查看: 3837|回復: 1
FXTH870x6引腳圖規格書pdf下載 飛思卡爾TPMS芯片
飛思卡爾TPMS芯片規格書
FXTH870x6 Tire Pressure Monitor Sensor
FXTH870x6引腳圖如下:
The FXTH870x6 family is comprised of the following functions all within the
same package.
Features
• Pressure sensor with one of two calibrated pressure ranges
— 100 - 450 kPa
— 100 - 900 kPa
• Temperature sensor
• Optional XZ- or Z-axis accelerometer with adjustable offset option
• Voltage reference measured by ADC10
• Six-channel, 10-bit analog-to-digital converter (ADC10) with two external
I/O inputs
• 8-bit MCU
— S08 Core with SIM and interrupt
— 512 RAM
— 8K FLASH (in addition to 8K providing factory firmware and trim
data)
— 64-byte, low-power, parameter registers
完整的pdf格式文檔51黑下載地址(共頁):
FXTH870x6.pdf (1.21 MB, 下載次數: 13)
參與人數 1黑幣 +5 收起 理由
dsh_wang + 5 很給力!
ID:414755 發表于 2018-10-24 17:06 | 只看該作者
我需要這個文檔,謝謝
