2017-6-28 17:19 上傳
單片機(jī)源程序如下:
- #include "ds18b20.h"
- #include "smg.h"
- #include "eepom52.h"
- #include"motor_pwm.h"
- sbit Reduc = P3^3; //減
- sbit Add = P3^4; //加
- sbit Mode = P3^5; //設(shè)置
- sbit fs = P3^6;
- uchar m=0;
- uint time_when=0,time_points=0,time_seconds=0,time_100ms=0;
- void Timer0Init(void) //1000微秒@12.000MHz
- TMOD |= 0x01; //設(shè)置定時(shí)器模式
- TL0 = 0x80; //設(shè)置定時(shí)初值
- TH0 = 0xD8; //設(shè)置定時(shí)初值
- TR0 = 1; //timer0 start running
- ET0 = 1; //enable timer0 interrupt
- EA = 1; //open global interrupt switch
- void tm0_isr() interrupt 1 using 1
- time_100ms++;
- if (time_100ms==99)
- time_100ms = 0;
- time_seconds++;
- m=~m;
- if (time_seconds==60)
- time_seconds=0;
- time_points++;
- if (time_points==60)
- time_points=0;
- time_when++;
- if (time_when==24)
- TR0 = 0;
- void main(void)
- uint T_tada;//溫度數(shù)據(jù)變量
- char T_L=2,T_H=0;
- uchar Mode_project=1,key_count=0;//設(shè)置變量
- uint disp_count=300;//顯示300次采集一次溫度數(shù)據(jù),解決采集時(shí)閃爍
- uchar temp_disp[4];//數(shù)據(jù)緩存
- /****DS18B20檢測(cè),沒有檢測(cè)到數(shù)碼管顯示四個(gè)‘----’****/
- while(reset())
- disp_count=100;while(disp_count--){SMG_setxy(1,11,0);SMG_setxy(2,11,0);SMG_setxy(3,11,0);SMG_setxy(4,11,0);}
- disp_count=100;while(disp_count--){SMG_setxy(1,10,0);SMG_setxy(2,10,0);SMG_setxy(3,10,0);SMG_setxy(4,10,0);}
- /****開機(jī)采集溫度,避免第一次讀取溫度為85度誤報(bào)警****/
- disp_count=30;
- while(disp_count--)
- T_tada=read_temp();
- /***開機(jī)把數(shù)據(jù)從單片機(jī)內(nèi)部eepom中讀出來(lái)***/
- if(byte_read(0x2050)!=0)
- SectorErase(0x2000);
- byte_write(0x2000,T_L);
- byte_write(0x2001,T_H);
- byte_write(0x2050,1);
- if(byte_read(0x2050)==1)
- T_L=byte_read(0x2000);
- T_H=byte_read(0x2001);
- Timer0Init();
- pwm_init();
- while(1)
- temp_disp[0]=time_when/10;
- temp_disp[1]=time_when%10;
- temp_disp[2]=time_points/10;
- temp_disp[3]=time_points%10;
- /*******加速*******/
- if(Add==0)
- //利用顯示延時(shí)
- key_count=60;
- while(key_count--)
- SMG_setxy(1,temp_disp[0],0);
- SMG_setxy(2,temp_disp[1],m);
- SMG_setxy(3,temp_disp[2],0);
- SMG_setxy(4,temp_disp[3],0);
- speed+=5;
- if(speed>=100)speed=100;
- /*******減速*******/
- if(Reduc==0)
- //利用顯示延時(shí)
- key_count=60;
- speed-=5;
- if(speed<=0)speed=0;
- if(T_tada>3500)//溫度大于35度,打開風(fēng)扇
- fs=1;
- else
- fs=0;
- if(T_H==time_when && T_L==time_points && time_seconds<0x01)
- EA=0;
- M1=0;
- // temp_disp[2]=time_seconds/10;
- // temp_disp[3]=time_seconds%10;
- /****溫度數(shù)據(jù)采集****/
- loop:
- if(++disp_count>=3000)
- disp_count=0;
- TR1=0;T_tada=read_temp();if(speed==0)TR1=1;
- // if(T_tada>20000)//負(fù)數(shù)
- // temp_disp[0]=11;
- // T_tada-=20000;
- // else temp_disp[0]=T_tada/10000; //正數(shù)溫度百位
- // temp_disp[1]=T_tada/1000%10; //溫度十位
- // temp_disp[2]=T_tada/100%10;//溫度個(gè)位
- // temp_disp[3]=T_tada/10%10;//溫度小數(shù)第一位
- // if(temp_disp[0]==0)temp_disp[0]=10;//百位消隱
- /****數(shù)碼管掃描顯示****/
- /****按下設(shè)置鍵,設(shè)置參數(shù)****/
- if(Mode==0)
- Mode_project=1;
- while(Mode==0);//按鍵松開
- while(1)
- //設(shè)置頁(yè)面顯示
- switch(Mode_project)
- case 1:
- SMG_setxy(1,12,0);
- SMG_setxy(2,11,0);
- SMG_setxy(3,T_H/10,0);
- SMG_setxy(4,T_H%10,0);
- break;
- case 2:
- SMG_setxy(1,13,0);
- SMG_setxy(3,T_L/10,0);
- SMG_setxy(4,T_L%10,0);
- break;
- //按下加鍵,對(duì)設(shè)定目標(biāo)加
- if(Add==0)
- //利用顯示延時(shí)
- key_count=60;
- case 1:
- break;
- case 2:
- break;
- case 1:T_H+=1;if(T_H>=100)T_H=100;break;
- case 2:T_L+=1;if(T_L>=100)T_L=100;break;
- //按下減鍵,對(duì)設(shè)定目標(biāo)減
- if(Reduc==0)
- //利用顯示延時(shí)
- key_count=60;
- case 1:
- break;
- case 2:
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
程序.rar
(48.04 KB, 下載次數(shù): 16)
2017-6-28 15:07 上傳
點(diǎn)擊文件名下載附件
具體程序 下載積分: 黑幣 -5
