查看: 6687|回復: 3
開源無刷云臺Arduino代碼
ID:211725 發表于 2017-6-15 22:29 | 顯示全部樓層 |閱讀模式
Configuration of the paramters is accomplished by a serial protocol.
The user will not access the serial line directly, he will use a graphical user interface (GUI) running on a host pc.
A proper gui tool (blg-tool) is located in the GUI folder.
The Arduino Serial Monitor can be used for debugging purposes.
Arduino -> Tools -> Serial Monitor Settings
  Baudrate: 11200 Baud, NL and CR
全部資料下載地址:
BruGi_050_r217.zip (3.01 MB, 下載次數: 63)
ID:87766 發表于 2019-1-2 19:40 | 顯示全部樓層
謝謝分享
ID:79544 發表于 2020-3-20 10:16 | 顯示全部樓層
樓主報錯啊//
ID:79544 發表于 2020-3-20 10:28 | 顯示全部樓層
編譯報錯。用1.7.8和1.8.3以及1.5.3版本都不行
