查看: 3373|回復: 4
16*16漢字點陳,多個漢字怎么一個接一個顯示出來?
ID:219908 發表于 2017-7-15 16:39 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
#include<intrins.h>
typedef unsigned char u8;
typedef unsigned int u16;
void delay(u16 i)
   while(i--);
u8  code ledwei[]=
  0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,
sbit  SER = P3^4; //串行數據輸入
sbit  RCLK = P3^5; //存儲寄存器時鐘輸入
sbit  SRCLK = P3^6; //移位寄存器時鐘輸入
u8 code Digital1[]=
/*--  文字:  普  --*/
/*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
0x40,0x44,0x54,0x64,0x45,0x7E,0x44,0x44,0x44,0x7E,0x45,0x64,0x54,0x44,0x40,0x00,
0x00,0x00,0x00,0xFF,0x49,0x49,0x49,0x49,0x49,0x49,0x49,0xFF,0x00,0x00,0x00,0x00,
u8 code Digital2[]=
/*--  文字:  我  --*/
0x20,0x24,0x24,0x24,0xFE,0x23,0x22,0x20,0x20,0xFF,0x20,0x22,0x2C,0xA0,0x20,0x00,
0x00,0x08,0x48,0x84,0x7F,0x02,0x41,0x40,0x20,0x13,0x0C,0x14,0x22,0x41,0xF8,0x00,
void HC595(u8 dat1,u8 dat2, u8 dat3, u8 dat4)
   u8 a;
   for(a=0; a<8; a++)
          SER = dat1 >>7;
          dat1 <<= 1;
      SRCLK = 0;
          _nop_();
          _nop_();
          SRCLK = 1;
          _nop_();
          _nop_();
   for(a=0; a<8; a++)
          SER = dat2 >>7;
          dat2 <<= 1;
      SRCLK = 0;
          _nop_();
          _nop_();
          SRCLK = 1;
          _nop_();
          _nop_();
   for(a=0; a<8; a++)
          SER = dat3 >>7;
          dat3 <<= 1;
      SRCLK = 0;
          _nop_();
          _nop_();
          SRCLK = 1;
          _nop_();
          _nop_();
   for(a=0; a<8; a++)
          SER = dat4 >>7;
          dat4 <<= 1;
      SRCLK = 0;
          _nop_();
          _nop_();
          SRCLK = 1;
          _nop_();
          _nop_();
      RCLK = 0;
          _nop_();
          _nop_();
          RCLK = 1;
          _nop_();
          _nop_();
    u8 i ;
           for(i=0;i<16;i++)
             HC595(~ledwei[i+16],~ledwei[i],Digital2[16+i],Digital2[i]);
                 delay(10);
ID:219796 發表于 2017-7-15 19:21 來自觸屏版 | 只看該作者
用二維數組,譬如woshi[][]={{我};{是}}我和是是點陣數組
ID:21069 發表于 2019-2-3 01:45 | 只看該作者
不難,建議在論壇找一個現實的案例調試,先開懂代碼,再改改修修,后自己寫整個代碼就掌握了
參與人數 3黑幣 +105 收起 理由
shuisheng + 35
刀刀見紅 + 35 贊一個!
areyouok + 35 很給力!
ID:474631 發表于 2019-2-3 22:52 | 只看該作者
二維數組 你看看main里面的循環吧
#include "reg51.h"
#include "intrins.h"
#define WEI P0
sbit shcp=P3^6;
sbit stcp=P3^5;
sbit ds=P3^4;
u8 Weixuan[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
u8 Word[4][8]={{0x8a,0x7e,0x2a,0x9f,0xd5,0xff,0xd5,0x9f},
               {0x40,0x44,0x44,0x7c,0x44,0x44,0x40,0x00},
               {0x88,0x48,0x28,0x1e,0x28,0x48,0x88,0x00},
{0x06,0x22,0x2b,0xaa,0xfb,0x2a,0x23,0x06}};
void delay(u16 i)
        while(i--);
void SendData(u8 dat)
        u8 i;
        shcp=0;stcp=0;
        for(i=0;i++;i<8)
                ds=dat>>7;
                dat<<=1;
                shcp=1;//上升沿時數據移位
                _nop_();
                _nop_();
                shcp=0;
        stcp=1;//移動結束后產生正脈沖所以是在循環外上升沿
        _nop_();
        _nop_();
        stcp=0;
        u8 i,j=0;
        u16 a=0;
                        for(i=0;i<8;i++)
                                WEI=Weixuan[i];
                        SendData(Word[j][i]);
                        delay(2);SendData(0x00);
                a++;
                        j++;
                        if(j==4)
                        j=0;
ID:472268 發表于 2019-2-12 01:30 | 只看該作者
用二維數組
參與人數 1黑幣 +35 收起 理由
就你**** + 35
