這是原理圖
下載:
16X32點(diǎn)陣源碼51.zip
(56.44 KB, 下載次數(shù): 49)
2017-6-15 11:18 上傳
點(diǎn)擊文件名下載附件
單片機(jī)程序源碼:
- #include <reg51.h>
- #include <intrins.h>
- #define DATAOUT P1 //P3 use as data, you can change
- #define SPEED 13
- void ymove(char dir,unsigned char *ptr,char speed);
- //void xmove(char dir,unsigned char *ptr,char n,char speed);
- void delay(unsigned int a);
- void display();
- void displaytime(char time);
- void init164();
- void kong(char dir, char speed);
- void fanzhuan(unsigned char *p);
- sbit ADATA= DATAOUT^1;//DS
- sbit ASCK= DATAOUT^2;//SCK
- sbit LATCH= DATAOUT^3;//LATCH
- sbit BDATA= DATAOUT^4;//RDATA
- sbit BCLK= DATAOUT^6;//CLK
- sbit K1 =P0^0;
- sbit K2 =P0^1;
- sbit K3 =P0^2;
- //OE接低電平
- //MR接高電平
- //CLR接高電平
- unsigned char idata buffer[64];
- unsigned char bigbuffer[194];
- unsigned char comm_len;
- unsigned char BSBUF=0;
- unsigned char iii; //全局當(dāng)前顯示第幾個(gè)字
- void Delay10ms() //@11.0592MHz
- unsigned char i, j;
- i = 18;
- j = 235;
- do
- while (--j);
- } while (--i);
- void UART_Init(void)//串口初始化函數(shù)
- SCON=0X50; //串口方式1,允許接收
- TMOD|=0X20; //定時(shí)器1 定時(shí)方式2 T0 is mode 1\
- TH1=0xfd; //Baud:9600 fosc=11.0592MHz
- TL1=0xfd;
- TR1=1; //啟動(dòng)定時(shí)器
- ES = 1; //開串口中斷
- EA = 1; //開總中斷
- void main(void)
- unsigned char i;
- init164();
- UART_Init();
- for(i=0;i<194;i++)
- bigbuffer[i]=0x00;
- //fanzhuan(&bigbuffer[1]);
- //for(i=0;i<32;i++)
- // buffer[i+32]=buffer[i];
- while(1)
- if(bigbuffer[0]==0x16)
- for(iii=0;iii<bigbuffer[1];iii++)
- ymove(1,&bigbuffer[2+iii*32],SPEED);
- else if(bigbuffer[0]==0x15)
- ymove(0,&bigbuffer[2+iii*32],SPEED);
- else
- display();
- /************* 子函數(shù) ******************/
- void delay(unsigned int a) //延時(shí)函數(shù)
- while(a--);
- unsigned char i,j,k,temp,*w,temp1,temp2,temp3;
- w=p;
- for(i=0;i<8;i++) //左下角的8*8 翻轉(zhuǎn)后位于左上角
- temp=0x00;
- for(j=0;j<8;j++)
- temp1= *(p+30-j*2) ;
- temp2=temp1<<i;
- temp3=temp2&0x80;
- temp3=temp3>>j;
- temp=temp|temp3;
- buffer[i*2]=temp;
- for(i=0;i<8;i++) //左上角的8*8 反轉(zhuǎn)后位于右上角
- temp=0x00;
- for(j=0;j<8;j++)
- temp1= *(p+14-j*2);
- temp2=temp1<<i;
- temp3=temp2&0x80;
- temp3>>=j;
- temp|=temp3;
- buffer[i*2+1]=temp;
- for(i=0;i<8;i++) //右上角的8*8 反轉(zhuǎn)后位于右下角
- temp=0x00;
- for(j=0;j<8;j++)
- temp1= *(p+15-j*2);
- temp2=temp1<<i;
- temp3=temp2&0x80;
- temp3>>=j;
- temp|=temp3;
- buffer[i*2+17]=temp;
- for(i=0;i<8;i++) //右下角的8*8 反轉(zhuǎn)后位于左下角
- temp=0x00;
- for(j=0;j<8;j++)
- temp1= *(p+31-j*2);
- temp2=temp1<<i;
- temp3=temp2&0x80;
- temp3>>=j;
- temp|=temp3;
- buffer[i*2+16]=temp;
- /*顯示*/
- void display() //顯示buffer里32*16的數(shù)據(jù)
- unsigned char hang,ib,k,tmp;
- DATAOUT= 0x0;
- BDATA = 1 ;
- for(hang=0;hang<16;hang++)
- ASCK =0;
- LATCH=0;
- BCLK =0;
- for(ib=0;ib<2;ib++)
- tmp = buffer[hang*2+ib];
- for(k=0;k<8;k++)
- tmp <<=1;
- ASCK =0;
- ADATA =CY;
- ASCK =1;
- tmp = buffer[hang*2+ib+32];
- for(k=0;k<8;k++)
- tmp <<=1;
- ASCK =0;
- ADATA =CY;
- ASCK =1;
- //DATAOUT|=0x14;
- LATCH=1;
- BCLK=1;
- BDATA=0;
- delay(64);
- ASCK =0;
- ASCK =1;
- void displaytime(char time) //循環(huán)刷新顯示
- unsigned char i;
- while(time--)
- i=130;
- while(i--)
- display();
- /*74ls164,74ls595的初始化*/
- void init164()
- char i;
- BDATA=0;
- for(i=0;i<16;i++) //清空164
- BCLK =0;
- BCLK =1;
- for(i=0;i<32;i++) //清空595
- ASCK =0;
- ADATA =0;
- ASCK =1;
- /*左右移動(dòng)*/
- void ymove(char dir,unsigned char *ptr, char speed)
- { //dir=1左移動(dòng),dir=0為右移動(dòng)
- char i=0, j=0, ib=0;
- unsigned int tmp=0, speedm=0;
- if(dir==0)
- /**** 向右移 ****/
- ib=31;
- for(i=16;i>0;i--) //下移16行
- for(j=61;j>-1;j--)
- buffer[j+2]=buffer[j]; //將上一行的內(nèi)容復(fù)制到下一行
- if(ptr==0)
- { //移空時(shí),buffer的首行用0移入
- buffer[0]=0;
- buffer[1]=0;
- else
- { //否則,處理buffer的首行元素
- buffer[1]=ptr[ib];
- buffer[0]=ptr[ib-1];
- ib=ib-2;
- speedm=speed;
- while(speedm--) //更新點(diǎn)陣
- display();
- /****** 向左移 *******/
- else
- ib=0; //數(shù)組元素序號(hào)
- for(i=0;i<16;i++) //上移16行
- for(j=0;j<62;j++) //將下一行的內(nèi)容復(fù)制到上一行
- buffer[j]=buffer[j+2];
- if(ptr==0) //移入為空,buffer的末行用0移入
- buffer[62]=0;
- buffer[63]=0;
- else
- { //否則,處理buffer的末行元素
- buffer[62]=ptr[ib];
- buffer[63]=ptr[ib+1];
- ib=ib+2;
- speedm=speed; //更新點(diǎn)陣
- while(speedm--)
- display();
- if(dir==0)
- /**** 向左移 ****/
- ib=31;
- for(i=8;i>0;i--) //下移16行
- buffer[0]=0;
- buffer[1]=0;
- speedm=speed;
- display();
- /****** 向右移 *******/
- else
- for(i=0;i<8;i++) //上移16行
- buffer[62]=0;
- buffer[63]=0;
- ib=ib+2;
- while(speedm--)
- display();
- void uart_get_int(void) interrupt 4//串口中斷接收函數(shù)
- unsigned char i,j,k;
- RI=0;
- if(SBUF==0XEF&&BSBUF==0xFE) //啟始幀
- comm_len=0;
- return;
- BSBUF=SBUF;
- bigbuffer[comm_len]=SBUF;
- comm_len++;
- if(comm_len==194) //所有數(shù)據(jù)接受完畢 串口發(fā)送數(shù)據(jù) 字模轉(zhuǎn)換 主函數(shù)里面滾屏
- comm_len=0;
- if(bigbuffer[0]==11)return;
- iii=bigbuffer[1]-1;
- SBUF= bigbuffer[i];
- while(!TI);
- TI=0;
- for(j=0;j<6;j++)//6個(gè)漢字的字模轉(zhuǎn)換
- fanzhuan(&bigbuffer[2+j*32]);
- for(k=0;k<32;k++)
- bigbuffer[2+j*32+k]=buffer[k];
- void saomiao()
- if(K1==0)
- Delay10ms();
- if(K1==0)
評(píng)分
查看全部評(píng)分
