查看: 2605|回復: 0
AD轉換電壓測量
ID:218728 發表于 2017-7-11 10:54 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
AD轉換電壓測量
#include <reg51.h>
char code TAB[10]={ 0xc0, 0xf9, 0xa4, 0xb0, 0x99,
     0x92, 0x83, 0xf8, 0x80, 0x98 };
#define  ADC P0
#define  SCANP P1
#define  SEG7P P2
sbit  relay=P3^0;
sbit  LED=P3^1;
unsigned char  disp[4]={0, 0, 0, 0};
unsigned char _adc;
void dataproc(unsigned char);
void display(void);
void delay1ms(char);
main()
{ while(1)
{ display();
  _adc=ADC;
  dataproc(_adc);
void dataproc(unsigned char data_in)
{ unsigned int results;
        LED=1;
results= data_in*197;
results=((results/(50000-results))*10000);
disp[3]=results/10000;
disp[2]=(results/1000)%10;
disp[1]=(results/100)%10;
disp[0]=(results/10)%10;
if(disp[3]>3)
     relay=0;
  LED=~LED;
  delay1ms(500);
void display(void)
{ char i,scan;
char times=20;
while (--times>=0)
{ scan=1;
  for(i=0;i<4;i++)
  { SEG7P=0xff;
   SCANP=scan;
   SEG7P=TAB[disp[i]];
   delay1ms(4);
   scan<<=1;
void delay1ms(char x)
{ int i,j;
for(i=0;i<x;i++)
  for(j=0;j<120;j++);
參與人數 1黑幣 +1 收起 理由
穿著安踏去拉薩 + 1 樓主,這資料給的有點草率啊,要是能備注一.
