查看: 3651|回復: 0
請問請問這段代碼中的變量TCount是什么意思?該程序中是怎么實現加速減速的?謝謝...
ID:214531 發表于 2017-6-25 20:55 | 顯示全部樓層 |閱讀模式
//可調控的跑馬燈
#include<reg52.h>
uchar ModeNo;//模式
uint Speed;
uchar TCount=0;////////////?????????????
uchar Idx;
uchar mb_Count=0;
bit Dirtect=1;
uchar code DSY_CODE[]={0xC0,0XF9, 0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
uint code sTable[]={0,1,3,5,7,9,15,100,200,230,300,350};
void Delay(uint x)
uchar i;
while(x--) for(i=0;i<120;i++);
uchar GetKey()//獲取按鍵信息
uchar K;
if(P2==0xFF) return 0;
Delay(10);
switch(P2)
{                         case 0xFE: K=1;break;                         case 0xFD: K=2;break;                         case 0xFB: K=3;break;                         default:   K=0;
}                         while (P2!=0xFF);                         return K;
void Led_Demo(uint Led16)
P1=(uchar)(Led16&0x00FF);
P0=(uchar)(Led16>>8);
void T0_INT() interrupt 1//模式內容
if(++TCount<Speed) return;/////////////////////?????????
TCount=0;
switch(ModeNo)
case 0:Led_Demo(0x0001<<mb_Count);break;
case 1:Led_Demo(0x8000>>mb_Count);break;
case 2:if(Dirtect)Led_Demo(0x000F<<mb_Count);
Else
Led_Demo(0xF000>>mb_Count);
if(mb_Count==15) Dirtect=!Dirtect;break;
case 3:if(Dirtect)Led_Demo(~(0x000F<<mb_Count));
else                          Led_Demo(~(0xF000>>mb_Count));
break;
case 4:if(Dirtect)Led_Demo(0x003F<<mb_Count);
else                          Led_Demo(0xFC00>>mb_Count);
case 5:if(Dirtect)Led_Demo(0x0001<<mb_Count);
else                   Led_Demo(0x8000>>mb_Count);
break;
case 6:if(Dirtect)Led_Demo(~(0x0001<<mb_Count));
else                   Led_Demo(~(0x8000>>mb_Count));
case 7:if(Dirtect)Led_Demo(0xFFFE<<mb_Count);
else                   Led_Demo(0x7FFF>>mb_Count);
default:break;
mb_Count=(mb_Count+1)%16;
void KeyProcess(uchar Key)//按鍵處理選擇模式
switch(Key)
{                         case 1:
Dirtect=1;mb_Count=0;
ModeNo=(ModeNo+1)%8;
P3=DSY_CODE[ModeNo];break;                         case 2:
if(Idx>1) Speed=sTable[--Idx];break;                         case 3:
if(Idx<15) Speed=sTable[++Idx];
uchar Key;
P0=P1=P2=P3=0xFF;
ModeNo=0;Idx=4;
IE=0x82;
TMOD=0x00;
TR0=1;
Key=GetKey();
if(Key!=0) KeyProcess(Key);
