查看: 3397|回復: 1
關于普中科技ES2.0開發板點陣動畫顯示的問題
ID:184970 發表于 2017-7-11 15:38 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
用的普中科技的ES2.0的開發板,求如何用這個板子實現點陣的動畫顯示呢,有用這個板子的大神么,希望給個程序看看,普中的學習視頻覺得不是多很好,所以用的普中的板子看的金沙灘的學習視頻,在看到點陣動畫顯示的時候,自己一直做不出那種效果!
ID:164602 發表于 2017-7-12 09:31 | 只看該作者
你是問對人了,我就用這塊板子。看我的名字,呵呵。
點陣嘛,想動態,我現在只有我初學時的程序,不是很好,只能是完成了動態顯示而已,給你看看,不要笑就好。
#include<reg51.h>
#include<intrins.h>
sbit SRCLK=P3^6;
sbit RCLK=P3^5;
sbit SER=P3^4;
#define LKZ P0
unsigned char code TAB[8]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
unsigned char code XS[17][8]=
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*以下是箭頭向左移動*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10},
{0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x38},
{0x00,0x00,0x00,0x00,0x00,0x10,0x38,0x38},
{0x00,0x00,0x00,0x00,0x10,0x38,0x38,0x54},
{0x00,0x00,0x00,0x10,0x38,0x38,0x54,0x10},
{0x00,0x00,0x10,0x38,0x38,0x54,0x10,0x10},
{0x00,0x10,0x38,0x38,0x54,0x10,0x10,0x10},
{0x10,0x38,0x38,0x54,0x10,0x10,0x10,0x10},
{0x38,0x38,0x54,0x10,0x10,0x10,0x10,0x00},
{0x38,0x54,0x10,0x10,0x10,0x10,0x00,0x00},
{0x54,0x10,0x10,0x10,0x10,0x00,0x00,0x00},
{0x10,0x10,0x10,0x10,0x00,0x00,0x00,0x00},
{0x10,0x10,0x10,0x00,0x00,0x00,0x00,0x00},
{0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00},
{0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
void delay(unsigned int time)//0.0001766s延時,約0.2ms
  unsigned int j;
  for(time;time>0;time--)
    for(j=0;j<20;j++);
void XP74HC595(unsigned char dat)//向74H595發送一個字節的數據
        //函數名必須由字母開始
        unsigned char a;
        SRCLK=0;
        RCLK=0;
        for(a=0;a<8;a++)
                if ((dat<<a)&0x80)//從高位開始發送數據
                        SER=1;
                        SER=0;
                SRCLK=1;
                _nop_();
                _nop_();
                SRCLK=0;
        RCLK=1;
        _nop_();
        _nop_();
        RCLK=0;
void main ()
        unsigned char i,j,k;
        LKZ=0xff;
        XP74HC595(0x00);
        while (1)
                for (i=0;i<17;i++)
                        for (j=0;j<50;j++)
                                for (k=0;k<8;k++)
                                        XP74HC595(XS[i][k]);
                                        LKZ=TAB[k];
                                        delay(5);
                                        LKZ=0xff;
                                        XP74HC595(0x00);        //消隱
我初學時的辦法是很笨的,叫“硬來”。即:將顯示內容逐幀列出,一次一幀,就動態顯示了。希望能拋磚引玉。
