路虎LPC1768開發(fā)板 GPIO實驗
這個例程是將路虎開發(fā)板上的八個LED輪流點亮100毫秒,
采用SYStick 定時器中斷方式做延時 系統(tǒng)時鐘設置在100MHZ
使用時,短路JP8跳線使能LED。
- * @file main.c
- * @brief CMSIS Cortex-M3 GPIO example
- * a LED using CM3 SysTick
- * @version V1.30
- * @date 24. Jan 2010
- * @note
- * Copyright (C) 2009 ARM Limited. All rights reserved.
- * @par
- * ARM Limited (ARM) is supplying this software for use with Cortex-M
- * processor based microcontrollers. This file can be freely distributed
- * within development tools that are supporting such ARM based processors.
- * @par
- * THIS SOFTWARE IS PROVIDED "AS IS". NO WARRANTIES, WHETHER EXPRESS, IMPLIED
- * OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF
- * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE.
- * ARM SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR
- * CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
- #include "LPC17xx.h"
- volatile uint32_t msTicks; /* counts 1ms timeTicks */
- SysTick_Handler
- void SysTick_Handler(void) {
- msTicks++; /* increment counter necessary in Delay() */
- delays number of tick Systicks (happens every 1 ms)
- __INLINE static void Delay (uint32_t dlyTicks) {
- uint32_t curTicks;
- curTicks = msTicks;
- while ((msTicks - curTicks) < dlyTicks);
- configer LED pins
- __INLINE static void LED_Config(void) {
- LPC_GPIO2->FIODIR = 0x000000ff; /* LEDs PORT2 are Output */
- LPC_GPIO0->FIODIR = 0x00200000;
- LPC_GPIO0->FIOPIN |= 0x00200000;
- Switch on LEDs
- __INLINE static void LED_On (uint32_t led) {
- LPC_GPIO2->FIOPIN |= (led); /* Turn On LED */
- Switch off LEDs
- __INLINE static void LED_Off (uint32_t led) {
- LPC_GPIO2->FIOPIN &= ~(led); /* Turn Off LED */
- MAIN function
- int main (void) {
- uint8_t location;
- if (SysTick_Config(SystemCoreClock / 1000)) { /* Setup SysTick Timer for 1 msec interrupts */
- while (1); /* Capture error */
- LED_Config();
- while(1)
- LED_On (0xff);
- Delay (500);
GPIO.rar
(163.57 KB, 下載次數: 18)
2017-6-12 20:20 上傳
