display()采集的數(shù)據(jù)都能在lcd上顯示了,可是display2(是按鍵調(diào)節(jié)數(shù)值(電壓))卻不能顯示在lcd上.顯示程序我感覺沒有出錯啊,為何display可以顯示,但display2就顯示不了
#include<reg52.h>
#include"lcd.h"
#define ulong unsigned long
sbit P1_6 = P1^6;
sbit P1_7 = P1^7;
sbit ADC_CS=P1^0;
sbit ADC_CLK=P1^1;
sbit ADC_DIN=P1^2;
sbit ADC_DOUT=P1^3;
sbit ADC_DRDY=P1^4;
uchar t = 0,c = 0,k,v =53;//k為脈沖周期
sbit S1 = P3^5;
sbit S2 = P3^4;
uchar date[3]={0,0,0};
uint result0[8]={0,0,0,0,0,0,0,0};
uint result1[8]={0,0,0,0,0,0,0,0};
void Display(uint AD_data);
void Display1(uint AD_data);
void Display2();
void PWM_Control1( uchar Width, uchar DutyCycle,uchar count,uchar partern);
void PWM_Control2( uchar Width, uchar DutyCycle,uchar count,uchar partern);
void Delay_1ms(uint c)
uchar a,b;
for(;c>0;c--)
for(b=199;b>0;b--)
for(a=1;a>0;a--);
void WriteToReg_ADC(uint byteword ) //發(fā)送控制字
uint AD16bit,Token;
uchar i;
ADC_CLK=1;
ADC_CS=0;
Token=0x80;
AD16bit=byteword;
for(i=0;i<8;i++)
if(AD16bit&Token) // 逐一取出各位上的數(shù)據(jù)
ADC_DIN=1;
ADC_DIN=0;
ADC_CLK=1;
ADC_CLK=0; //為發(fā)送數(shù)據(jù)做準(zhǔn)備
ADC_CLK=1;
Token=Token>>1;
ADC_CLK=1;
ADC_DIN=1;
uint ReadADC_16BitValue(uchar channel) //發(fā)送控制字準(zhǔn)備讀取的通道,接著讀取數(shù)據(jù)
uint AD16bit;
uchar i;
WriteToReg_ADC(0x38|channel);
while(ADC_DRDY==1); // 等待DRDY下降沿讀數(shù)據(jù)
ADC_CLK=1;
ADC_CS=0;
AD16bit=0x00;
for(i=0;i<16;i++) //巡歷
AD16bit=AD16bit<<1;
ADC_CLK=0;
if(ADC_DOUT==1) //等待DRDY低電平時間
AD16bit=AD16bit|0x01; //最低位開始
ADC_CLK=1;
ADC_CLK=1;
ADC_DIN=1;
return(AD16bit); //返回數(shù)據(jù)
void InitADC()
uchar i;
ADC_CLK=1;
ADC_DIN=1;
ADC_CS=0;
for(i=0;i<40;i++) //自校驗
ADC_CLK=0;
ADC_CLK=1;
WriteToReg_ADC(0x20); //先寫通信寄存器,下一步時鐘寄存器
WriteToReg_ADC(0x02); //100HZ CLKIDS=0 CLKDIV=0(器件內(nèi)部頻率)
WriteToReg_ADC(0x10); //設(shè)置寄存器
WriteToReg_ADC(0x44); //自校準(zhǔn)
WriteToReg_ADC(0x21); //通道2
WriteToReg_ADC(0x11);
Delay_1ms(50);
void PWM_Control1( uchar Width, uchar DutyCycle,uchar count,uchar partern) //1ms為最小單位
{ uchar i,j;
//脈寬設(shè)置 Wdith
//占空比 X0% DutyCycle
//脈沖個數(shù) count
// pin = ;
k = (Width*10)/DutyCycle; //PWM整個周期
if(partern == 6)
for(i=0;i<k*count;i++)
P1_6= 0;
delay(Width);
P1_6= 1;
delay(k-Width);
if(partern == 7)
for(j=0;j<k*count;j++)
P1_7 = 0;
delay(Width);
P1_7 = 1;
delay(k-Width);
void PWM_Control2( uchar Width, uchar DutyCycle,uchar count,uchar partern) //1ms為最小單位
{ uchar i,j;
//脈寬設(shè)置 Wdith
//占空比 X0% DutyCycle
//脈沖個數(shù) count
// pin = ;
if(partern == 6)
P1_6= 0;
delay(Width);
P1_6= 1;
delay(k-Width);
if(partern == 7)
P1_7= 0;
delay(Width);
P1_7= 1;
delay(k-Width);
/***************按鍵S1,S2調(diào)節(jié)電壓************/
unsigned int Set()
if( S1 == 0)
delay(5);
if(S1 == 0)
v++;
if(S2 == 0)
delay(5);
if(S2 == 0)
v--;
return v;
/*******************設(shè)定值與檢測值比較****************/
void compare()
if(v<50)PWM_Control1(7,7,1,7);else PWM_Control2(7,7,1,6);
uchar i;
ulong sum=0;
uint result;
float h;
lcd1602init();
InitADC();
// v = Set();
lcd_pos(0x00);
lcd1602writedata('V');
lcd1602writedata('=');
lcd1602writedata(5+0x30);
lcd1602writedata(0x2e);
lcd1602writedata(0x30);
lcd_pos(0x08);
lcd1602writedata('S');
lcd1602writedata('e');
lcd1602writedata('t');
/* lcd1602writedata((v/10)+0x30);
lcd1602writedata((v%10)+0x30); */
lcd_pos(0x40);
lcd1602writedata('T');
lcd1602writedata('s');
WriteToReg_ADC(0x44); //自校準(zhǔn)后DRDY返回低電平
Delay_1ms(60);
for(i=0;i<8;i++) //讀取數(shù)據(jù)并轉(zhuǎn)換成電壓
result0[i]=ReadADC_16BitValue(0);
sum=sum+result0[i];
sum=sum/8;
result=(uint)sum;
sum=0;
h=result;
result=h*5000/65536;
Display(result);
result=0;
Delay_1ms(50);
/**********************就是這個函數(shù)********************/
/*******************同樣在主循環(huán)中,display正常,但這個display2不顯示***********/
v = Set();
Display2(); //Display2函數(shù)寫在主循環(huán)中但LCD卻不顯示
Delay_1ms(5);
compare();// 判定設(shè)定值與檢測值大小,從而輸出PWM1或PWM2 (P1^6或P1^7)
Delay_1ms(5);
// Delay_1ms(500);
/* WriteToReg_ADC(0x21);
Delay_1ms(60);
for(i=0;i<8;i++)
result1[i]=ReadADC_16BitValue(1);
sum=sum+result1[i];
sum=sum/8;
result=(uint)sum;
sum=0;
h=result;
Display1(result);
result=0;
// Delay_1ms(500); */
date[2]= (AD_data)/1000;
date[1]= (AD_data)/100%10;
date[0]= (AD_data)/10%10;
lcd_pos(0x45);
lcd1602writedata(0x30+date[2]);
lcd1602writedata(0x30+date[1]);
lcd1602writedata(0x30+date[0]);
/*void Display1(uint AD_data)
lcd_pos(0x49);
/****************就是這個Display2函數(shù)*********************/
void Display2()
{ v = Set();
lcd_pos(0x13);
