查看: 2256|回復(fù): 5
求助一段單片機(jī)代碼 中斷套中斷的
ID:209822 發(fā)表于 2017-6-28 22:24 | 顯示全部樓層 |閱讀模式
代碼目的:單片機(jī)通過定時器0產(chǎn)生中斷 ,定時發(fā)送串口數(shù)據(jù)并接受返回值 通過判斷返回值來判斷SIM900a模塊工作狀態(tài),通過檢測LED5亮 否則LED5熄 ,但是總是不知道哪里的問題 達(dá)不到效果,請大神們指教 單片機(jī)愛好者 初學(xué) 謝謝!代碼如下:
  1. #include <reg52.h>
  2. #include <stdio.h>
  3. #include <string.h>
  4. #define Buf_Max 90
  5. unsigned char i = 0;
  6. unsigned char T0RL =0;
  7. unsigned char T0RH =0;
  8. xdata unsigned char Rec_Buf[Buf_Max];
  9. void init(void);
  10. void GSM_Call(unsigned char *num)
  11. void Delay_ms(unsigned int time);
  12. void CLR_Buf(void);//Çå3y»o′æ
  13. void Send_ASCII(unsigned char *b);
  14. void Send_Hex(unsigned char c);
  15. void work_test(void);
  16. void ConfigTimer0(unsigned int ms);
  17. void ConfigUART(unsigned int baud);
  18.
  19. char code num[]="xxxxxxxxxx";
  20. sbit key1=P1^1;
  21. sbit LED5=P1^5;
  22. void main(void)
  23. {
  24.         EA = 1;
  25.         ConfigUART(9600);
  26.         ConfigTimer0(20);
  27.         CLR_Buf();
  28.         Delay_ms(3000);
  29.
  30.         while(1)
  31.         {
  32.                 if(key1==0)
  33.                 {
  34.                         Delay_ms(20)
  35.                         if(key1==0)
  36.                         {
  37.                                 GSM_Call(num);
  38.                                 Delay_ms(1000);
  39.                         }
  40.                 }
  41.   }
  42. }
  43. void GSM_Call(unsigned char *num)
  44. {
  45.         Send_ASCII("ATD");
  46.         Send_ASCII(num);
  47.         Send_ASCII(";");
  48.   Send_Hex(0x0d);
  49.         Send_Hex(0x0a);
  50.         Delay_ms(200)
  51. }
  52. //oáÃëÑóê±oˉêy
  53. void Delay_ms(unsigned int time)
  54. {
  55.         unsigned int i;
  56.         for(;time>0;time--)
  57.         {
  58.                 i=125;
  59.                 while(i--);
  60.         }
  61. }
  62. void CLR_Buf(void)
  63. {
  64.         unsigned char k;
  65.     for(k=0;k<Buf_Max;k++)
  66.             {
  67.                         Rec_Buf[k] = 0;
  68.                 }
  69.     i = 0;
  70. }
  71. void Send_Hex(unsigned char c)
  72. {
  73.     ES = 0;
  74.     SBUF = c;
  75.     while(TI!=1);
  76.     TI = 0;
  77.           ES = 1;
  78. }
  79. void Send_ASCII(unsigned char *b)
  80. {
  81.   ES = 0;
  82.     for (b; *b!='\0';b++)
  83.             {
  84.                 SBUF = *b;
  85.                 while(TI!=1);
  86.                         TI = 0;
  87.                 }
  88.         ES = 1;
  89. }
  90. void work_test(void)
  91. {
  92.                 Send_ASCII("AT")
  93.           Send_Hex(0x0d);
  94.           Send_Hex(0x0a);
  95.                 Delay_ms(2000);
  96.         if(strstr(Rec_Buf,"OK")!=NULL)
  97.
  98.         {
  99.                 CLR_Buf();
  100.
  101.                 //LED2=0;
  102.
  103.                 Send_ASCII("AT+CPIN?")
  104.                 Send_Hex(0x0d);
  105.                 Send_Hex(0x0a);
  106.                 Delay_ms(2000);
  107.                 if(strstr(Rec_Buf,"+CPIN")!=NULL&&strstr(Rec_Buf,"OK")!=NULL)
  108.                 {
  109.                                 CLR_Buf();
  110.                         //        LED3=0;
  111.
  112.                                 Send_ASCII("AT+CSQ")
  113.                                 Send_Hex(0x0d);
  114.                                 Send_Hex(0x0a);
  115.                                 Delay_ms(2000);
  116.                                 if(strstr(Rec_Buf,"OK")!=NULL)
  117.                                 {
  118.                                         CLR_Buf();
  119.                                 //        LED4=0;
  120.                                         Send_ASCII("AT+CREG?")
  121.                                         Send_Hex(0x0d);
  122.                                         Send_Hex(0x0a);
  123.                                         Delay_ms(2000);
  124.                                         if(strstr(Rec_Buf,"0")!=NULL&&strstr(Rec_Buf,"1")!=NULL&&strstr(Rec_Buf,"OK")!=NULL)
  125.                                         {
  126.
  127.                                                 CLR_Buf();
  128.                                                 Delay_ms(1000);
  129.                                                 LED5 = 0;
  130.                                         }
  131.                                 }
  132.                 }
  133.         }else LED5 = 1;
  134. }
  135. void ConfigUART(unsigned int baud)
  136. {
  137.     SCON  = 0x50;
  138.     TMOD &= 0x0F
  139.     TMOD |= 0x20
  140.     TH1 = 256 - (11059200/12/32)/baud
  141.     TL1 = TH1;
  142.     ET1 = 0;
  143.     ES  = 1;
  144.     TR1 = 1;
  145. }
  146. void ConfigTimer0(unsigned int ms)
  147. {
  148.     unsigned long tmp
  149.     tmp = 11059200 / 12;
  150.     tmp = (tmp * ms) / 1000
  151.     tmp = 65536 - tmp;
  152.     tmp = tmp + 18;
  153.     T0RH = (unsigned char)(tmp>>8);
  154.     T0RL = (unsigned char)tmp;
  155.     TMOD &= 0xF0;
  156.     TMOD |= 0x01;
  157.     TH0 = T0RH;
  158.     TL0 = T0RL;
  159.     ET0 = 1;
  160.     TR0 = 1;
  161. }
  162. void InterruptTimer0() interrupt 1
  163. {
  164. static unsigned int cnt = 0;
  165.         TH0 = T0RH;
  166.         TL0 = T0RL;
  167.         cnt++;
  168.         if(cnt ==50)
  169.         {
  170.                 work_test();
  171.         }
  172.         if(cnt ==800)
  173.         cnt =0;
  174. }
  175. void tinit() interrupt 4
  176. {
  177.         ES = 0;
  178.         if(TI)
  179.                 {
  180.                         TI = 0
  181.                 }
  182.         if(RI)
  183.                 {
  184.                         RI = 0
  185.                         Rec_Buf[i] = SBUF
  186.                         i++;
  187.                         if(i>90)
  188.                                 {
  189.                                         i = 0;
  190.                                 }
  191.                 }
  192.         ES = 1;
  193. }
參與人數(shù) 1黑幣 +1 收起 理由
5664645345 + 1 很給力!
ID:209822 發(fā)表于 2017-6-28 23:16 | 顯示全部樓層
求大神指點(diǎn)  在線等
ID:209822 發(fā)表于 2017-6-29 09:56 | 顯示全部樓層
這么大的論壇有人懂的嗎
ID:215758 發(fā)表于 2017-6-29 11:13 | 顯示全部樓層
你就不能加點(diǎn)備注么?好難審閱啊
ID:123289 發(fā)表于 2017-7-1 01:27 | 顯示全部樓層
1、達(dá)不到效果,已達(dá)到了什么程序呢?
2、串行數(shù)據(jù)丟失風(fēng)險大,其中斷優(yōu)先級可以考慮設(shè)置為最高。
3、中斷服務(wù)程序要盡可能“小”少用時間,以防妨礙其它低級別的中斷。所以,中斷事件盡可不要在中斷服務(wù)程序中處理,而是做個“記號”,讓事件在主程序中進(jìn)行依“記號”處理。
ID:82765 發(fā)表于 2017-7-1 08:57 | 顯示全部樓層
提示: 作者被禁止或刪除 內(nèi)容自動屏蔽
