#include<reg52.h>//單片機(jī)制造出來(lái)的電子計(jì)時(shí)表//
uchar num,num0,num1,num2,num3,num4;
uint xq;
void delayms(zms);
sbit key1=P2^5;
sbit key2=P2^6;
sbit key3=P2^3;
sbit key4=P2^4;
sbit led0=P1^0;
sbit led1=P1^1;
sbit led2=P1^2;
sbit led3=P1^3;
sbit led4=P1^4;
sbit led5=P1^5;
sbit led6=P1^6;
sbit led7=P1^7;
uchar code table1[]={
0x05,0x7d,0x46,0x54,
0x3c,0x94,0x84,0x5d,
0x04,0x14 }; //無(wú)小數(shù)點(diǎn)
uchar code table2[]={
0x01,0x79,0x42,0x50,
0x38,0x90,0x80,0x59,
0x00,0x10};//有小數(shù)點(diǎn)
xq=1;
num=0;
num0=0;
num1=0;
num2=0;
num3=0;
num4=0;
led0=0 ;
TMOD=0x01;
TH0=(65536-45872)/256;
TL0=(65536-45872)%256;
EA=1;
ET0=1;
TR0=1;
key4=0;
P0=table1[num1];
key4=1;
P0=0xff;
key3=0;
P0=table1[num2];
key3=1;
P0=0xff;
key2=0;
P0=table2[num3];
key2=1;
P0=0xff;
key1=0;
P0=table1[num4];
key1=1;
P0=0xff;
if(num==20)
num=0;
num0++;
if(num0==60)
num0=0;
num1++;
if(num1==10)
num1=0;
num2++;
if(num2==6)
num2=0;
num3++;
if(num3==10)
num3=0;
num4++;
if(num4*10+num3==24)
num3=0;
num4=0;
xq++;
if(xq==1)
led1=0;
led2=1;
led3=1;
led4=1;
led5=1;
led6=1;
led7=1;
if(xq==2)
led1=1;
led2=0;
led3=1;
led4=1;
led5=1;
led6=1;
led7=1;
if(xq==3)
led1=1;
led2=1;
led3=0;
led4=1;
led5=1;
led6=1;
led7=1;
if(xq==4)
led1=1;
led2=1;
led3=1;
led4=0;
led5=1;
led6=1;
led7=1;
if(xq==5)
led1=1;
led2=1;
led3=1;
led4=1;
led5=0;
led6=1;
led7=1;
if(xq==6)
led1=1;
led2=1;
led3=1;
led4=1;
led5=1;
led6=0;
led7=1;
if(xq==7)
led1=1;
led2=1;
led3=1;
led4=1;
led5=1;
led6=1;
led7=0;
if(xq==8)
xq=1;
