          查看: 2757|回復: 0
          Cortex-M3 驅動16 * 02 LCD程序
          ID:210672 發(fā)表于 2017-6-13 08:51 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
          版權聲明:本日志所載內容的版權為本人所擁有,僅供學習目的,切勿用于商業(yè)用途。未經本人同意,不可轉載或拷貝及復制用于任何目的之用途。
          嘔心瀝血兩個星期,終于成功調試完成Cortex-M3 驅動16 * 02 LCD程序。
          void LCD_init(void)
          //LCD初始化
            LCD_PortConfig();
            LCD_BLC_ON();
            Delay_Ms(500);
            LCD_write_command(0x38);
            Delay_Us(50);
            LCD_write_command(0x39);
            Delay_Us(50);
            LCD_write_command(0x14);
            Delay_Us(50);
            LCD_write_command(0x78);
            Delay_Us(50);
            LCD_write_command(0x5e);
            Delay_Us(50);
            LCD_write_command(0x6f);
            Delay_Us(50);
            LCD_write_command(0x0f);
            Delay_Us(50);
            LCD_write_command(0x01);
            Delay_Us(50);
            LCD_write_command(0x06);
            Delay_Us(50);
            Delay_Ms(10);
          static void LCD_WriteDataByte( unsigned char uData )
            unsigned long sSysclock;
            unsigned char i;
            sSysclock = SysCtlClockGet() / (1000000 * 3);
            for( i = 0; i < 8; i++ )
          //    GPIOPinWrite( GPIO_PORTB_BASE, LCDSCL, LCDSCL );
              if( uData & 0x80 )
                GPIOPinWrite( GPIO_PORTB_BASE, LCDSDA, LCDSDA );
                GPIOPinWrite( GPIO_PORTB_BASE, LCDSCL, 0 );
                GPIOPinWrite( GPIO_PORTB_BASE, LCDSDA, 0 );
              // 左移數據,剛好又可以做延時.
              uData <<= 1;
              SysCtlDelay(sSysclock);
          //    SysCtlDelay(sSysclock);
            GPIOPinWrite(GPIO_PORTD_BASE,LCDCSn,0);
          void LCD_write_command(unsigned char command)          //寫指令
            GPIOPinWrite(GPIO_PORTD_BASE,LCDCSn,LCDCSn);
            GPIOPinWrite( GPIO_PORTF_BASE,LCDRSn,0);
            LCD_WriteDataByte( command );
          //  GPIOPinWrite(GPIO_PORTD_BASE,LCDCSn,LCDCSn);
