謝樓主分享,新人學(xué)習(xí)一下
謝謝樓主分享,學(xué)習(xí)一下
ID:338360 發(fā)表于 2020-4-7 00:00 | 只看該作者
謝謝!剛好需要,下來(lái)參考一下
