查看: 3322|回復: 0
人機界面初稿
ID:190116 發表于 2017-6-16 02:50 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h> // 引用標準庫的頭文件
#include <intrins.h>
#include <eeprom.h>
#define uint  unsigned int
#define det_Dist 0.45454545         //20MM/44
//=============HALL按鍵接口======================
sbit    HALL_r  =    P3^2;// 右邊HALL模塊檢測口 INT0
sbit    HALL_l  =    P3^3;// 左邊HALL模塊檢測口 INT1
sbit        up=P2^0;           //up
sbit        down=P2^1;           //down
sbit        m1234=P2^2;   // m1234
//=================電機驅動接口=====================
sbit    dianji_r = P1^0;  //右邊電機U10P7控制口,低電平正轉,高電平反轉
sbit    pwm_r = P1^1;
sbit    brake_r = P1^2;          //剎車
sbit    dianji_l = P1^3;  //左邊電機U9P6控制口,低電平正轉,高電平反轉
sbit    pwm_l = P1^4;
sbit    brake_l = P1^5;          //剎車
sbit    r12 = P0^0;            //RCK  or #define r12 P0_0?
sbit    s11 = P0^1;                   //SCK
sbit    d14 = P0^2;                  //模擬SPI總線
uchar r_count;//右邊HALL檢測到的次數計數單元xj
uchar l_count;         //xj
uint time;                //xj
uchar i,j;                            //定義循環控制變量lc
uchar code duan[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x7F};        //0x7F點亮小數點
                    //0    1    2    3    4    5    6    7    8    9    .  BLOG
uchar code duandp[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};        //段碼含小數點
                    //0.    1.    2.   3.   4.   5.  6.   7.    8.  9.    zb
uchar code wei[]={0x01,0x02,0x04,0xf7,0xef,0xdf,0xbf,0x7f};                //后5位鍵掃用,按M1234鍵序送出低電平
                                   //1    2    3    m    1    2    3    4           BLOG        ,11110111,11101111,11011111,10111111,01111111
uint keyvalue;         //BGSY TinyHMI
    //uchar KeyValue;        //用來存放讀取到的鍵值 PZ矩陣
    //uchar M,O,T,TRE,F;
void    check_right();//右邊時候檢測到停止測試程序
void    check_left();//左邊時候檢測到停止測試程序
void delay_50us(uint t); //xj
void delayms(uint Ms);         //xj
void delay2ms(void);         //595BLOG
   //void delay(uint i);                 //PZ
void h595_in(uchar Data); //595BLOG
void h595_out(void);           //595BLOG
void Hc595SendData(uchar SendVal); //595BLOG+YL視
void TinyHMI_STR(void);
void TinyHMI_CP(void);
char delay100us(unsigned int uiDly);
void TinyHMI_Display(unsigned char Data); //8位串入并出帶鎖存送數子程序
void TinyHMI_Show(unsigned i,unsigned j);
void TinyHMI_Scan(void);
   //void KeyDown(void);                  //PZ矩陣
//void Keypros();                           //PZ后要用
   //=============計數器初始化子程序BK ======================
void Init_Timer0(void)
    TMOD = 0x0D;        // TMOD=00001101B不影響定時計數器T1
                        // 使用定時計數器T0(GATE 1, C/T 1計數, M1 0, M0 1)
                        // 使用模式1, 16位定時器.
    TH0 = (65536 - 50000) / 256;     // 計數器計數初值, 這里使用定時器最大值從0開始計數一直到65535溢出
    TL0 = (65536 - 50000) % 256;
    EA = 1;            // 總中斷打開
    ET0 = 0;           // 不使用定時器T0管腳的中斷
    TR0 = 1;           // 定時器計數器開關打開
}                                           // 計數器器初始化子程序
//***********************主程序******************************
main()
    uchar cnt=0;
    uint temp=0;
    uint tab=0,wap=0,a;            //定義無符號整形變量
    double way = 0,sudu = 0;//定義浮點型數據,way表示高度,sudu表示速度
          uint Hc595SendVal;
   TinyHMI_Scan();
  time=50;
    dianji_r=1;//上電時右側電機stop
    dianji_l=1;//上電時左側電機stop
        brake_r =0;
        brake_l =0;
        pwm_r =1;
        pwm_l =1;
        EA=1;           //CPU總中斷允許控制IE
    EX1=1;           //INT1外部中斷1允許控制IE
    EX0=1;           //INT1外部中斷1允許控制IE
    IT1=1;           //INT1設下降沿觸發方式 外部中斷1請求標志TCON
    IT0=1;            //INT0設下降沿觸發方式 外部中斷0請求標志TCON
   HALL_r=1;//置IO為1,準備讀取數據
   HALL_l=1;
   _nop_();
   r_count=0;
   l_count=0;
       _nop_();//
           check_right();//調用右邊HALL檢測傳感器
           check_left(); //調用左邊HALL檢測傳感器
         TH1=0x00;
         TL1=0x00;
         sudu=0;            //速度清零
             temp=TH1;
         temp=temp<<8;             //將TH1中數字左移8位再賦給temp
         temp=temp|TL1;      //將TH1和TL1中數據合到一個整形變量temp中
         way=temp*det_Dist;           //高程存入浮點型變量way中
      while(HALL_r==1);                  //等待0INT變低
             TR0=1;
      while(HALL_r==0);                  //等待0INT變高
         TR0=0;
         a=TH0;
         a=a<<8;
         a=a||TL1;         a=a*0.001;
         sudu=2/a;
         wap=sudu*10;
      wap=sudu*10; //將速度數據轉化為整形,最低位表示十分位,其次為個位,十位
      tab=way*10;  //將高程數據轉化為整形,最低位表示厘米,其次表示分米,米
          Hc595SendVal=tab;
          Hc595SendData(Hc595SendVal);
                if(up==0)
                        dianji_r=0;          //        正轉
                        dianji_l=0;          //        正轉
                            if(sudu==0)
                                   brake_r =1;        //剎車
                           brake_l =1;        //剎車
                }                 //堵轉保護
                    }                //        正轉
            if(down==0);
                        dianji_r=1;        //反轉
                        dianji_l=1;        //反轉
                                  if(sudu==0)
                                  dianji_r=0; //        正轉
                          dianji_l=0; //        正轉
                                          if(way==2)
                                           brake_r =1;        //剎車
                                   brake_l =1;        //剎車
                                           Init_Timer0();
                                    }  //反轉堵轉變正轉2個脈沖,計數器初始化
                         }                 //        反轉
  void init0int() interrupt 2
       l_count=2;
       dianji_l=1;
       dianji_r=0;
       if(r_count>0)
               EX0=0;
           delayms(20);
           if(time>=20)time-=19;
           EX0=0;
      return;
  void init1int() interrupt 0
      r_count=2;
     dianji_r=1;          dianji_l=0;
     if(l_count>0)
     { EX1=0;
      delayms(20);
      EX1=1;}
     return;
  //函數名稱:
  //功能:左邊邊時候檢測到停止測試程序
void    check_left()
    if(HALL_l==0)//檢測右邊的傳感器是否感應到停止
     delay_50us(1);//延時,去除機械振動
     _nop_();
     if(HALL_l==0)//再次檢測
           if(HALL_l==0)
            l_count++;
            HALL_l=1;
//函數名稱:
        //功能:右邊時候檢測到停止測試程序
void    check_right()
if(HALL_r==0)//檢測右邊的傳感器是否感應到停止
  if(HALL_r==0)//再次檢測
   if(HALL_r==0)
    r_count++;
    HALL_r=1;
//函數名稱:void delay_50US(unsigned int t)
//功能:延時50*t(us)
    uchar j;
    for(;t>0;t--)
       for(j=19;j>0;j--);
/*==========設定延時時間:x*1ms  =============*/
   uint i,TempCyc;
   for(i=0;i<Ms;i++)
     TempCyc =70;
     while(TempCyc--);
void delay2ms(void)
   unsigned char i,j;
   for(i=133;i>0;i--)
   for(j=6;j>0;j--);
/*void delay(uint i)
        while(i--);
void h595_in(uchar SendVal)
uchar i;
for(i = 0; i < 8; i++)   //循環8次,剛好移完8位
      s11 = 0;        //先將移位寄存器控制引腳SCK(s11)置為低
      _nop_();
      if((SendVal & 0x80)== 0x80)          //SendVal是沒有經過位分離的d14數據。因595先處理最高位,所以用0x80
           d14 =1;  //當0賦i(第1輪for循環),SendVal最高位(第8位)若高電平,則&運算后,d14也為高電平,
      else                    //否則,
           d14 =0;  //d14為低電平,1賦i(第2輪for循環)、2賦i(第3輪for循環).....以此類推
       SendVal <<= 1;      //將數據的次高位移到最高位
       s11 = 1;            //再置為高,產生移位時鐘上升沿,上升沿時數據寄存器的數據移位
      _nop_();
}          //串行入
void h595_out(void)
      r12 = 0; //先將存儲寄存器引腳置為低
      _nop_();
      r12 = 1; //再置為高,產生移位時鐘上升沿,上升沿時移位寄存器的數據進入數據存儲寄存器,更新顯示數據。
}    //并行出
uchar i;
  for(i = 0;i < 8;i++)  //有3位數碼管,3位依次掃描        余5位按鍵
     h595_in(duan[i]);  //先傳段碼?(BLOG圖段9-位14腳送序與己同)
     h595_in(wei[i]);   //再傳位碼,3<=i<8傳M1234按鍵,595輪流輸出一個低電平,P2^2已上拉,當檢測P2^2腳為低電平時,看595是哪腳輸出低電平,得鍵值
     h595_out();
     delay2ms();        //延遲時間2ms以內
r12 =1; //STR開解鎖控制字
_nop_();
r12 =0;
s11 =1; //CP方波移位控制字
_nop_();
s11 =0;
unsigned char k;
do{
   k=46;
   do{
     }while (--k!=0);
  }while (--uiDly!=0);
return 0;
void TinyHMI_Display(unsigned char Data) //8位串入并出帶鎖存送數子程序
unsigned char i;
for (i=0;i<8;i++)
  d14=Data&0x80;
  Data<<=1;
  TinyHMI_CP();
void TinyHMI_Show(unsigned i,unsigned j)                // unsigned?
TinyHMI_Display(duandp[i+1]);
TinyHMI_Display(~wei[j+1]);
TinyHMI_STR();
delay100us(22);
  unsigned i;
  for (i=3;i<8;i++)
   TinyHMI_Display(duandp[i]);
   TinyHMI_Display(~wei[i]);
   TinyHMI_STR();
   if(m1234==0)keyvalue=i;
   if(keyvalue==1)TinyHMI_Show(1,0);
   if(keyvalue==2)TinyHMI_Show(2,1);
   if(keyvalue==3)TinyHMI_Show(3,2);
   if(keyvalue==4)TinyHMI_Show(4,3);
   if(keyvalue==5)TinyHMI_Show(5,4);
   if(keyvalue==6)TinyHMI_Show(6,5);
   if(keyvalue==7)TinyHMI_Show(7,6);
   if(keyvalue==8)TinyHMI_Show(8,7);
   delay100us(22);
/*for(n=3;n<8;n++) //BG,CF
  s11 out;
  Qn = 1;//Qn595某腳
  s11 in;
  if(s11==1) KEYn=1;//KEYn某鍵
  else       KEYn=0;
  Qn = 0;
/*void KeyDown(void)          //M1234按下 PZJZ
        char a=0;
        m1234=0;
        if(m1234!=0)//讀取按鍵是否按下(m1234中任一按下,通過d14、CPUP2^2口傳595后5位選拉低)
                delay(500);//延時5ms進行消抖
                if(m1234!=0)//再次檢測鍵盤是否按下
                        m1234=0;
                        switch(P2^2)//不需要如何將P2^2口送出8位串行數據
                                case(0xf7):        KeyValue=M;break;                 //11110111
                                case(0xef):        KeyValue=O;break;                 //11101111
                                case(0xdf): KeyValue=T;break;                 //11011111
                                case(0xbf):        KeyValue=TRE;break;                 //10111111
                                case(0x7f):        KeyValue=F;break;                 //01111111
                        while((a<50)&&(m1234!=0))         //檢測按鍵松手檢測
                                delay(1000);
                                a++;
/*M1234鍵函*/
/*void Keypros()
        if(M==0)
                delay(1000);  //消抖處理
                if(k1==0)
                        At24c02Write(1,num);   //在地址1內寫入數據num
                while(!k1);
        if(k2==0)
                delay(1000);  //消抖處理
                if(k2==0)
                        num=At24c02Read(1);          //讀取EEPROM地址1內的數據保存在num中
                while(!k2);
        if(k3==0)
                delay(100);  //消抖處理
                if(k3==0)
                        num++;           //數據加1
                        if(num>255)num=0;
                while(!k3);
        if(k4==0)
                delay(1000);  //消抖處理
                if(k4==0)
                        num=0;                 //數據清零
                while(!k4);
if(M==0)//擦除數據(準備寫)SMG 閃
                        {        if(O==0)   //寫0x2000SMG !閃(&位選)
                                if(T==0)   //寫0x2200SMG !閃(&位選)
                                if(TRE==0) //寫0x2400SMG !閃(&位選)
                                if(F==0)   //寫0x2600SMG !閃(&位選)        }
if(O==0)   //讀0x2000SMG 電機轉到1位
if(T==0)   //讀0x2200SMG 電機轉到2位
if(TRE==0) //讀0x2400SMG 電機轉到3位
if(F==0)   //讀0x2600SMG 電機轉到4位        } */
