查看: 4292|回復: 1
最簡單的程序都編譯出錯,幫我看下是什么問題。
ID:38658 發表于 2017-7-5 19:05 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
// PIC16F877A Configuration Bit Settings
// 'C' source line config statements
// CONFIG
#include <stdio.h>
#include <stdlib.h>
#pragma config FOSC = HS        // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable bit (BOR disabled)
#pragma config LVP = OFF        // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF        // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
* File:   蜂鳴器.c
* Author: Administrator
* Created on 2017年7月5日, 下午6:44
#define ucahr unsigned char
    TRISD=0;
    PORTD=0;
下面是編譯的結果,看不懂這是什么意思。用的軟件是“MPLAB X IDE V3.61”編譯器是XC8
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
nbproject/Makefile-default.mk:105: *** missing separator.  Stop.
make[1]: Entering directory 'F:/PIC��Ƭ��ѧϰ/������.X'
make: *** [.build-impl] Error 2
make[1]: Leaving directory 'F:/PIC��Ƭ��ѧϰ/������.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
編譯已失敗 (退出值2, 總時間: 140ms)
ID:217351 發表于 2017-7-6 20:23 | 只看該作者
額。。文件路徑里有中文??
