只需一步,快速開(kāi)始
查看: 10090|回復(fù): 11
做了一個(gè)超聲波測(cè)距報(bào)警器
ID:168149 發(fā)表于 2017-7-1 10:35 | 顯示全部樓層 |閱讀模式
Trig -------  P2^1;
Echo -------  P2^0;
VCC  -------- +5v
GND  -------- GND
請(qǐng)?jiān)谏想娭埃瑱z查好接線(xiàn)是否正確。
可以按鍵調(diào)節(jié)報(bào)警距離,LCD顯示當(dāng)前距離
單片機(jī)源程序如下:
  1. #include<reg51.h>
  2. #include<intrins.h>
  3. #include"lcd.h"
  4. sbit Trig = P2^1;
  5. sbit Echo = P2^0;
  6. sbit LED5 = P2^7;
  7. sbit beep = P1^5;
  8. sbit jia_key=P3^2;
  9. sbit jian_key=P3^3;
  10. sbit Reset_key = P3^0;
  11. //全局變量 ,音符索引數(shù)
  12. unsigned char musicNum;
  13. //音符播放時(shí)定時(shí)寄存器處值TH0
  14. unsigned char code high_buff[] = {240,229,240, 229,240, 229};
  15. //音符播放時(shí)定時(shí)寄存器處值TL0
  16. unsigned char code low_buff[] = {6,13,6,13,6,13};
  17. unsigned char arm[]=" Alarm ";
  18. unsigned char arm1[]=" NowDis ";
  19. unsigned char num=0;
  20. unsigned char code ASCII[15] = {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
  21. static unsigned char DisNum = 0;
  22.        unsigned int  time=0;
  23.            unsigned long S=0;
  24.            unsigned long m=20;
  25.            bit      flag =0;
  26.            unsigned char disbuff[4]           ={0,0,0,0,};
  27.            unsigned char disbuff1[4]   ={0,0,0,0,} ;
  28. /*延時(shí)函數(shù)單位為毫秒*/
  29. void delayms(unsigned int ms)
  30. {
  31.         unsigned char i=100,j;
  32.         for(;ms;ms--)
  33.         {
  34.                 while(--i)
  35.                 {
  36.                         j=10;
  37.                         while(--j);
  38.                 }
  39.         }
  40. }
  41. //延時(shí)函數(shù)用于蜂鳴器的延時(shí)
  42. void delayfm(unsigned int x)
  43. {
  44.   unsigned char i;
  45. while(x--)
  46. {
  47.    for(i = 0;i < 120;i++);
  48. }
  49. }
  50. /*蜂鳴器主函數(shù)*/
  51. void fengmingqi(void)
  52. {
  53.         // TMOD = 0x00;    //定時(shí)器0工作在模式0
  54.          TH1 = (8192 - 700) / 32;  //定時(shí)器賦初值
  55.          TL1 = (8192 - 700) % 32;
  56.         // EA = 1;       //開(kāi)總中斷
  57.          ET1 = 1;      //開(kāi)定時(shí)器0定時(shí)溢出中斷
  58.          beep = 0;
  59.           for(musicNum = 1;musicNum < 6;musicNum++)
  60.           {
  61.             TR1 = 1;
  62.             delayfm(500);
  63.             TR1 = 0;
  64.             delayfm(50);
  65.           }
  66.
  67. }
  68. //無(wú)源蜂鳴器中斷采用t1定時(shí)器
  69. void Timer1(void) interrupt 3
  70. {
  71.   //蜂鳴器輸出電平取反
  72.   beep = ~beep;
  73.   TH1 = high_buff[musicNum];
  74.   TL1 = low_buff[musicNum];
  75. }
  76. /*計(jì)數(shù)程序用于將超聲波發(fā)出的信號(hào)時(shí)間與收到的作差通過(guò)計(jì)算公式從而求出距離*/
  77. void Conut(void)
  78.         {
  79.          time=TH0*256+TL0;
  80.          TH0=0;
  81.          TL0=0;
  82.
  83.          S=(time*1.7)/100;     //算出來(lái)是CM
  84.          if((S>=700)||flag==1) //超出測(cè)量范圍顯示“-”
  85.          {
  86.           flag=0;
  87.
  88.           DisplayOneChar(0+9, 1, ASCII[11]);
  89.           DisplayOneChar(1+9, 1, ASCII[10]);        //顯示點(diǎn)
  90.           DisplayOneChar(2+9, 1, ASCII[11]);
  91.           DisplayOneChar(3+9, 1, ASCII[11]);
  92.           DisplayOneChar(4+9, 1, ASCII[12]);        //顯示M
  93.          }
  94.          else
  95.          {
  96.           disbuff[0]=S%1000/100;
  97.           disbuff[1]=S%1000%100/10;
  98.           disbuff[2]=S%1000%10 %10;
  99.           DisplayOneChar(0+9, 1, ASCII[disbuff[0]]);
  100.           DisplayOneChar(1+9, 1, ASCII[10]);        //顯示點(diǎn)
  101.           DisplayOneChar(2+9, 1, ASCII[disbuff[1]]);
  102.           DisplayOneChar(3+9, 1, ASCII[disbuff[2]]);
  103.           DisplayOneChar(4+9, 1, ASCII[12]);        //顯示M
  104.
  105.          }
  106.          delayms(80);
  107. }
  108. /*報(bào)警距離顯示函數(shù)*/
  109. void dispose()
  110. {
  111.                           disbuff1[0]=m%1000/100;
  112.                           disbuff1[1]=m%1000%100/10;
  113.                           disbuff1[2]=m%1000%10 %10;
  114.                           DisplayOneChar(0+9, 0, ASCII[disbuff1[0]]);
  115.                           DisplayOneChar(1+9, 0, ASCII[10]);        //顯示點(diǎn)
  116.                           DisplayOneChar(2+9, 0, ASCII[disbuff1[1]]);
  117.                           DisplayOneChar(3+9, 0, ASCII[disbuff1[2]]);
  118.                           DisplayOneChar(4+9, 0, ASCII[12]);        //顯示M
  119. }
  120. /*按鍵處理函數(shù)*/
  121. void key()
  122. {
  123.         while(jia_key==0)
  124.         {
  125.                 delayms(10);
  126.                 if(jia_key==0)
  127.                 {
  128.                         m++;
  129.                         dispose();
  130.                         if(m==81)
  131.                         {
  132.                                 m=80;
  133.
  134.                         }
  135.
  136.                 }
  137.         }
  138.         while(jian_key==0)
  139.         {
  140.                 delayms(10);
  141.                 if(jian_key==0)
  142.                 {
  143.                         m--;
  144.                         dispose();
  145.                         if(m==19)
  146.                         {
  147.                                 m=20;
  148.
  149.                         }
  150.
  151.                 }
  152.         }
  153.         while(Reset_key==0)
  154.         {
  155.                 delayms(10);
  156.                 if(Reset_key==0)
  157.                 {
  158.                         m=20;
  159.                         dispose();
  160.                 }
  161.         }
  162.
  163. }
  164. void zd0() interrupt 1                  //T0中斷用來(lái)計(jì)數(shù)器溢出,超過(guò)測(cè)距范圍
  165.   {
  166.     flag=1;                                                         //中斷溢出標(biāo)志
  167.   }
  168. void  StartModule()                          //啟動(dòng)模塊
  169.   {
  170.           Trig=1;                                             //啟動(dòng)一次模塊
  171.           _nop_();
  172.           _nop_();
  173.           _nop_();
  174.           _nop_();
  175.           _nop_();
  176.           _nop_();
  177.           _nop_();
  178.           _nop_();
  179.           _nop_();
  180.           _nop_();
  181.           _nop_();
  182.           _nop_();
  183.           _nop_();
  184.           _nop_();
  185.           _nop_();
  186.           _nop_();
  187.           _nop_();
  188.           _nop_();
  189.           _nop_();
  190.           _nop_();
  191.           _nop_();
  192.           Trig=0;
  193.   }
  194. void main(void)
  195. {
  196.          TMOD=0x01;                   //設(shè)T0為方式1,GATE=1;
  197. ……………………
  198. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
超聲波測(cè)距報(bào)警(LCD1602顯示).zip (48.41 KB, 下載次數(shù): 257)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
ID:640699 發(fā)表于 2019-11-12 20:21 | 顯示全部樓層
感謝樓主分享
ID:617693 發(fā)表于 2019-9-28 19:18 | 顯示全部樓層
太強(qiáng)了感謝
ID:602896 發(fā)表于 2019-9-2 22:08 | 顯示全部樓層
太強(qiáng)了,就是沒(méi)看懂,蜂鳴器主函數(shù)
ID:487508 發(fā)表于 2019-4-4 20:41 | 顯示全部樓層
太強(qiáng)了,瘋狂打扣
ID:448852 發(fā)表于 2018-12-18 13:54 | 顯示全部樓層
好資料,收藏了
ID:448811 發(fā)表于 2018-12-18 13:01 | 顯示全部樓層
感謝分享
ID:448741 發(fā)表于 2018-12-18 11:35 | 顯示全部樓層
感謝分享
ID:241242 發(fā)表于 2018-9-14 19:54 | 顯示全部樓層
感謝分享,正是需要的
ID:392145 發(fā)表于 2018-9-12 20:17 | 顯示全部樓層
怎么沒(méi)有電路圖?
ID:218953 發(fā)表于 2017-7-11 21:35 | 顯示全部樓層
感謝分享~
ID:89286 發(fā)表于 2017-7-2 08:23 | 顯示全部樓層
thanks for sharing
