查看: 11877|回復: 9
單片機熱敏電阻測溫(仿真+程序)
51單片機做的用熱敏電阻來測溫并用數碼管顯示,下面是電路原理圖:
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #include <math.h>
  4. typedef unsigned char uchar;
  5. typedef unsigned int  uint;
  6. code        uint VOL[]={                343,        339,        339,        335,        332,        332,        328,        324,        320,        320,
  7.                                                         316,        312,        312,        308,        304,        300,        300,        296,        292,        292,
  8.                                                         289,        285,        285,        281,        277,        273,        273,        269,        265,        265,
  9.                                                         261,        257,        257,        253,        250,        250,        246,        242,        242,        238,
  10.                                                         234,        234,        230,        230,        226,        222,        222,        218,        218,        214,
  11.                                                         210,        210,        207,        207,        203,        199,        199,        195,        195,        191,
  12.                                                         191,        187,        187,        183,        179,        179,        175,        175,        171,        171,
  13.                                                         167,        167,        164,        164,        160,        160,        160,        156,        156,        152,
  14.                                                         152,        148,        148,        144,        144,        140,        140,        140,        136,        136,
  15.                                                         132,        132,        132,        128,        128,        125,        125,        125,        121,        121,
  16.                                                         121,        117,        113,        109,        109,        105,        101,        101,        97,                97,
  17.                                                         93,                89,                89,                85,                85,                82,                82,                78,                78,                74,
  18.                                                         74,                70,                70,                66,                66,                66,                62,                62,                58,                58,
  19.                                                         58,                54,                54,                54,                50,                50,                50,                46,                46,                46,
  20.                                                         42,                42,                42,                42,                39,                39,                39,                39,                35,                35};
  21. code        uint Temper[]={                100,        150,        200,        250,        300,        350,        400,        450,        500,        550,
  22.                                                         600,        650,        700,        750,        800,        850,        900,        950,        1000,        1050,
  23.                                                         1100,        1150,        1200,        1250,        1300,        1350,        1400,        1450,        1500,        1550
  24.                                                         1600,        1650,        1700,        1750,        1800,        1850,        1900,        1950,        2000,        2050,
  25.                                                         2100,        2150,        2200,        2250,        2300,        2350,        2400,        2450,        2500,        2550,
  26.                                                         2600,        2650,        2700,        2750,        2800,        2850,        2900,        2950,        3000,        3050,
  27.                                                         3100,        3150,        3200,        3250,        3300,        3350,        3400,        3450,        3500,        3550,
  28.                                                         3600,        3650,        3700,        3750,        3800,        3850,        3900,        3950,        4000,        4050,
  29.                                                         4100,        4150,        4200,        4250,        4300,        4350,        4400,        4450,        4500,        4550,
  30.                                                         4600,        4650,        4700,        4750,        4800,        4850,        4900,        4950,        5000,        5050,
  31.                                                         5100,        5200,        5300,        5400,        5500,        5600,        5700,        5800,        5900,        6000,
  32.                                                         6100,        6200,        6300,        6400,        6500,        6600,        6700,        6800,        6900,        7000,
  33.                                                         7100,        7200,        7300,        7400,        7500,        7600,        7700,        7800,        7900,        8000,
  34.                                                         8100,        8200,        8300,        8400,        8500,        8600,        8700,        8800,        8900,        9000,
  35.                                                         9100,        9200,        9300,        9400,        9500,        9600,        9700,        9800,        9900,        10000};
  36. sbit STS=P1^0;
  37. sbit CE = P1^1;
  38. sbit CS=P1^2;
  39. sbit A0=P1^3;
  40. sbit RC=P1^4;
  41. sbit RS=P1^5 ;
  42. sbit RW=P1^6 ;
  43. sbit EN=P1^7 ;
  44. void delay_ms(uint z)
  45. {
  46.         uint x,y;
  47.         for(x=z;x>0;x--)
  48.                 for(y=110;y>0;y--);
  49. }
  50. uint AD1674_Read(void)
  51. {
  52.         uint temp;
  53.         uchar temp1,temp2;
  54.         CS=1;        //片選信號
  55.         CE=0;        //初始化,關閉數據采集
  56.         CS=0;
  57.         A0=0;
  58.         RC=0;
  59.         CE=1;//CE=1,CS=0,RC=0,A0=0啟動12位溫度轉換
  60.         _nop_();
  61.         while(STS==1);         //等待數據采集結束
  62.         CE=0;         //芯片使能關閉
  63.         RC=1;
  64.         A0=0;
  65.         CE=1;//CE=1,CS=0,RC=1,12/8=1,A0=0 允許高八位數據并行輸出
  66.         _nop_();
  67.         temp1=P0; //讀取轉換結果的高八位
  68.         CE=0;  //芯片使能關閉
  69.         RC=1;
  70.         A0=1;
  71.         CE=1;//CE=1,CS=0,RC=1,12/8=0,A0=1 允許低四位數據 并行輸出
  72.         _nop_();
  73.         temp2=P0;         //讀取轉換結果的第四位
  74.         temp=((temp1<<4)|(temp2&0X0F));          //高位和低位合成實際溫度,temp2為PO口的高四位
  75.         return (temp);           //還回轉換結果,右移四位是因為temp2為P0口的高四位
  76. }
  77. /*** 寫數據***/
  78. void w_dat(unsigned char dat)
  79. {
  80.         RS = 1;
  81.         //EN = 0;
  82.         P2 = dat;
  83.         delay_ms(5);
  84.         RW = 0;
  85.         EN = 1;
  86.         EN = 0;
  87. }
  88. /*** 寫命令***/
  89. void w_cmd(unsigned char cmd)
  90. {
  91.         RS = 0;
  92. //        EN = 0;
  93.         P2 = cmd;
  94.         delay_ms(5);
  95.         RW = 0;
  96.         EN = 1;
  97.         EN = 0;
  98. }
  99. /*** 發送字符串到LCD***/
  100. void w_string(unsigned char addr_start, unsigned char *p)
  101. {
  102.         unsigned char *pp;
  103.
  104.         pp = p;
  105.         w_cmd(addr_start);
  106.         while (*pp != '\0')
  107.         {
  108.                 w_dat(*pp++);
  109.         }
  110. }
  111. /*** 初始化1602****/
  112. void Init_LCD1602(void)
  113. {
  114.         EN = 0;
  115.         w_cmd(0x38);  // 16*2顯示,5*7點陣,8位數據接口
  116.         w_cmd(0x0C);  // 顯示器開、光標開、光標允許閃爍
  117.         w_cmd(0x06);  // 文字不動,光標自動右移
  118.         w_cmd(0x01);  // 清屏
  119. }
  120. void process(uint date,uchar add)
  121. {
  122.         uchar A[7];
  123.         A[0]=date/1000%10+'0';
  124.         A[1]=date/100%10+'0';
  125.         A[2]='.';
  126.         A[3]=date/10%10+'0';
  127.         A[4]=date%10+'0';
  128.         A[5]='C';
  129.         w_string(add,A);
  130. }
  131. void main()
  132. {
  133.         uchar i,flag=0;
  134.         uint result,temp1,temp2;
  135.         float        res;
  136.         Init_LCD1602();
  137.
  138.         w_string(0x80,"Temper:");
  139.
  140. ……………………
  141. …………限于本文篇幅 余下代碼請從51黑下載附件…………
熱敏電阻測溫.zip (259.77 KB, 下載次數: 247)
參與人數 2黑幣 +55 收起 理由
公司大股東是個 + 5 共享資料的黑幣獎勵!
收藏收藏4 分享淘帖 頂 踩
ID:58730 發表于 2018-2-5 02:38 | 只看該作者
謝謝分享
ID:282517 發表于 2018-2-6 09:57 | 只看該作者
請問這個1602有字庫嗎?
ID:301273 發表于 2018-4-3 09:00 | 只看該作者
謝謝分享
ID:333584 發表于 2018-5-19 12:25 | 只看該作者
謝謝大佬分享啊!
ID:379683 發表于 2019-1-7 18:47 | 只看該作者
謝謝分享
ID:170800 發表于 2019-1-8 09:46 | 只看該作者
thank you very much!
ID:427755 發表于 2020-3-12 17:12 | 只看該作者
為什么不能調溫度的?
ID:337609 發表于 2020-3-16 17:14 | 只看該作者
初心22 發表于 2020-3-12 17:12
為什么不能調溫度的?
你點擊那個熱敏電阻 把最下面的10 改成其他數就行
ID:710864 發表于 2020-3-18 14:34 | 只看該作者
謝謝大佬
