- 名稱:st7920字庫液晶顯示
- 論壇:806899919
- 編寫:光匯科技
- 日期:2012.3
- 修改:無
- 內容:通過顯示字符、數字、漢字和圖片測試液晶基本功能
- #include <reg52.h>
- #include "delay.h"
- sbit RS = P2^2;
- sbit RW = P2^1;
- sbit E = P2^0;
- sbit RES = P2^5;
- sbit PSB = P2^3;
- #define DataPort P0 //MCU P0<------> LCM
- unsigned char code user16x16[]={ //笑臉圖片
- 0x0F,0xF0,0x10,0x08,0x20,0x04,0x40,0x02,0x9C,0x39,0xBE,0x7D,0x80,0x01,0x80,0x01,
- 0x80,0x01,0x88,0x11,0x84,0x21,0x43,0xC2,0x20,0x04,0x10,0x08,0x0F,0xF0,0x00,0x00,
- 檢測忙位
- void Check_Busy()
- RS=0;
- RW=1;
- E=1;
- DataPort=0xff;
- while((DataPort&0x80)==0x80);//忙則等待
- E=0;
- 寫命令
- void Write_Cmd(unsigned char Cmd)
- Check_Busy();
- RS=0;
- RW=0;
- E=1;
- DataPort=Cmd;
- DelayUs2x(5);
- E=0;
- DelayUs2x(5);
- 寫數據
- void Write_Data(unsigned char Data)
- Check_Busy();
- RS=1;
- RW=0;
- E=1;
- DataPort=Data;
- DelayUs2x(5);
- E=0;
- DelayUs2x(5);
- 液晶屏初始化
- void Init_ST7920()
- DelayMs(40); //大于40MS的延時程序
- PSB=1; //設置為8BIT并口工作模式
- DelayMs(1); //延時
- RES=0; //復位
- DelayMs(1); //延時
- RES=1; //復位置高
- DelayMs(10);
- Write_Cmd(0x30); //選擇基本指令集
- DelayUs2x(50); //延時大于100us
- Write_Cmd(0x30); //選擇8bit數據流
- DelayUs2x(20); //延時大于37us
- Write_Cmd(0x0c); //開顯示(無游標、不反白)
- Write_Cmd(0x01); //清除顯示,并且設定地址指針為00H
- DelayMs(15); //延時大于10ms
- Write_Cmd(0x06); //指定在資料的讀取及寫入時,設定游標的移動方向及指定顯示的移位,光標從右向左加1位移動
- 用戶自定義字符
- void CGRAM()
- int i;
- Write_Cmd(0x30);
- Write_Cmd(0x40);
- for(i=0;i<16;i++)
- Write_Data(user16x16[i*2]);
- Write_Data(user16x16[i*2+1]);
- 顯示用戶自定義字符
- void DisplayCGRAM(unsigned char x,unsigned char y)
- switch(y)
- case 1: Write_Cmd(0x80+x);break;
- case 2: Write_Cmd(0x90+x);break;
- case 3: Write_Cmd(0x88+x);break;
- case 4: Write_Cmd(0x98+x);break;
- default:break;
- Write_Data(00);
- Write_Data(00);
- 顯示字符串
- x:橫坐標值,范圍0~8
- y:縱坐標值,范圍1~4
- void LCD_PutString(unsigned char x,unsigned char y,unsigned char code *s)
- switch(y)
- default:break;
- while(*s>0)
- Write_Data(*s);
- s++;
- DelayUs2x(50);
- 清屏
- void ClrScreen()
- Write_Cmd(0x01);
- DelayMs(15);
- 顯示圖片
- void LCD_PutGraphic(unsigned char code *img)
- int i,j;
- //顯示上半屏內容設置
- for(i=0;i<32;i++)
- Write_Cmd(0x80 + i); //SET 垂直地址 VERTICAL ADD
- Write_Cmd(0x80); //SET 水平地址 HORIZONTAL ADD
- for(j=0;j<16;j++)
- Write_Data(*img);
- img++;
- //顯示下半屏內容設置
- for(i=0;i<32;i++)
- Write_Cmd(0x88); //SET 水平地址 HORIZONTAL ADD
- for(j=0;j<16;j++)
- Write_Data(*img);
- img++;
- 設置到繪圖模式
- void SetGraphicMode()
- Write_Cmd(0x36); //選擇8bit數據流 圖形模式
- DelayUs2x(20);
- void display_init()
- LCD_PutString(0,1,"智能家居控制系統");
- LCD_PutString(0,2,"學生:鄭家波");
- LCD_PutString(0,3,"老師:李湘文");
- LCD_PutString(0,4,"時間:2015/6/2");
- 主程序
- main()
- unsigned char i;
- // CGRAM(); //寫入自定義字符
- Init_ST7920(); //初始化
- LCD_PutString(0,4,"時間:2015/5/5");
- //延時30x200ms
- for(i=0;i<30;i++)
- DelayMs(200);
- ClrScreen();
- while(1)
- LCD_PutString(0,1,"窗簾OFF 燈光OFF");
- LCD_PutString(0,2,"煙霧OK 溫度OK ");
- LCD_PutString(0,3," 溫度:28°C");
- LCD_PutString(0,4," 光照度:53% ");
- //延時30x200ms
- for(i=0;i<30;i++)
- DelayMs(200);
- LCD_PutString(0,1,"窗簾ON 燈光OFF");
- for(i=0;i<30;i++)
- DelayMs(200);
- ClrScreen();
- LCD_PutString(0,2," 短信通知中..."); //"正”字顯示不出
- for(i=0;i<20;i++)
- DelayMs(200);
復制代碼 |
