查看: 7068|回復: 5
自制8x32點陣時鐘,帶誤差調整,可用麻將筒子顯示
ID:168911 發表于 2017-6-20 08:47 | 顯示全部樓層 |閱讀模式
IMG_20170620_084049.jpg IMG_20170617_102216.jpg IMG_20170617_101858.jpg IMG_20170619_194336.jpg IMG_20170617_102011.jpg IMG_20170617_102151.jpg IMG_20170617_102226.jpg IMG_20170617_102249.jpg IMG_20170617_101942.jpg IMG_20170617_101738.jpg IMG_20170617_101730.jpg IMG_20170617_101717.jpg 程序是網上8x16點陣滾動時鐘修改而來,在此謝謝原創。
#include <REGX51.H> unsigned char sec=0,min=0,hou=12,st=0x00,timecount=0,oldP1=0xff,setting=0;
bit point=1,K1_old,K2_old;
unsigned char code dis_code[]=
{ 0x3E,0x41,0x41,0x3E,0x21,0x7F,0x01,0x00,//0與1
  0x23,0x45,0x49,0x31,0x22,0x41,0x49,0x36, //2與3
  0x1E,0x22,0x7F,0x02,0x72,0x51,0x51,0x4E, //4與5
  0x3E,0x49,0x49,0x26,0x60,0x40,0x4F,0x70,  //6與7
  0x36,0x49,0x49,0x36,0x32,0x49,0x49,0x3E,  //8與9
  0x3E,0x2A,0x3E,0x40,0x49,0xFE,0x40,0x00,        //時
  0x00,0x18,0x18,0x7E,0x7E,0x18,0x18,0x00,                   //+
  0x00,0x18,0x18,0x18,0x18,0x18,0x18,0x00,                        //-
  0x10,0x21,0x4A,0x0C,0x49,0x2F,0x20,0x00,        //分
  0x32,0x49,0x49,0x26,0x00,0x40,0x7F,0x40,        //st
unsigned char code disp_code[]=
{ 0x7F,0x41,0x7F,0x00,0x00,0x08,0x00,0x00,
  0x00,0x41,0x00,0x00,0x01,0x08,0x40,0x00,
  0x41,0x00,0x41,0x00,0x41,0x08,0x41,0x00,
  0x45,0x00,0x45,0x00,0x15,0x20,0x45,0x00,
  0x55,0x00,0x55,0x00,0x49,0x49,0x49,0x00,
sbit  K1=P1^7;
sbit  K2=P1^6;
void time50ms(void);
void delay_ms(void);
void timedeal(void);
void main(void)
        unsigned char num,disnum,x,y,offset=0,dis_p,scantimes=0;
        IE=0x82;     //允許定時器0工作
        TMOD=0x01;   //timer0為模式1
        TR0=1;       //定時器0可以工作
        TH0 = 0x4c;
        TL0 = 0x00|(st);
        do
                if(setting==0)         //正常顯示狀態
                           for(x=0;x<16;x++)  //
                                dis_p=x;
                                 if(dis_p==3|| dis_p==8|| dis_p==10|| dis_p==15||dis_p>15)         //空列
                                         y=0;
                                 else if(dis_p<=2) //0~2為時的十位
                                          num=hou/10;
                                          if(num>0)
                                          y=dis_code[num*4+dis_p];
                                        y=0;
                                  else if(dis_p<=7) //4~7為時的個位
                                          num=hou%10;
                                          y=dis_code[num*4+dis_p-4];
                                  else if(dis_p<=9)        //9為冒號的顯示位
                                     if(point)
                                          y=0x63;
                                          y=0;
                                  else if(dis_p<=14)         //11~14為分的十位
                                          num=min/10;
                                          y=dis_code[num*4+dis_p-11];
                                P3=0;
                                P1=x|0xE0;
                                P3=y;
                                   delay_ms();
                        for(x=0;x<16;x++)
                                dis_p=x;
                                 if(dis_p==4 || dis_p==6||dis_p==11||dis_p==16||dis_p>16 )         //空列
                                         y=0;
                                   else if(dis_p<=3)                 //0~3為分的個位
                                          num=min%10;
                                else if(dis_p<=5)        //5為冒號的顯示位
                                     if(point)
                                          y=0x63;
                                          y=0;
                                else  if(dis_p<=10)          //7~10為秒的十位
                                        num=sec/10;
                                        y=dis_code[num*4+dis_p-7];
                                else if(dis_p<=15) //12~15為秒的個位
                                          num=sec%10;
                                          y=dis_code[num*4+dis_p-12];
                                  P3=0;
                                 P1=x|0xd0;
                                  P3=y;
                                   delay_ms();              //刷新
/**********************************************************************///以下麻將
                else if(setting==1)         //正常顯示狀態
                                dis_p=x;
                                         y=0;
                                          num=hou/10;
                                          if(num>0)
                                          y=disp_code[num*4+dis_p];
                                        y=0;
                                          num=hou%10;
                                          y=disp_code[num*4+dis_p-4];
                                     if(point)
                                          y=0x63;
                                          y=0;
                                          num=min/10;
                                          y=disp_code[num*4+dis_p-11];
                                P3=0;
                                P1=x|0xE0;
                                P3=y;
                                   delay_ms();
                        for(x=0;x<16;x++)
                                dis_p=x;
                                         y=0;
                                          num=min%10;
                                     if(point)
                                          y=0x63;
                                          y=0;
                                        num=sec/10;
                                        y=disp_code[num*4+dis_p-7];
                                          num=sec%10;
                                          y=disp_code[num*4+dis_p-12];
                                  P3=0;
                                 P1=x|0xd0;
                                  P3=y;
                                   delay_ms();              //刷新
                else         //當進入調整時間的狀態,運行下面的程序段
                         for(x=0;x<16;x++)
                                 if(setting==2)
                                 if(x<16)                          //前16列顯示漢字+時
                                if(point)
                            y=dis_code[24+setting*8+x];
                                y=0;
                                if(setting==3)
                                 if(x<16)                          //前16列顯示漢字-時
                                if(point)
                            y=dis_code[32+setting*8+x];
                                y=0;
                                if(setting==4)
                                 if(x<16)                          //前16列顯示漢字+分
                                if(point)
                            y=dis_code[40+setting*8+x];
                                y=0;
                                if(setting==5)
                                 if(x<16)                          //前16列顯示漢字-分
                                if(point)
                            y=dis_code[48+setting*8+x];
                                y=0;
                            if(setting==6)
                                 if(x<16)                          //前16列顯示漢字+st
                                if(point)
                            y=dis_code[56+setting*8+x];
                                y=0;
                                if(setting==7)
                                 if(x<16)                          //前16列顯示漢字-st
                                if(point)
                            y=dis_code[64+setting*8+x];
                                y=0;
                                P3=0;
                                   P1=x|0xe0;                //刷新
                                   P3=y;
                                   delay_ms();
                     for(x=0;x<16;x++)
                                if(setting==2||setting==3)
                                        dis_p=x;
                                          if(dis_p<=7 )
                                                y=0;
                                          else if(x<12)  //8~11為十位
                                                disnum=hou;
                                                num=disnum/10;
                                                y=dis_code[num*4+x-8];
                                         else                                   //12~15為個位
                                                  num=disnum%10;
                                                  y=dis_code[num*4+x-12];
                                 if(setting==4||setting==5)
                                        dis_p=x;
                                          if(dis_p<=7 )
                                                y=0;
                                                disnum=min;
                                                num=disnum/10;
                                         else                          //12~15為個位
                                                  num=disnum%10;
                                if(setting==6||setting==7)
                                        dis_p=x;
                                          if(dis_p<=7 )
                                                y=0;
                                                disnum=st;
                                                num=disnum/10;
                                         {                               //12~15為個位
                                                  num=disnum%10;
                                P3=0;
                                   P1=x|0xd0;
                                   P3=y;
                                   delay_ms();
        while(1);
void delay_ms(void)            //顯示刷新
        unsigned char i,j;
          for(i=0;i<4;i++)
          for(j=0;j<30;j++);
void time50ms(void) interrupt 1
           TH0 = 0x4c;
        TL0 = 0x00|(st);
        timecount++;
        if(timecount==10)
                timecount=0;
                 point=!point;
                  if(point)
                          sec++;
                          timedeal();
    if(!K1&&K1!=K1_old)//按下模式鍵
                setting++;
                if(setting==8)
                setting=0;
        if(!K2 && K2!=K2_old)   //按下置位鍵
                if(setting==2)
                        hou++;
                        sec=0;
                        timedeal();
                else if(setting==3)
                        if(hou==0)
                        hou=12;
                        hou--;
                        timedeal();
                else if(setting==4)
                        min++;
                        sec=0;
                        timedeal();
                else if(setting==5)
                        if(min==0)
                        min=60;
                        min--;
                        sec=0;
                        timedeal();
                else if(setting==6)
                        st++;
                        if(st==100)
                        st=0;
                else if(setting==7)
                        st--;
                        if(st==0-1)
                        st=99;
          K1_old=K1;
        K2_old=K2;
void timedeal(void)
        if(sec>=60)
                 sec=0;
                  min++;
          if(min>=60)
                min=0;
                hou++;
         if(hou>12)
         hou=1;
參與人數 1黑幣 +100 收起 理由
admin + 100 共享資料的黑幣獎勵!
ID:1046983 發表于 2022-10-11 10:43 | 顯示全部樓層
太棒了,收藏了
ID:134960 發表于 2020-1-2 17:46 | 顯示全部樓層
不錯,研究一下
ID:318672 發表于 2018-12-13 22:06 來自觸屏版 | 顯示全部樓層
學習學習了
ID:258402 發表于 2018-12-9 23:20 | 顯示全部樓層
先看看
ID:1 發表于 2017-6-20 15:54 | 顯示全部樓層
好資料,51黑有你更精彩!!!
