SHT30是盛世瑞最新出品的低端低價溫濕度傳感器,在精度和尺寸上都優(yōu)于SHT20.
附件是SHT30的STM8驅(qū)動,用的是庫函數(shù),自己寫的,可行。
- // S E N S I R I O N AG, Laubisruetistr. 44, CH-8712 Staefa, Switzerland
- // Project : SHT3x Sample Code (V1.0)
- // File : sht3x.c (V1.0)
- // Author : RFU
- // Date : 16-Jun-2014
- // Controller: STM32F100RB
- // IDE : 礦ision V4.71.2.0
- // Compiler : Armcc
- // Brief : Sensor Layer: Implementation of functions for sensor access.
- //-- Includes ------------------------------------------------------------------
- #include "sht3x.h"
- #include "iic.h"
- //-- Defines -------------------------------------------------------------------
- // CRC
- #define POLYNOMIAL 0x131 // P(x) = x^8 + x^5 + x^4 + 1 = 100110001
- // IO-Pins /* -- adapt the defines for your uC -- */
- // Reset on port B, bit 12
- #define RESET_LOW() (GPIOB->BSRR = 0x10000000) // set Reset to low
- #define RESET_HIGH() (GPIOB->BSRR = 0x00001000) // set Reset to high
- // Alert on port B, bit 10
- #define ALERT_READ (GPIOB->IDR & 0x0400) // read Alert
- //-- Global variables ----------------------------------------------------------
- u8t _i2cWriteHeader=0x88;
- u8t _i2cReadHeader=0x89;
- void SHT3X_Init(u8t i2cAdr){ /* -- adapt the init for your uC -- */
- // init I/O-pins
- RCC->APB2ENR |= 0x00000008; // I/O port B clock enabled
- GPIOB->CRH &= 0xFFFFF0FF; // set floating input for Alert-Pin
- GPIOB->CRH |= 0x00000400; //
- GPIOB->CRH &= 0xFFF0FFFF; // set push-pull output for Reset pin
- GPIOB->CRH |= 0x00010000; //
- RESET_LOW();
- // I2c_Init(); // init I2C
- SHT3X_SetI2cAdr(i2cAdr); //
- // release reset
- // RESET_HIGH();
- void SHT3X_SetI2cAdr(u8t i2cAdr){
- _i2cWriteHeader = i2cAdr << 1;
- _i2cReadHeader = _i2cWriteHeader | 0x01;
- u8t SHT3x_ReadSerialNumber(u32t *serialNbr){
- u8t error; // error code
- u16t serialNumWords[2];
- error = SHT3X_StartWriteAccess();
- // write "read serial number" command
- error |= SHT3X_WriteCommand(CMD_READ_SERIALNBR);
- // if no error, start read access
- if(error == NO_ERROR) error = SHT3X_StartReadAccess();
- // if no error, read first serial number word
- if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(&serialNumWords[0], ACK, 100);
- // if no error, read second serial number word
- if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(&serialNumWords[1], NACK, 0);
- SHT3X_StopAccess();
- // if no error, calc serial number as 32-bit integer
- *serialNbr = (serialNumWords[0] << 16) | serialNumWords[1];
- return error;
- u8t SHT3X_ReadStatus(u16t *status){
- // if no error, write "read status" command
- if(error == NO_ERROR) error = SHT3X_WriteCommand(CMD_READ_STATUS);
- // if no error, read status
- if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(status, NACK, 0);
- return error;
- u8t SHT3X_ClearAllAlertFlags(void){
- // if no error, write clear status register command
- if(error == NO_ERROR) error = SHT3X_WriteCommand(CMD_CLEAR_STATUS);
- return error;
- u8t SHT3X_GetTempAndHumi(ft *temp,
- ft *humi,
- etRepeatab repeatab,
- etMode mode,
- u8t timeout){
- u8t error;
- switch(mode)
- case MODE_CLKSTRETCH: // get temperature with clock stretching mode
- error = SHT3X_GetTempAndHumiClkStretch(temp, humi, repeatab, timeout); break;
- case MODE_POLLING: // get temperature with polling mode
- error = SHT3X_GetTempAndHumiPolling(temp, humi, repeatab, timeout); break;
- default:
- error = PARM_ERROR; break;
- return error;
- u8t SHT3X_GetTempAndHumiClkStretch(ft *temp,
- ft *humi,
- u8t timeout){
- u16t rawValueTemp; // temperature raw value from sensor
- u16t rawValueHumi; // humidity raw value from sensor
- // if no error ...
- // start measurement in clock stretching mode
- // use depending on the required repeatability, the corresponding command
- switch(repeatab)
- case REPEATAB_LOW: error = SHT3X_WriteCommand(CMD_MEAS_CLOCKSTR_L); break;
- case REPEATAB_MEDIUM: error = SHT3X_WriteCommand(CMD_MEAS_CLOCKSTR_M); break;
- case REPEATAB_HIGH: error = SHT3X_WriteCommand(CMD_MEAS_CLOCKSTR_H); break;
- default: error = PARM_ERROR; break;
- // if no error, read temperature raw values
- if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(&rawValueTemp, ACK, timeout);
- // if no error, read humidity raw values
- if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(&rawValueHumi, NACK, 0);
- // if no error, calculate temperature in 癈 and humidity in %RH
- *temp = SHT3X_CalcTemperature(rawValueTemp);
- *humi = SHT3X_CalcHumidity(rawValueHumi);
- return error;
- u8t SHT3X_GetTempAndHumiPolling(ft *temp,
- ft *humi,
- u8t timeout){
- // start measurement in polling mode
- switch(repeatab)
- case REPEATAB_LOW: error = SHT3X_WriteCommand(CMD_MEAS_POLLING_L); break;
- case REPEATAB_MEDIUM: error = SHT3X_WriteCommand(CMD_MEAS_POLLING_M); break;
- case REPEATAB_HIGH: error = SHT3X_WriteCommand(CMD_MEAS_POLLING_H); break;
- // if no error, wait until measurement ready
- // poll every 1ms for measurement ready until timeout
- while(timeout--)
- // check if the measurement has finished
- error = SHT3X_StartReadAccess();
- // if measurement has finished -> exit loop
- if(error == NO_ERROR) break;
- // delay 1ms
- DelayMicroSeconds(1000);
- // check for timeout error
- if(timeout == 0) error = TIMEOUT_ERROR;
- // if no error, read temperature and humidity raw values
- error |= SHT3X_Read2BytesAndCrc(&rawValueTemp, ACK, 0);
- error |= SHT3X_Read2BytesAndCrc(&rawValueHumi, NACK, 0);
- return error;
- u8t SHT3X_StartPeriodicMeasurment(etRepeatab repeatab,
- etFrequency freq){
- // if no error, start periodic measurement
- // use depending on the required repeatability and frequency,
- // the corresponding command
- switch(repeatab)
- case REPEATAB_LOW: // low repeatability
- switch(freq)
- case FREQUENCY_HZ5: // low repeatability, 0.5 Hz
- error |= SHT3X_WriteCommand(CMD_MEAS_PERI_05_L); break;
- case FREQUENCY_1HZ: // low repeatability, 1.0 Hz
- error |= SHT3X_WriteCommand(CMD_MEAS_PERI_1_L); break;
- case FREQUENCY_2HZ: // low repeatability, 2.0 Hz
- error |= SHT3X_WriteCommand(CMD_MEAS_PERI_2_L); break;
- case FREQUENCY_4HZ: // low repeatability, 4.0 Hz
- error |= SHT3X_WriteCommand(CMD_MEAS_PERI_4_L); break;
- case FREQUENCY_10HZ: // low repeatability, 10.0 Hz
- error |= SHT3X_WriteCommand(CMD_MEAS_PERI_10_L); break;
- default:
- error |= PARM_ERROR; break;
- break;
- case REPEATAB_MEDIUM: // medium repeatability
- switch(freq)
- case FREQUENCY_HZ5: // medium repeatability, 0.5 Hz
- error |= SHT3X_WriteCommand(CMD_MEAS_PERI_05_M); break;
- case FREQUENCY_1HZ: // medium repeatability, 1.0 Hz
- error |= SHT3X_WriteCommand(CMD_MEAS_PERI_1_M); break;
- case FREQUENCY_2HZ: // medium repeatability, 2.0 Hz
- error |= SHT3X_WriteCommand(CMD_MEAS_PERI_2_M); break;
- case FREQUENCY_4HZ: // medium repeatability, 4.0 Hz
- error |= SHT3X_WriteCommand(CMD_MEAS_PERI_4_M); break;
- case FREQUENCY_10HZ: // medium repeatability, 10.0 Hz
- error |= SHT3X_WriteCommand(CMD_MEAS_PERI_10_M); break;
- default:
- break;
- case REPEATAB_HIGH: // high repeatability
- switch(freq)
- case FREQUENCY_HZ5: // high repeatability, 0.5 Hz
- error |= SHT3X_WriteCommand(CMD_MEAS_PERI_05_H); break;
- case FREQUENCY_1HZ: // high repeatability, 1.0 Hz
- error |= SHT3X_WriteCommand(CMD_MEAS_PERI_1_H); break;
- case FREQUENCY_2HZ: // high repeatability, 2.0 Hz
- error |= SHT3X_WriteCommand(CMD_MEAS_PERI_2_H); break;
- case FREQUENCY_4HZ: // high repeatability, 4.0 Hz
- error |= SHT3X_WriteCommand(CMD_MEAS_PERI_4_H); break;
- case FREQUENCY_10HZ: // high repeatability, 10.0 Hz
- error |= SHT3X_WriteCommand(CMD_MEAS_PERI_10_H); break;
- default:
- break;
- default:
- return error;
- u8t SHT3X_ReadMeasurementBuffer(ft *temp, ft *humi){
- // if no error, read measurements
- if(error == NO_ERROR) error = SHT3X_WriteCommand(CMD_FETCH_DATA);
- if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(&rawValueTemp, ACK, 0);
- if(1) error = SHT3X_Read2BytesAndCrc(&rawValueHumi, NACK, 0);
- //if(error == NO_ERROR)
- return error;
- u8t SHT3X_EnableHeater(void){
- // if no error, write heater enable command
- if(error == NO_ERROR) error = SHT3X_WriteCommand(CMD_HEATER_ENABLE);
- return error;
- u8t SHT3X_DisbaleHeater(void){
- // if no error, write heater disable command
- if(error == NO_ERROR) error = SHT3X_WriteCommand(CMD_HEATER_DISABLE);
- return error;
- u8t SHT3X_SoftReset(void){
- // write reset command
- error |= SHT3X_WriteCommand(CMD_SOFT_RESET);
- // if no error, wait 50 ms after reset
- if(error == NO_ERROR) DelayMicroSeconds(50000);
- return error;
- void SHT3X_HardReset(void){
- // set reset low
- //RESET_LOW();
- // wait 100 ms
- DelayMicroSeconds(100000);
- // release reset
- //RESET_HIGH();
- // wait 50 ms after reset
- DelayMicroSeconds(50000);
- u8t SHT3X_StartWriteAccess(void){
- // write a start condition
- I2C_START();
- // write the sensor I2C address with the write flag
- error = I2C_TX(_i2cWriteHeader);
- return error;
- u8t SHT3X_StartReadAccess(void){
- I2C_START();
- // write the sensor I2C address with the read flag
- error = I2C_TX(_i2cReadHeader);
- return error;
- void SHT3X_StopAccess(void){
- // write a stop condition
- I2C2_Stop();
- u8t SHT3X_WriteCommand(etCommands cmd){
- // write the upper 8 bits of the command to the sensor
- error = I2C_TX(cmd >> 8);
- // write the lower 8 bits of the command to the sensor
- error |= I2C_TX(cmd & 0xFF);
- return error;
- u8t SHT3X_Read2BytesAndCrc(u16t *data, etI2cAck finaleAckNack, u8t timeout){
- u8t bytes[2]; // read data array
- u8t checksum; // checksum byte
- // read two data bytes and one checksum byte
- error = I2c_ReadByte(&bytes[0], ACK, timeout);
- if(error == NO_ERROR) error = I2c_ReadByte(&bytes[1], ACK, 0);
- if(error == NO_ERROR) error = I2c_ReadByte(&checksum, finaleAckNack, 0);
- bytes[0]=I2C_RX(ACK);
- bytes[1]=I2C_RX(ACK);
- checksum=I2C_RX(finaleAckNack);
- // verify checksum
- if(error == NO_ERROR) error = SHT3X_CheckCrc(bytes, 2, checksum);
- // combine the two bytes to a 16-bit value
- *data = (bytes[0] << 8) | bytes[1];
- return error;
- u8t SHT3X_Write2BytesAndCrc(u16t data){
- bytes[0] = data >> 8;
- bytes[1] = data & 0xFF;
- checksum = SHT3X_CalcCrc(bytes, 2);
- // write two data bytes and one checksum byte
- error = I2C_TX(bytes[0]); // write data MSB
- if(error == NO_ERROR) error = I2C_TX(bytes[1]); // write data LSB
- if(error == NO_ERROR) error = I2C_TX(checksum); // write checksum
- return error;
- u8t SHT3X_CalcCrc(u8t data[], u8t nbrOfBytes){
- u8t bit; // bit mask
- u8t crc = 0xFF; // calculated checksum
- u8t byteCtr; // byte counter
- // calculates 8-Bit checksum with given polynomial
- for(byteCtr = 0; byteCtr < nbrOfBytes; byteCtr++)
- crc ^= (data[byteCtr]);
- for(bit = 8; bit > 0; --bit)
SHT3X.zip
(6.78 KB, 下載次數(shù): 338)
2017-6-20 11:05 上傳
