查看: 4967|回復: 4
求大神指導,寫的一個51單片機用定時器0方式一60倒計時程序跑不了
ID:183466 發表于 2017-7-14 09:34 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#include<intrins.h>
uchar temp,num,second;
unsigned char code Tab[11]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};
void delay1ms(uint i)
        uchar j;
        while(i--)
        for(j=0;j<115;j++)
void display(uchar k)
        P2=0xfe;
        P0=Tab[k/10];
        delay1ms(5);
        P2=0xfd;
        P0=Tab[k%10];
        delay1ms(5);
        P2=0xff;
        P0=0xff;
        delay1ms(5);
        void main(void)
                   TMOD=0x01;
            TH0=(65536-50000)/256;
                TL0=(65536-50000)%256;
                EA=1;
                ET0=0;
                TR0=0;
                num=0;
                second=60;
                        display(second);
                void timer0(void) interrupt 1
                   TR0=0;
                   num++;
                                  if(num==20)
                                num=0;
                             second--;
                                if(second==0)
                          second=60;
                        TR0=1;
ID:219592 發表于 2017-7-14 10:16 | 只看該作者
看著沒什么錯誤
ID:213173 發表于 2017-7-14 10:51 | 只看該作者
初始化定時器中 ET0=1;  TR0=1;,中斷程序中取消對TR0的操作
參與人數 1黑幣 +1 收起 理由
zlc哈哈哈 + 1 很給力!
ID:218170 發表于 2017-7-14 16:53 | 只看該作者
#include<reg52.h>
#include<intrins.h>
uchar temp,second,tab1[2],TOH = 0,TOL = 0;
bit flag = 0;
void display( )
                  static uchar i = 0;
    P0 = 0xff;
    P2 = ~(0x01 << i);
    P0 = Tab[tab1[i]];
    if ( i< 1)
        i++;
        i = 0;
//定時函數
void Timer( uchar t)
    unsigned long temp;
    temp = 11059200 / 12;
    temp = (temp * t) / 1000;
    temp = 65536 - temp;
    TOH = (uchar)(temp >> 8);
    TOL = (uchar)temp;
    TH0 = TOH;
    TL0 = TOL;
    TMOD &= 0XF0;
    TMOD |= 0X01;
    TR0 = 1;
    ET0 = 1;
    EA = 1;
void main(void)
                    Timer(1); //定時一毫秒
                second=60;
                                tab1[0] = second / 10;
                                tab1[1] = second % 10;
                   if(flag)                //一秒鐘就減一次
                                         flag = 0;
                                         second--;
                                         if (second == 0)
                                         second = 60;
                                  static unsigned int num = 0;
                                  TH0 = TOH;
                                  TL0 = TOL;
                                   display();
                   num++;
                  if(num>= 1000)   //一秒鐘就減一次
                                       num = 0;
                       flag = 1;
