unsigned char code Segs_tab[]={
0xe0,0xe1,0xe2,0xe3,0xe4,0xe5,0xe6,0xe7,0xe8,0xe9,0xea,0xeb,0xec,0xed,0xee,0xef,
0xd0,0xd1,0xd2,0xd3,0xd4,0xd5,0xd6,0xd7,0xd8,0xd9,0xda,0xdb,0xdc,0xdd,0xde,0xdf,
0xb0,0xb1,0xb2,0xb3,0xb4,0xb5,0xb6,0xb7,0xb8,0xb9,0xba,0xbb,0xbc,0xbd,0xbe,0xbf,
0x70,0x71,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7a,0x7b,0x7c,0x7d,0x7e,0x7f,
unsigned char idata Rec_buf[64]={
0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
sbit Rest=P3^0;
void IO_Interrupt_UART_Init();
unsigned char T1_count=0,Anm1=0,Mode=0,Rec_count=0;
unsigned int End,Anm=0;
End=sizeof(table);
if(Anm>End)Anm=0;
Segs=Segs_tab[Anm1];
switch (Mode)
case 0:Out=table[Anm1+Anm];break;
case 1:Out=Rec_buf[Anm1];break;
default:break;
P0M1=0x00;
P0M0=0x00;
P1M1=0x00;
P1M0=0xff;
EA=1;
EX0=1;
IT0=1;
ET0=1;
ET1=1;
ES=1;
AUXR |= 0x80; //定時器時鐘1T模式
TMOD &= 0xF0; //設(shè)置定時器模式
TL0 = 0x5C; //設(shè)置定時初值
TH0 = 0xF7; //設(shè)置定時初值
TF0 = 0; //清除TF0標志
TR0 = 1; //定時器0開始計時
AUXR &= 0xBF; //定時器時鐘12T模式
TMOD &= 0x0F; //設(shè)置定時器模式
TL1 = 0x00; //設(shè)置定時初值
TH1 = 0x70; //設(shè)置定時初值
TF1 = 0; //清除TF1標志
TR1 = 1; //定時器1開始計時
SCON = 0x50; //8位數(shù)據(jù),可變波特率
AUXR |= 0x04; //定時器2時鐘為Fosc,即1T
T2L = 0xD0; //設(shè)定定時初值
T2H = 0xFF; //設(shè)定定時初值
AUXR |= 0x01; //串口1選擇定時器2為波特率發(fā)生器
void Button() interrupt 0
Mode=Mode+1;
if(Mode==1)
AUXR |= 0x10;
ET1=0;
TR1=0;
Anm=0;
Anm1=0;
if(Mode>1)IAP_CONTR=0x60;
void Display_delay() interrupt 1
TR0=0;
Anm1=Anm1+1;
if(Anm1>63)Anm1=0;
Out=0x00;
Segs=0xff;
TR0=1;
void LED_Display() interrupt 3
TR1=0;
T1_count++;
if(T1_count==Anm_speed)
T1_count=0;
Anm=Anm+64;
TR1=1;
void uart_receive() interrupt 4
unsigned char ch;
ES=0;
if(RI)
ch=SBUF;
Rec_buf[Rec_count]=ch;
Rec_count++;
if(Rec_count>63)Rec_count=0;
RI=0;
ES=1;
